Solving Force Problem: Finding Velocity and Force Requirements
  • Thread starter Thread starter the_d
    Force
To determine the force needed to achieve a velocity of 30 ft/s after moving 20 ft from rest, the work done by the force must equal the change in kinetic energy. The equation W = KE can be used, but it is crucial to account for the coefficient of kinetic friction, which is 0.20 in this case. The frictional force must be included in the total force calculation acting on the object. Understanding these relationships is key to solving the problem effectively. Properly incorporating friction will ensure accurate force requirements are determined.
the_d
My problem is to find the force needed to give the system of bodies a velocity of 30 ft/s after moving 20 ft. from rest.
Can anyone help me with this? All i have done is found EFx and EFy for the 50lb weight
Didn't you post this question earlier? (Or was it someone else with the same question?) As said, use the fact that the work done by that force on the distance of 20 ft equals the change of kinetic energy.
is there an equation for that??
If you know the definition of work, and the definition of kinetic energy, you should be able to write down this equation yourself.
so W = KE, where does the coeffeficient of kinetic friction play in all this??
You didn't mention any kinetic friction coefficient.
sorry, the kinetic friction is 0.20...
does that play a role??
Yes, it does, because you have to include the force of friction into your sum of forces acting on the object.
ok, i got ya
