Solving electrostatic, rotationally symmetric 3D problem with conformal mapping?
3 replies · 5K views · last reply
Gerenuk
I heard that one can solve 2D problem with conformal mapping of complex numbers.
Is it possible to use this method for 3D axial-rotationally symmetric problems (which are effectively 2D with a new term in the differential equation)?
Azimuthally symmetric 3D problems have different solutions than 2D ones, so solution approaches are not interchangeable. Take a cut through a cylinder including the axis--it looks like a rectangle, but radial solutions are Bessel functions. The sine/cosine solutions you'd get from solving it as a 2D rectangle are flat out wrong.
I know that.
I was wondering if one can still use some kind of complex variable method such as conformal mapping to treat this 2D problem.
To be clear on what you mean by "this" 2D problem:
Solution of 2D problem in a planar boundary like rectangle--yes
Solution of 3D azimuthally symmetric problems--no.
Actually, Weber recounts that Maxwell evaluated the capacitance of parallel plates with guard rings by approximating as a 2D conjugate-function solution valid far from the axis. The general answer is no.
Weber, Electromagnetic Fields, Vol. 1: Mapping and Fields, Wiley, 1950.
