Solving Initial Value Problem: 1st Order Dif Eq Help with 2 Variables
  • Thread starter Thread starter footballxpaul
6 replies · 7K views
footballxpaul
(2x-y)dx+(2y-x)dy=0 y(1)=3
solve the given initial value problem and determine at least approx where the solution is valid?
this should be simple right? I got 2y+2x=C and then 2y+2x=8. It doesn't match the answer in the back of the book at all, and I do see how they could have gotten the answer in the back. Is my answer right? The book says y=[x+sqrt(28-3x^2)]/2, abs(x)<sqrt(28/3)? or is the book right, and if so how do you get to their answer?
The book is right, this is an exact differential equation. You can tell this since the partial derivative of the term multiplied by dx, namely (2x-y), with respect to y is equal to the partial derivative of the term multiplied by dy, or (2y - x), with respect to x (since both partials are -1).
Check out http://www.sosmath.com/diffeq/first/exact/exact.html. Follow the method step by step and that will lead you straight to the solution.
thanks I got to x^2-yx+y^2=7 now. I have no clue how to separate this right now, is there a trick, did I do something wrong.
No you basically got this. To complete the problem, subtract 7 from both sides and view the equation as a quadratic in y (treating other quantities as constants) and apply the quadratic formula.
And how did you solve this
(2x-y)dx+(2y-x)dy=0
But, generally speaking, it is not necessary to "solve" the equation for y. [itex]x^2- xy+ y^2=7[/itex] is a perfectly good solution.
solved, thanks guys, can't believe I couldn't see those
