Solving Friction Questions: Find Distance & Slope of Inclined Plane
  • Thread starter Thread starter SheldonG
    Friction
The discussion centers on the physics problem involving a block sliding down an inclined plane with a slope angle θ and its subsequent motion when projected upwards with an initial speed v₀. The distance traveled up the incline before coming to rest is calculated as v₀²/(4g sin θ). The participants clarify that the coefficient of kinetic friction (μₖ) equals tan θ, and upon stopping, the block will slide back down due to the relationship between static (μₛ) and kinetic friction, where μₛ must be greater than μₖ. The consensus is that the block will slide back down the incline after coming to rest.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of friction coefficients (static and kinetic)
  • Familiarity with inclined plane dynamics
  • Basic trigonometry (sine and tangent functions)
  • Study the relationship between static and kinetic friction coefficients in detail
  • Learn about the dynamics of objects on inclined planes
  • Explore the concept of forces acting on objects in motion
  • Review the derivation of motion equations for inclined planes
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators seeking to clarify concepts related to friction and motion on inclined planes.
SheldonG
A block slides with constant velocity down an inclined plane with slope angle \theta. The block is then projected up the same plane with an initial speed v_o. How far up the plane will it move before coming to rest, and after coming to rest, will it slide down the plane again?
F = ma.
f = \mu mg
The block will travel a distance of v^2_0/(4g\sin\theta). But the second part of this problem is not clear to me. I am inclined to say there isn't enough information to answer this, but if pressed, I would say that it would probably slide back down. I would say this because the coefficient of kinetic friction in this problem is \tan\theta. If the box would not move, then it would seem that \mu_s = \mu_k, which contradicts the usual situation where \mu_s > \mu_k. The book answer is no.
I would appreciate any insights offered.
Thank you,
Sheldon
I can see no reason for that. Since the kinetic friction exactly cancels gravity and static friction will be bigger.
If the box isn't moving then there is no kinetic friction, only static friction. What is of vital importance is the following information,
SheldonG said:
A block slides with constant velocity down an inclined plane.
Which means, as you correctly say, that:
\mu_k = \tan\theta
Now once the box has stopped, there are only two forces acting parallel to the incline: static friction and a component of the block's weight. We know that the maximum static frictional force is given by,
f_s = \mu_sN
And as you correctly say we know that \mu_s>\mu_k, which means,
\mu_s > \tan\theta
Now let's multiply both sides by mg\cos\theta (i.e. the component of the block's weight normal to the incline),
\mu_smg\cos\theta > mg\sin\theta
Notice that the LHS is the maximum static frictional force and the RHS is the component of the block's weight acting parallel to the incline.
Does that help?
\mu_k = \tan\theta
f_s = \mu_sN
\mu_s > \tan\theta
Does that help?
I'm still a bit confused, unless we are both saying the same thing in a different way. Since the block travels at constant velocity down the incline, we have
m(0) = mg\sin\theta - \mu_k mg\cos\theta
which leads to
\mu_k = \tan\theta
If the block stops and does not slide back down:
0 = mg\sin\theta - \mu_s mg\cos\theta
which gives
\mu_k = \mu_s = \tan\theta
Unless I have mucked up my force equations (very possible), then the correct answer to the question is not "the block will not slide" as the textbook states, but the block will slide, since we need \mu_k > \tan\theta so a smaller angle would be required to keep the block from sliding back.
Or perhaps, "not enough information" to decide would be the right answer.
Where am I going astray here?
Why assume this? The problem doesn't say what happened prior to the constant velocity of the block down the incline. Perhaps the block was placed on the incline, wouldn't move, and then someone gave it a push. On the other hand, perhaps the block was placed on the incline, wouldn't move, and someone increased the angle until it slid at constant v down the incline. In this second case, if you projected the block up the incline again, it should eventually slide back.
I don't see any way from the information given in the problem to conclude that the block must stop. If you actually calculate the coefficients from the information in the problem, you end up with the same value for both of them, unless I made a mistake (which I admit is very possible).
That's where the error is.
\mu _sN is not the force of static friction, it is the maximum force of static friction.
i.e., F_{stat} \leq \mu_sN
which leads to
\mu_k = \tan\theta
OK. Now you know \mu_k--what can you immediately deduce about \mu_s?
which gives
What it tells you is that the minimum value of \mu_s to prevent sliding is equal to what you just found for \mu_k. Is that criterion met?
You've got all the info you need to answer the question, but you also need to know a basic fact about how maximum static friction compares to kinetic friction.
I understand now, thank you so much. I see my mistake now. I was thinking of the situation where the incline was increased to overcome the static friction and cause the block to slide at constant velocity. But after further calculation, I see that this is an impossibility, such an angle does not exist. Any increase in the angle great enough to overcome static friction would cause the block to accelerate. You would have to lower the angle during the slide to get constant velocity, which would of course cause static friction to hold it still when it stopped.
You have all been very patient and so helpful. Thank you very much.
  • · Replies 33 ·
