Solving for Angle of Elevation: p = 12.67°
  • Thread starter Thread starter thereddevils
    Angle
5 replies · 2K views · last reply
thereddevils
A small ball is projected with a speed of 10 m/s at an angle of elevation of p from the top of a vertical pole whose height is 15 m from the level ground. The ball hits the ground at a point whose horizontal distance from the foot of the pole is 20 m . Find the value of p . gravity=10 m/s^2
Consider horizontal motion , s=Vx t
20=10 (cos p) t
t=2/(cos p) --1
Consider vertical motion,
15=10 (sin p)(2/(cos p))+1/2 (10)(2\(cos p))^2
15 cos^2 p -20 sin p cos p -20 =0
3 cos 2p - 4 sin 2p=1
5 cos (2p+53.13)=1
2p+53.13=78.46
therefore , p=12.67 degrees
Am i correct ?
15=10 (sin p)(2/(cos p))-1/2 (10)(2\(cos p))^2
Till the above step you are right except one sign. Next
15 = 20tan(p) - 20sec^2(p)
Put sec^2(p) = 1 + tan^2(p) and solve for tan(p)
Thanks but isn't the ball being projected downwards which is in the path of the gravity pull ?
Projected at an angle of elevation means up against the gravitational pull.
Be careful with your signs in your equation for the vertical position. We can use, since the acceleration due to gravity is approximately constant:
[tex]\Delta y \equiv y_{f}-y_{0}=v_{y}t+\frac{1}{2}at^{2}[/tex]
If we define our coordinate system so that up is positive and down, negative then we are given
[tex]y_{0}=+15, v_{y}=+10sin(p), a=-g=-9.8[/tex]
Since it starts out above the ground and is shot with an initial velocity up and gravity pulls it down.
got it , thanks
