Solving for the Depth of Release: Pressure on a Ball
  • Thread starter Thread starter BoostAdiction
    Ball Pressure
The discussion focuses on calculating the depth from which a small ball is released underwater, given that it rises 1 meter above the surface after being released. The ball's density is 0.4 times that of water, and the drag force is negligible. Participants emphasize the importance of analyzing the problem through potential energy rather than pressure, highlighting the need to consider buoyancy and gravitational forces to determine the effective acceleration acting on the ball.
  • Understanding of buoyancy and gravitational forces
  • Familiarity with potential energy concepts
  • Basic knowledge of fluid mechanics
  • Ability to apply Newton's second law in fluid contexts
  • Study the principles of buoyancy and Archimedes' principle
  • Learn how to calculate potential energy in fluid environments
  • Explore the effects of density on buoyancy and acceleration
  • Investigate the relationship between pressure and depth in fluids
Students in physics, educators teaching fluid mechanics, and anyone interested in understanding buoyancy and potential energy in underwater scenarios.
BoostAdiction
[SOLVED] Pressure on a ball
Suppose you release a small ball from rest at a depth h below the surface of water. The ball shoots upwards above the surface by 1m. If the density of the ball is .400 that of water and drag force on the ball from water is negligible, at what depth was the ball released?
I'm assuming p(2)=p(1) + dg(y(1)-y(2))
I think I have to find the pressure on the ball in order to start solving this. I also know that the force due to gravity on the ball is less than that of the buoyancy force because the ball shoots upwards. I also know that the pressure increases as h below the water increases
Welcome to PF!
Hi BoostAdiction! Welcome to PF! :smile:
Hint: Try this as a potential energy problem rather than a pressure problem.
What is the potential energy difference between the ball being distance h below the surface and being at the surface? :smile:
If you set the ball below the surface to be 0, then the potential energy is 0. Thus, the ball at the surface has a potential energy equal to mgh. Both m and h are unknown. And thanks for the welcome!
Whoa!
It isn't g, is it?
What is the effective force of gravity (in other words, the actual acceleration) under the water?
For a start, it's up and not down, isn't it?
Try again! :smile:
So it has an acceleration in the positive direction. I understand that much, then its all a lil fuzzy
Hi BoostAdiction! :smile:
Normally, I'd recommend looking at wikipedia … but I've just checked the page on Buoyancy, and it looks terribly long and confusing! :redface:
So let's ignore wikipedia … what are the forces on the ball, in terms of volume, density of ball, and density of water?
So what is the overall force?
And then what is the acceleration? :smile:
haha, good ole' wiki. there's a force due to gravity pushing down on it, and one pushin up (buoyancy force) and I think the net upward force is that buoyancy force...
Yeeees … but how much is it?! :smile:
Well the acceleration has to be greater than 9.8 to have an upwards effect on the ball...So would i take .4 x 9.8 to get the force due to gravity?
erm … would you take 1 x 9.8 if it had the same density as water? :redface:
Or 5 x 9.8 if it was 5 times as dense?
Either do the equations …
… or make a good guess! :biggrin:
  • · Replies 31 ·
