Solving logarithmic and exponential equations
8 replies · 4K views
Mootjeuh
I'm trying to solve trying logarithmic and exponential equations but for the life of me I can't seem to figure out what I'm doing wrong.
Log equation: log3(x+2)+1 = log3x²+4x
Exp equation: 2x + 2x+1 = 3
For the first one, here's what I did:
  • 1 = log3(x²+4x) - log3(x+2)
  • log3((x²+4x)/(x+2)) = 1
  • log3((x² +4x)/(x+2)) = 1
  • log3((x+4x)/2) = 1 --Can I do this? Dividing the denominator and numerator by the same value within a log
  • log3(x+2x) = 1
  • log3(3x) = 1
  • log33 + log3x = 1
  • 1 + log3x = 1
  • log3x = 0
  • x = 1
And then for the second one:
  • 2x + 2x+1 = 3
  • I figured I'd put them all on the same base so I tried to find 2 to what power equals 3
  • So I did ln(3)/ln(2) = 1.584962501, which for simplicity's sake I'll replace by y here
  • And when I put in 2y in my calculator it does give me 3 so it must be correct
  • x + x + 1 = y
  • 2x + 1 = y
  • x = (y-1)/2
But when I put the result back in the original equations, none of the answers I found seem to be correct.
I'm at my wit's end here, I don't know what else to try.
Any help is greatly appreciated.
For the log expression on the right side, do you mean log3(x2 + 4x)? That seems to be what you're doing in your work below.
  • I have no idea what you did. How did you go from (x2 + 4x)/(x + 2) to (x + 4x)/2? That's not a valid step.
    Mootjeuh said:
    [*]log3(x+2x) = 1
    [*]log3(3x) = 1
    [*]log33 + log3x = 1
    [*]1 + log3x = 1
    [*]log3x = 0
    [*]x = 1
  • 2x + 2x+1 = 3
  • Where did this (above) come from?
    Mootjeuh said:
    [*]And when I put in 2y in my calculator it does give me 3 so it must be correct
    [*]x + x + 1 = y
    [*]2x + 1 = y
    [*]x = (y-1)/2
That should be written: log3(x+2)+1 = log3(x²+4x)
Parentheses are important!
  • OK so far.
    [*]log3((x+4x)/2) = 1 --Can I do this? Dividing the denominator and numerator by the same value within a log
    You can divide a rational expression within a log argument. But your algebra is totally wrong here, because ##\frac{x^2+4x}{x+2} \neq \frac{x+4x}{2}##. Please review your algebra.
    Instead of this, I would just take antilogs of both sides to get:
    ##\frac{x^2+4x}{x+2} = 3##
    and solve that quadratic. Be careful about which solution(s) is/are admissible.
    • 2x + 2x+1 = 3
    • Doesn't help because ##a^x + a^y = a^z## does NOT imply that ##x + y = z##. In fact, there's no "easy" relationship between x, y and z here.
      To solve, observe that ##2^{x+1} = 2.2^x## (the dot signifies multiplication). Now put ##2^x = y## to get a simple linear equation.
Thanks, I didn't think of using an antilog, solved it smoothly.
I kind of don't follow what happened here, where did 2x go?
It's still there.
2x + 1 = 2 * 2x
Yeah but I mean the original formula was 2x + 2x+1 = 3, you moved it to the other side of the equals sign and it became 2 times 2x. Why not 3-2x?
I'm sure it's obvious and I completely missed it but it's 1am here and trying to finish this before going to sleep
Because doing that won't help you. If you subtract 2x from both sides, you get
2x + 1 = 3 - 2x
This isn't wrong, but it's not helpful, either, in getting you closer to a solution.
This is what you need to do:
2x + 2x+1 = 3
==>2x + 2*2x = 3
==> 2x(1 + 2) = 3
==>2x * 3 = 3
==>2x = 1
Now you can solve for x.
Aaaah right 2x+1 = 2*2x is the same as 21*2x which makes the rest distributable now
Great thanks I can finally go catch some Zs now, you've been a real help!
