How Is Displacement Current Calculated in a Parallel Plate Capacitor?
  • Thread starter Thread starter PenTrik
    Maxwell's equation
The calculation of Maxwell's displacement current (ID) in a parallel plate capacitor is based on the sinusoidal voltage V(t) = Vosin(ωt), where Vo = 10 V and frequency f = 100 Hz. The displacement current can be determined using the equation ID = ε0(dΦ/dt), where ε0 represents the permittivity of free space. The electric field between the plates can be calculated from the total charge and the area of the plates, allowing for the differentiation of electric flux over time to find ID. This approach resolves discrepancies in Ampere's law by accounting for the displacement current in scenarios where traditional current does not flow.
  • Understanding of sinusoidal voltage functions
  • Familiarity with Maxwell's equations
  • Knowledge of electric flux and its calculation
  • Basic principles of Ampere's law
  • Study the derivation of Maxwell's equations in detail
  • Learn how to calculate electric flux in capacitors
  • Explore the implications of displacement current in electromagnetic theory
  • Investigate applications of displacement current in real-world circuits
Students of electromagnetism, electrical engineers, and anyone interested in the theoretical foundations of capacitors and displacement currents.
PenTrik
A sinusoidally-varying voltage V(t) = Vosinωt with amplitude Vo = 10 V and frequency of f = ω/(2π) = 100 Hz is impressed across the plates of a circular-shaped parallel plate air-gap capacitor of radius a = 1.0 cm and plate separation d= 0.01 mm. The amplitude of Maxwell's displacement current ID flowing across the gap between the plates of this capacitor is:
From what I know, the one equation that we have is
I_d=e_0\frac{d\Phi}{dt}
Of course, I'm trying to solve for I_d here
I don't really have much of an attempt here. Sort of lost on how to do it.
It's good to think back to the reason that displacement currents are needed in the first place. See here: http://en.wikipedia.org/wiki/Displacement_current#To_obtain_the_correct_magnetic_field
Ampere's law states that the integral of B*dl across a closed curve is equal to the current through any surface that you can draw around the curve. As the second diagram in that Wikipedia article's section shows, you can draw two different surfaces, one that the wire passes through and one that no current passes through whatsoever. Displacement current is needed to explain this discrepancy, so displacement current must be exactly equal to the current in the wires (or else the discrepancy would remain).
Another way to calculate displacement current would be to use your equation. You can easily calculate the electric field between between the plates as a function of the total charge on the plate and you know the plates' area, so you can calculate electric flux. Differentiating with respect to time would give you d(phi)/dt.
  • · Replies 28 ·
9K
