Solving Pulley and Platform Homework w/ Acceleration
  • Thread starter Thread starter judas_priest
    Platform Pulley
35 replies · 11K views
judas_priest
Two construction workers each of mass m raise themselves on a hanging platform using pulleys as shown above. If the platform has a mass of 0.5m, the initial distance between the pulleys and the platform is d, and the workers each pull with a force f on the ropes, what is the acceleration a of the workers? Assume the pulleys and ropes are massless.
Forces on one Man:
FME (weight of the man),
The normal force NMP (contact of the man with the platform),
The tension force FMR (the response force that the rope applies to the man).
The force applied by 2 men pointing down
For the platform:
FPE (weight of the platform),
NPM (force on the platform due to the man, it is the pair of NMP) and remember you have two of this because you have 2 men,
T and T: The two tensions acting on the platform due to the ropes
I would consider men+platform as one system. This reduces the number of forces involved.
What did you do after listing all those forces?
Eliminated Normal force. What answer do you get? I tried doing it by considering them as a one system too. Still stuck.
Considering them as one system:
2N downwards
2N upwards
2mg + .5 mg downwards
2f downwards (force applied by men)
2f upwards. (The tension in the strings attached to the platform)
2t upwards. (the tension in the strings held by men)
Where am I going wrong?
They do not apply a downwards force on the pulley/men system.
Where is the difference between f and t?
The other forces look good.
But the question says they pull down with a force f. What are the correct forces?
also, is there a difference between f and t in this case?
They pull the rope down, and themself up.
That was my question to you. Can the rope tension be different at both sides?
Okay, so tension and force are the same in this case. Can you please list out all the forces?
For the two men combined:
[tex]2N - 2F - 2Mg = 2Ma[/tex]
For the platform
[tex]2f -.5Mg - 2N = .5Ma[/tex]
Is that right?
Is that right?
Why the minus sign in -2F here?
Because they're pulling it down.
Here's another way I did it in:
Forces on 2 men
tension upwards
normal upwards
weight downwards
Forces on platform:
normal downwards
weight downwards
I've ignored the forces applied by the two men to pull the string down, because they get balanced by the forces on platform pointing up
F points upwards for the men, as I mentioned before. They are pulling the rope down, so they are pulling themself up.
Apart from that, post 9 is right.
That does not work.
But aren't they trying to pull it down? How would it point upwards?
And F gets balanced by the force on platform. Don't they?
That does not work.
Why not? They are reaction forces after all? How does F point upwards for men when they're applying force downwards.
Also, Isn't tension upwards?
[tex]2N + 2F - 2Mg = 2Ma[/tex]
[tex]2F -.5Mg - 2N = .5Ma[/tex]
Solving them, this is what I get:
[tex]4F - 25m = 2.5Ma[/tex]
Is that correct?
Did you ever try to push a rope? Did it work?
You can only pull it, and get a positive tension in it.
They are "trying" to pull at the anchor on the top of the building. As this anchor feels a force downwards, they feel a force upwards (action/reaction).
Exactly, tension pulls them upwards.
Is that correct?
If you add the missing decimal point, yes.
I'm confused. If I'm pulling the rope, am I not applying the force downwards? Of course, it's upwards on the platform. And isn't the equation incomplete without tension?
Also, I did add the decimal points.
I got the answer, but can someone explain to me the working of this problem? I haven't understood it.
I just got the answer by blindly following the posts
I think judas_priest has substituted g = 10.
Yes, downwards on the rope, so the rope is applying the same force upwards on you.
The quick way to solve this problem is to consider the forces pulling upwards the pulleys. What do these add up to?
Okay, got it. Thanks a lot!
im trying to figure this out but I am really confused where did the 2N come from?
As in post #10? N is the normal force from the platform on each man. Total = 2N.
ohh okay ! thank you ! I thought it was that but I got confused because on a later post it was said there is no normal force
My problem :Two construction workers each of mass m raise themselves on a hanging platform using pulleys as shown above. If the platform has a mass of 5m and the workers each pull with a force f on the ropes, what is the acceleration a of the workers? Assume the pulleys and ropes are massless.
so would the forces be
2N up
2N down
7mg down
4f up
and you would add all of them up and equal to mass*acceleration (ma)?
2N up
2N down
7mg down
4f up
Yes, if the m in the last line represents the total mass, not the given m.
so the equation would be 2N-2N+2f+2f+7mg=7mga
to find acceleration it would be (4f+7mg)/7mg= a ?
it marked it wrong. I am soo confused! what am I doing wrong?
7mga? That's multiplying two accelerations together.
but I thought that since both men have a mass of m and the platforms mass is 5m the total mass would be 7m
so would the formula just be 2N-2N+2f+2f+7mga = 7ma ??
I got it ! the answer is (4f-7mg) / 7m
