Solving Substitution Process Homework Questions
The discussion revolves around finding antiderivatives using substitution methods in calculus. Participants are addressing two specific integrals involving polynomial and radical expressions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of u-substitution for both integrals, with some suggesting partial fractions for the first integral. There are attempts to clarify the substitution process and its implications on the integrals.
The discussion is active, with participants providing guidance on substitution techniques and checking each other's work. There are multiple interpretations being explored, particularly regarding the first integral, and some participants express confusion about the steps involved.
Some participants express uncertainty about their substitutions and the resulting integrals, indicating a need for further clarification on the integration process. There are references to confirming answers through differentiation, and participants are encouraged to show their work for better understanding.
rayray19
1) antiderivative of ((t^2)+2)/((t^3)+6t+3) dt
2) antiderivative of r(sqrt((r^2)+2))dr
help please with these
#2 let u = r^2 + 2
du/dr = 2r
du = 2rdr?? i don't knoww!
[tex]\int\frac{t^2 +2}{t^3 +6t +3}dt[/tex]
[tex]\int r\sqrt{r^2+2}dr[/tex]
correct?
yes, that is correct
For the first one, try partial fractions (probably).
For the second, your substitution seems promising. You will have the integral [tex]\int r u^{1/2}\frac{du}{2r}=\int \frac{1}{2}u^{1/2}du[/tex]
well for both, all you do is a u-substitution
1) u-sub of your denominator
2) u-sub of your radican, which you already did
so let's work 2
[tex]u=r^2 +2[/tex]
[tex]du=2rdr \rightarrow \frac{1}{2}du=rdr[/tex]
Rearranging your integral, do you notice that your derivative shows up in your original integrand? by that happening, you can take it out of your integral.
[tex]\int\sqrt{r^2 +1} rdr[/tex]
[tex]\frac{1}{2}\int\sqrt{u}du[/tex]
for my answer to #2 i got (1/3)((r^2)+2)^(3/2) + cis that correct??
is that correct??
correct, now your first one works out the same way, all you have to do is factor our a common term from the derivative of your u-sub.
i factored out a 3 but now I am lost at finishing it up
i got 3 times the antiderivative of du/u dt.. i don't think that's right though
[tex]u=t^3 +6t +3[/tex]
[tex]du=3(t^2 + 1)dt \rightarrow \frac{1}{3}du=(t^2 +1)dt[/tex]
just replace what you have with your u-sub and derivative of your u-sub.
What you have to do is, divide by that 3 so that it becomes the constant for your substituted Integral.
im sorry I am stuck, what do i do after i find the du=3((t^2) +2)) dt
so is the answer (1/3)((t^2)+2) +c ?
Unfortunately, no. Have you learned about the Integral of Ln? (Natural Log)
yea it becomes 1/x doesn't iit
correct, so when we complete all our substitutions, we end up with:
[tex]\frac{1}{3}\int\frac{1}{u}du[/tex]
so now take the Integral of that and just resubstitute.
i think i have it,, (1/3)ln(t^3 + 6t + 3) ?
yes, but with + C
you can always confirm your answer by taking the derivative, gl!
It helps if you post your working at each stage, instead of simply posting what you get as the answer. This not only helps the person checking your work, but also helps you in that you organise your thoughts into a logical progression through the problem.
thank yo u so muchh, I am working on a problem now
antiderivative of 4rsqrt(8-r)dr
so the u is 8-r
and the du is -1dr right
yes, that's correct
now i got up to 4 times antiderivative of (8-u)sqrt(u)) -du
right?
my answer is...
(8/5)(8-r)^(5/2) - (64/3)(8-r)^(3/2) + ccan any1 tell me if this is correct
my answer is...
It is correct.
  • · Replies 24 ·
  • · Replies 21 ·
