Solving LaTeX \nmid Problems with Packages
  • Context: LaTeX
  • Thread starter Thread starter JasonRox
    Latex
4 replies · 3K views
Homework Helper
I'm trying to make the following command work:
\nmid
It doesn't work at all. I found other old threads over the net about people also having the same problem, but no response to those thread! Hopefully this one gets a response.
The following packages are in use...
\usepackage{latexsym}
\usepackage{amsfonts}
\usepackage{amsthm}
\usepackage{amsmath}
Does not work.
Works for me, but check this out. It DOESN'T show the correct symbol in the preview plane (I'm using LeD) but when i build the pdf it works correctly. Are you looking at the pdf?
Try to add \usepackage{amssymb}.
ah yes, i was also using the assymb sty. Again though, make sure you're actually looking at the final product. For some reason most DVI previewers use a different set of fonts than the ones used in the compiler and loaded by the document.
Thanks guys, that's the correct package!
