Solving Physics on Own: Horizontal Force for Blocks
The discussion revolves around a physics problem involving horizontal forces acting on blocks, specifically a large block of mass M and two smaller blocks M1 and M2. The scenario assumes frictionless surfaces and a pulley, with the goal of determining the necessary horizontal force to keep the blocks stationary relative to each other.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster questions the reasoning behind the total mass used in the force calculation, specifically why the force F must account for all three masses (M, M1, and M2) when M2 is influenced by gravity. Other participants explore Newton's second law and the implications of tension in the system.
Participants are actively engaging in clarifying the application of Newton's second law and discussing the roles of tension and acceleration in the system. Some have acknowledged misunderstandings and are reconsidering their initial thoughts based on the responses received.
There is a mention of assumptions regarding the connection between M1 and M2, as well as the effects of gravity on M2. The discussion also reflects on the implications of different setups, such as M1 resting on the floor versus being connected to M2.
Joran Verlaeck
Dear Forum Users,
I am studying physics on my own, i am new to this forum, i am working every example in the book and i have a question. I hope that you are so kind to give me an explanation so that i can continue my chapter exercises.
The question of the book is : What horizontal force must be applied to a large block of mass M shown in Figure P5.67 so that the tan blocks remain stationary relative to M ? Assume all surfaces and the pulley are frictionless. (Notice that the force exerted by the string accelerates M1)
See attachement for picture.
The calculation goes as follows.
M1*g - T = 0 =>
T = M2 * a =>
M1*g = M2 * a => a = (M1*g)/(M2)
F = TotalMass * a => in the book and on the internet the result is
F = (M + M1 + M2) * (M1*g) / (M2)
What i was wondering is if M1 is not connected by the string with M2, and the surface is frictionless, normally only block M would slide together with M1 and M2 would remain stationary and eventually fall off. The tension in the robe is provided by the gravitational force, no gravity
no tension. So in the end result F only needs to accelerate M and M1 and not M2 because that
is accelerated by gravity -> equation a = M1 * G / M2.
So why is the result (M + M1 + M2) * (M1*g) / (M2) and not (M + M1) * (M1*g) / (M2).
Because F is not responsible to give M2 that acceleration just for keeping M relative to M2 in rest.
So they both need the same acceleration.
Can you please help me with this reasoning.
Thx
Jöran
Welcome to PF!
Hi Jöran! Welcome to PF! :smile:
I see what you mean.
But no, for two reasons:
i] suppose the three masses were fixed to each other …
the result would be the same, wouldn't it? :wink:
ii] this is an exercise in applying Newton's second law …
you must always apply it to all the external forces on a particular body (or bodies)
if you apply it to M and M1 combined, then you must include the external force (on M and M1) from the horizontal part of the rope …
(M + M1)a = F - T = F - M2a,
ie (M + M1 + M2)a = F :smile:
Dear Forum Users,
M1*g - T = 0 =>
T = M2 * a =>
Thx
Jöran
Hello Joran Verlaeck. Welcome to PF !If m1 and m2 are stationary relative M, then they all have the same acceleration, call it a .
So the net force, F, on the system must be such that F = (m1 + m2 + M)a . It's simply the application of Newton's 2ND Law of Motion.
in the end result F only needs to accelerate M and M1 and not M2 because that is accelerated by gravity -> equation a = M1 * G / M2.
T = m1g = m2a. At the pulley, the string exerts a force T vertically and horizontally on M. The horizontal forces on M are therefore F, m1a from contact with m1 and m2a from the pulley.
All of you guys,
Thanks for presenting me the reasoning why this is the case.
After i read the responses i released that i made a mistake by following my reasoning.
I was thinking of the same physics situation only this time m1 rests on the floor, the outcome is like tiny-tim suggested the same. If so M1 feel the normal force and in reality there is really no tension in the robe, but once the object starts moving, and we want to make sure that M2 has no velocity relative to M, the tension in the robe gets m2.a and if a is exactly m1*g/m2 the normal force on m1 is zero. In this case you can see that F must be responsible to the motion of M2 and all the equations remains the same.
Thanks for answering this topic.
  • · Replies 17 ·
  • · Replies 102 ·
9K
  • · Replies 18 ·
  • · Replies 19 ·
