Solving SIR Model with Euler's Method
7 replies · 4K views · last reply
tomc612
Question on SIR Model and using Eulers method for approximating a solution.
Given the 3 ODEs of the SIR model
dS/dt = -\betaSI
dI/dt= -\betaSI - \gammaI
dR/dt = \gammaI
Ive been asked to produce in excel Eulers method for axproximate solutions. Given some initial values for S(0) and I(0) as well values for the constants for \beta and \gamma, and increments of time (t)
What I would like to know, is do I need to use Matrix/Linear Algebra to produce a generic solution for the system of equations? is this then used with Eulers method?
If not how do I use Eulers method when the equations have a product if S and I
See below for the actual questionImplement Euler's method in MS Excel or MATLAB to produce approximate solutions
for the system of di erential equations of the SIR model. Use initial conditions of S(0) =
S0 = 249995=250000 and I(0) = I0 = 5=250000, with = 2 and
= 0:5. Use a time
step of 0.25 to ensure the graphs display a smooth curve. Iterate Euler's method for the
duration of the epidemic (halt the simulation when In approaches zero). Plot S; I and R
against time.
any help appreciated
dS/dt = -\betaSI
dR/dt = \gammaI
= 0:5. Use a time
against time.
Hi tomc612,
Euler's method is to approximate an equation of the form:
$$\mathbf y'(t) = \mathbf f(t, \mathbf y(t))$$
with the algorithm:
$$\mathbf y_{n+1} = \mathbf y_n + h \mathbf f(t_n, \mathbf y_n)$$
where $t_n = t_0 + nh$, and $h$ is the step size.
In your case we have:
$$\mathbf y(t) = \begin{pmatrix}S(t)\\I(t)\\R(t)\end{pmatrix}
so
$$\mathbf y'(t) = \mathbf f(t, \mathbf y(t)) = \begin{pmatrix}-\beta S(t)I(t)\\-\beta S(t)I(t) - \gamma I(t) \\ -\gamma I(t)\end{pmatrix}
In this case Euler's method is:
\begin{cases}
S_{n+1} = S_n + h \cdot -\beta S_n I_n \\
I_{n+1} = I_n + h \cdot (-\beta S_n I_n - \gamma I_n) \\
R_{n+1} = R_n + h \cdot -\gamma I_n
\end{cases}
When we fill in the initial conditions, and perhaps some arbitrary values for $\beta$ and $\gamma$, then we can calculate a number of iterations. (Thinking)
Hi,
thanks for the info.
To input values to the formulas.. with the example of S..
S(0)= {S}_{0} = 3
I(0) = I{S}_{0}= 5
h= 0.5
\beta=1
\gamma=2
Sn+1 = Sn +(h.-\betaSnIn)
Sn+1 = 3 +(0.5.-1.3.5)
Sn+1 = -4.5
Is that right? Thanks
Yep, although it should be $S_1=-4.5$.
And we have:
$$t_{n+1} = t_0 + n\cdot h \\
t_1 = 0 + 1\cdot 0.5 = 0.5$$
Thanks..
So to graph that function, you would then input the {S}_{1} result back into the formula. How do we produce the result when the formula requires the subsequent I value? Or does n value for I remain at a constant?
Thanks
tomc612 said:
Thanks..
Thanks
Similar to calculating $S_1$, we should calculate $I_1$ and $R_1$.
After that we can use them to calculate $S_2$.
And that's calculated by using the {I}_{n+1} formula with to obtain that result?
and then the results for S and I are inputted to each of the formulas sequentially? And then the same for the R formula?
Exactly! (Nod)
