Solving Inequalities in Interval Notation: Where Did I Go Wrong?
  • Thread starter Thread starter aeroengphys
    Stupid
The discussion revolves around solving the inequality 5 < 2x - 1 ≤ 15 using interval notation. The original approach involved creating four cases, leading to an incorrect final answer of [-7, -2) ∪ (3, 8). Upon reevaluation, the correct method simplifies to solving 3 < x ≤ 8, which is confirmed as the accurate solution. The confusion may stem from mixing this problem with absolute value inequalities, which require different handling. Ultimately, the simplest solution method is preferred for clarity and efficiency.
aeroengphys
In interval notation, I was asked to solve for 5 < 2x - 1 ≤ 15
I did this by making the 4 cases...
2x-1>5 or 2x-1<-5 AND 2x-1≤ 15 and 2x-1≥-15
x > 3 or x < -2 AND x ≤ 8 and x ≥ -7
So for my final answer...i got [-7,-2),(3,8]
But when i check it, none of the numbers between -7 and -2 check...what'd I do wrong?
Lastly, is the answer actually just (3,8]?
What's the use in checking if 2x-1<-5 and 2x-1>= -15?
honestly...I have no idea, but we were taught to make four cases for those...so that's how I've been doing it ever since.
Actually, I just realized that I could've solved for x by adding 1 to the left and right, and dividing by 2 to the left and right...which gives me an answer of 3 < x ≤ 8...i'm pretty sure that's right...guess i went about it the wrong way
Yup, that's probably the easiest way.
You're probably confusing it with a problem like:
2 &lt; |2x - 1| \le 15
where the absolute value sign creates a problem.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
