Solving Mechanics Basics CW Homework: F and Theta
  • Thread starter Thread starter Jintachi
    Basics Mechanics
The discussion revolves around a mechanics problem involving forces and angles. The original poster seeks to determine the magnitude of a force F and its direction (theta) given a resultant force of 750N along the positive x-axis. The problem involves breaking down forces into their components.
  • Participants discuss the calculation of force components using trigonometric functions and question the definitions and assumptions related to angles and components. There is confusion regarding the angle derived from a triangle associated with a force vector.
Participants are actively engaging with the problem, clarifying definitions and exploring the relationships between force components. Some guidance has been provided regarding the addition of components to find resultant forces, but there remains uncertainty about the next steps after calculating the resultants.
There is a request for more information about the problem setup, including any diagrams that may accompany the question. The original poster's understanding of the tangent function and its application in this context is also under scrutiny.
Jintachi
The question in short: If the resultant force acting on the bracket is 750N along the x positive axis, what is the magnitude of F and the direction (theta)
I have tried for several hours now trying to get this done. I have made a table for the components, Fx and Fy.
Fx
325cos(22.61) = 300.0215
600cos(40) = 459.62
Fy
325sin(22.61)=124.9483
-600sin(40) = -385.67
Rx = 759.6415
Ry = -260.6857
But I don't know where to go from there. In all honesty I really don't have much idea on what to do.
Please help me out. Thanks for your time for reading this!
Is 325N making an angle 22.61 degrees with the horizontal?
Oops. forgot to mention, I got 22.61degrees from the triangle on the 325N vector.
I got it by doing:
tan-1(5/12) = 22.6198
I got it by doing:
I do not understand . What is 5 and 12 ?
I got it by doing:
You need to review the definition of the tangent.
How would you guys start this? I'm sorry to ask this but I'm fairly clueless. I'm pretty sure what I've said to the above post makes no sense
You need to write the complete question .It is not clear from the OP what are the given parameters .Please state clearly what is given in the question and if any picture is given in the question then attach the image .
Can you see the image?
Okay...
tan-1(5/12) is the angle which 325N force makes with the vertical not horizontal .
If a force P makes an angle θ with the horizontal then what are its components in x and y directions ?
Tanya Sharma said:
Okay...
Pcosθ for x component, and sin for y?
Yes...horizontal component is Pcosθ and vertical component is Psinθ.
If there are two forces P and R making angles θ and α respectively with the x axis,then the components of the resultant force ,T, in x and y direction (i.e Tx and Ty) will be
Tx = Pcosθ+Rcosα
Ty = Psinθ+Rsinα
i.e we algebraically add the x components to get the x-component of the resultant force .Similarly we do for y-components.
Does this make sense ?
Tx = Pcosθ+Rcosα
Ty = Psinθ+Rsinα
The only part which makes sense is where I have to add the x and y components to get the resultant of x and y. Where do I go from after I have the resultants?
This does tell you about the component of the resultant force in x and y direction . What do you infer ?
  • · Replies 21 ·
