Solving for Tensions with Different Angles
  • Thread starter Thread starter Paul_Bunyan
    Angles Tension
10 replies · 49K views
Paul_Bunyan
A climber is suspended between two cliffs and is closer to the left cliff. The left part of the rope makes an angle of 65 to the cliff and the right part an angle of 80 to the cliff. The climber weighs 535N.
Trigonometry...
What I did at first was assume that the vertical force on the two sides is equal, then use Trig. to calculate the two tensions, but the answers I got seemed way off...And as I think of it more I think the two Y tensions of the ropes may not be 535/2 as I first thought...So I'm stuck here...
I keep re-reading my book for clarification, but I can't seem to grasp what I must do.
The tensions will not be the same. You must resolve the forces into their x and y components using trig, then sum them up in each direction to get your two equations with two unknowns.
Ahhh, of course! I can't believe I overlooked that...I was thinking too much, thanks.
So, after doing all the algebra and trig, I came up with this...
From the equations for the components:
T1=Left, T2=Right
T1 Sin 65 + T2 Sin 80 = 0
T1 Cos 65 + T2 Cos 80 = 535
Left string's tension = T1 = 2032.654N
Right string's tension = T2 = 1870.629N
Does that look right?
Thanks again.
Don't forget about the force due to the mass of the climber! You must use ALL the forces. That acts in the vertical direction.
Also, in the horizontal direction, the tension in the first rope acts in the opposite direction of the second rope. So you must subtract instead of add.
So, in the vertical part:
Doesn't the 535 take into account the weight of the climber? Since the two vertical upward forces of each rope must add together to equal the single downward force due to the mass of the climber?
Yes, you are right about that. Sorry, I think I misread your earlier post.
As for the horizontal components of the tension, T1 acts to the left, while T2 acts to the right. So when summing up the forces it will be the difference between the two. Does that make sense?
Yeah, I think I get it now, thanks a bunch!
Hmmm, when I work through your equations, I get a different answer. One way to check if your that you didn't make a mistake in your algebra is to put your values back into your original equations, and see if they make sense.
You're right, I went through it kind of fast and had a wayward "-" sign.
After fixing that I got:
T1 = 917.456
T2 = 844.18
Which makes a lot more sense, is that close to what you got?
hi how would you soolve for t1 and t2?
