Solving Stress in Bicycle Chain for NDO
The discussion revolves around calculating the stress in the pin and the link of a bicycle chain, as part of a homework problem related to mechanics. Participants are exploring the necessary equations and approaches to solve the problem.
  • Homework-related
  • One participant requests help on how to start solving the problem, indicating uncertainty about the approach.
  • Another participant suggests finding an expression for the tension force in the chain based on the crank length, sprocket radius, and pedal load.
  • There is a discussion about determining the cross-sectional area of the pin and the link, with questions about whether to consider the width between the links or the area around the pin hole.
Participants have not reached a consensus on the best approach to calculate the cross-sectional area or the tension force, indicating that multiple views and uncertainties remain in the discussion.
Participants have not provided specific definitions for terms like "narrowest point" or clarified assumptions regarding the geometry of the chain components, which may affect the calculations.
NDO
See attachment for the problem. or visit the link http://i908.photobucket.com/albums/ac286/NDO_02/Capture.jpg
Basically calculate the stress in the pin and the link in a bicycle chain.
the average shearing stress = P/A = F/A
i think the chain is made of 2 shearing stresses
F.S = ultimate stress/ allowable stress
Can someone help. I have no idea where to start. can someone give me a pointer
cheers NDO
Your attachment is not yet approved but it looks like one of your class mates has reposted the exact same question here : https://www.physicsforums.com/showthread.php?t=347571
Perhaps a moderator should merge these two threads.
You should both start by :
1. Finding an expression for the tension force in the chain as a function of the crank length, sprocket radius and pedal load.
2. Find the cross sectional area of both the pin and the link at it's overall narrowest point (make sure you include the pin hole when finding the narrowest point).
Do the above and the problem should be fairly straight forward.
BTW. What grade/subject course work is this?
first year uni
mechanics
with the cross sectional area of the link
do u just calculate it using the width between the links which is the narrowest part or should i use the area around the hole for the pin or should i treat it as a composite shape
cheers
NDO
30K
9K
  • · Replies 16 ·
  • Sticky
506K
