Solving for Real Current in a Complex Circuit
17 replies · 3K views
Niles
Hi all.
Please take a look at the attachted circuit.
I have found the following expression for the complex current in the resistor (the hat indicates that it is complex):
[tex] \widehat_{I (t)} = \frac{{\omega ^2 LC {\widehat{U_0} }}}{{\omega ^2 LRC + i\omega L - R}}\exp ( - i\omega t),[/tex]
where U_0 is the amplitude of U(t), and the hat indicates that it is complex.
Now I wish to find the real current, and I want to write it as:
[tex] I(t) = I_0\cos(\omega t + \phi).[/tex]
But how do I do this? I have spent like 2 hours trying, but I don't know how to rewrite the complex amplitude of the current to have a phase.
Thanks in advance.
Regards
Niles.
Hi Niles! :smile:
(have an omega: ω and a phi: φ :wink:)
The standard way would be to write the left bit as A + iB (multiply top-and-bottom by the complex conjugate of the bottom), and then
Re(A + iB)eiωt = Re(A + iB)(cosωt + isinωt)
= Acosωt - Bsinωt,
which maybe you know how to rewrite as Ccos(ωt + φ) ? :wink:
Ok, so you are telling me to multiply the first term on the RHS with the complex conjugate and then take the square root. Thus I get the amplitude of the current, and now we have to multiply that with exp(iφ).
But this gives me: ... * exp(-i(ωt-φ))? Don't we want a plus instead?
And thanks for replying!
Why are you taking the square root? :confused:
(And you did multiply top and bottom, didn't you? To get a complex over a real?)
Anyway, you don't multiply the amplitude with exp(iφ) …
you can't find the amplitude (or the phase) until you've got the whole function …
in other words, until after you multiply. :smile:
Ok, so what I do is:
1) Multiply the first term on the RHS with the complex conjugate of the denominator.
2) I find the phase, and write the first term as: z = |z|*exp(iφ).
3) Find the real part, and all ...
4) Done? If yes, then I will go to bed.
EDIT: Can you confirm me in that -0.1 * 2*Pi radians is equal to 2*Pi - 0.1 * 2*Pi radians?
I'm not convinced that you've got it.
You're given (K + iL)/(M + iN) times eiωt
that's (K + iL)(M - iN)/(M + iN)(M - iN) times eiωt
= (K + iL)(M - iN)/(M2 + N2) times eiωt
the bottom is real, so the whole of the left can now easily be put in the form A + iB …
go on from there.
Yes, adding multiples of 2π to the phase makes no difference … e2πi = 1
… so if your result comes out as more than 2π, just subtract 2π (or 4π or … ) :smile:
go on from there.
And then I write z = A + iB as z = |z|e, right?
sorry!
ooh, I misunderstood what you wrote earlier …
even though it was clear :rolleyes:
Yes, that's right … then the real current will be the real part of |z|*exp(-iωt + iφ), = |z|*cos(-ωt + φ)
To answer a previous point, cos(x) = cos(-x), so the minus sign doesn't matter (though it will mess up the sign of φ). :smile:
Ignore some of my previous comments. :redface:
Nono, they were all good. Thanks for helping me - I see it much clearer now!
Niles.
I have found the phase φ to be -0.63, which is equivalent of 5.65. Does this mean that I am allowed to write:
I(t) = Re [|z|*exp(-iωt - 0.63i)] = Re [|z|*exp(-i(ωt + 0.63)] = |z|*cos(ωt + 0.63),
where Re [..] denotes the real part of the argument "...".
Yup! :biggrin:
Great! Thanks!
Just one last thing: Is it correct that sometimes the expressions for the current are very nasty? I mean, they are sometimes quite long :rolleyes:
Niles said:
Great! Thanks!
oooh … dunno! :redface:
i never did current 'n' stuff …
i just know about the maths bit! :smile:
Niles said:
Great! Thanks!
Hah, yes.
Consider a serial RCL circuit, that is, a voltage source connected to a condensator, a loop and a resistor. Let's say the Resistor is 200 ohm, the loop is 1 millihenry and the condensator is 20 nanofahrad. If you apply a simple voltage, not even timevariable, of 10 volt to this system, the current will look like this:
i(t)=0.05*e^(-100000*t)*sin(200000*t)
(this assumes i(0)=0 and i'(0)=10000)
If, instead, you apply an AC source, the voltage function (again assuming i(0)=0 but i'(0)=2*10^9) of which being v(t)=10*sin(20000*t), the resulting current function looks like this:
i(t) = (1/20)*e^(-100000*t)*sin(200000*t)+B*sin(200000*t)+A*cos(200000*t).
Explaining why this is so takes about two full pages.
Oh, I forgot to substitute the variables. A=1/85 and B=4/85
I am familiar with Kirchhoff's laws (I guess that's what you are referring to?), and I used them to find my expression.
But I guess I should stop fearing long expressions :smile:
Nah, it's
L*i''(t)+R*i'(t)+1/C*i=V'(0)
where
L=1 milliHenry, R=200 ohm and C=20 nanofahrad.
Applying 10 volt (DC) to this system gets you
0.001*i'' + 200*i' + 5*10^7*i = 0.
Solving this equation:
0.001*y^2 + 200*y + 50000000 = 0
gives you two imaginary numbers,
y1=100000 + j*200000
y2=100000 - j*200000
which means that
i(t) = e^(-100000*t)*( A*sin(200000*t) + B*cos(200000*t) ).
(This is the general solution to the "ordinary differential equation" shown above.)
To find A and B, you need to know some starting conditions. We know i(0)=0 because the loop has "infinite resistance*" when you apply the initial potential.
Knowing that i(0)=0 means you can rewrite, so:
i(0) = e^(0)*(A*sin(0) + B*cos(0))
0 = A*sin(0)+B*cos(0)
0 = B*1
B=0
so you can simplify the initial expression for the current to
i(t) = e^(-100000*t)*A*sin(200000*t)
from elsewhere (and I honestly can't remember) we know that i'(0)=10000, so A can be isolated and determined. I don't want to write out di/dt here because it is a damn long function, but suffice to say, it turns out A = 0.05 so
i(t) = 0.05*sin(200000*t)*e^(-100000*t)
All in all, current determination becomes complicated once you have a lot of loops and capacitors, but not so difficult that you should feel discouraged - there are a lot of shortcuts and neat tools at your disposal if you ever start in on the subject in a serious manner.
*not true
