Solving for Vc, Vb, Ve, Ib, Ic and Ie
  • Thread starter eehelp150
    Ib Ic
eehelp150
Find Vc, Vb, Ve, Ib, Ic, and Ie
Vbe is 0.7V
Circuit schematic of an NPN bipolar transistor biased by a 50k resistor from +10 V and a 30k resistor to ground, with a 1k collector resistor, a 1k emitter resistor to ground, and beta = 150 labelled.
KVL
Vb = (10*30k)/(80k) = 3.75V
Ve = Vb-Vbe = 3.05V
Ie = Ve/Re = 0.305A
Icmax = 10/(1010) = 9.9mA
Ie is much greater than 9.9mA, so this circuit is saturated. Is this correct?
  • Circuit schematic of a bipolar transistor biased with a 50k resistor from +10 V to the base, a 30k resistor from base to ground, a 1k collector resistor, a 1 ohm emitter resistor to ground, and beta = 150.
This is true iff the base current is zero or negligible.
It is better to apply Thévenin and say VB = 3.75 – IB×30k||50k
Q still turns out to be saturated, yes.
1. Substitute labels for the resistors, like R1, R2 etc. Substitute actual values only at the end.
2. Write Σi = 0 at the base and emitter junctions. Let Ve = Vb - 0.75V. Gives you 4 independent equations in 4 unknowns.
3. Assume no saturation and solve for ib, Vb, Ve and Vc. If Vc turns out to be < Ve your equations were invalid and you have saturation.
