Solving for mass of a solute given ppm and volume?
  • Thread starter Thread starter CamD13
    Mass Volume
To find the mass of oxygen in a solution with 23 ppm and a volume of 242.0066 mL, the formula for ppm can be applied: ppm = (grams of solute / grams of solution) * 1,000,000. The challenge arises from the lack of information about the density of the solution, which is necessary to convert volume to mass. Without knowing the density, it's impossible to determine the mass of the solution and subsequently the mass of the solute. Clarification on the solution's density or additional context is needed to solve the problem accurately. Accurate calculations require both the ppm value and the mass of the solution.
CamD13
The question is: A solution contains 23ppm of dissolved O2 in 242.0066 mL of solution. What is the mass of the oxygen.
Formula: ppm=(grams of solute/grams of solution)*1,000,000
I tried plugging stuff in but it wasn't working out what so ever.
I just don't know how to do these when given so little information. Thanks in advance if you can help.
The solution is NOT water.
Formula calls for the mass of the solution. You are give volume. You either have enough information to do the conversion, or not - hard to say not knowing the context.
