Solving for Flux. Basic Calculus question.
The discussion revolves around a basic calculus question related to the concept of flux in the context of heat transfer. The original poster is attempting to understand the relationship between the rate of heat transfer per unit area and its derivative with respect to area.
  • Conceptual clarification, Mathematical reasoning
  • The original poster questions the validity of taking the derivative of an integral with respect to the same variable, expressing confusion about whether this results in zero. They seek clarification on how to correctly solve for flux in this context.
Some participants have provided insights into the relationship between integration and differentiation, suggesting that the derivative of the integral relates to the original function being integrated. There appears to be a productive exchange of ideas, with some clarification being offered regarding the mathematical principles involved.
The original poster expresses uncertainty about the application of calculus principles in this specific scenario, indicating a potential misunderstanding of the relationship between flux and its mathematical representation.
kdhutchi
Basic Question. My book describes the rate of heat transfer per unit of system area as \dot{Q}=\int\dot{q}dA.
I'm trying to solve for the flux. I've already discovered that the correct answer question is just the derivative of \dot{Q} with respect to area, but this goes against other things I've read. I thought taking the derivative of an integral with respect to the same variable as the integration yields zero. For example, if I was integrating something with respect to area, and I take the derivative of the integral with respect to area, then the whole thing cancels out. Isn't this true? How would I solve for the flux in this case?
When you integrate, the entire "argument" of the integration is the differential element of the desired function. The integration just sums them up. So for example,
F(x) = \int f(x) dx
then the differential element for F(x) is f(x)dx. That is to say, dF = f(x)dx.
Rearranging, you find dF/dx = f(x).
So in your case d\dot{Q} = \dot{q}dA and \frac{d\dot{Q}}{dA} = \dot{q}
I think I understand what you are saying. The part where you mention dF=f(x)dx comes from just taking a derivative from both sides, correct? So dividing by dx will produce the dF/dx=f(x) I sought earlier correct?
Right.
Thank you for your help Gneill!
