Solving system of differential equations using elimination method
The discussion revolves around solving a system of differential equations using the elimination method. The equations presented are first-order equations that lead to a second-order linear differential equation, which some participants identify as inhomogeneous due to the presence of a non-zero term.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss differentiating the first equation to form a second-order equation and question the nature of the resulting equation as homogeneous or inhomogeneous. There are attempts to clarify the steps involved in using the elimination method and variation of parameters.
There is ongoing exploration of the problem with various participants offering insights into the nature of the equations and potential methods for finding solutions. Some participants express confusion regarding the application of variation of parameters and the correct formulation of the Wronskian.
Participants note that there may be constraints related to the homework rules and the expectations set by the professor regarding the correctness of solutions obtained through online tools.
berlinvic
$$\begin{cases}
y'_1 = y_2, \\
y'_2 = -y_1 + \frac{1}{\cos x}
\end{cases}$$
Elimination method for differential equations, associated homogeneous equation
I am trying to solve this system of differential equations using elimination method, but I am stuck.
$$\begin{cases}
y'_1 = y_2, \\
\end{cases}$$
Here's what I tried:
I've been suggested to differentiate the ##y_1'= y_2## again to get ##y_1''= y_2'= -y_1+ \frac{1}{\cos(x)}##. The "associated homogeneous equation". However, I don't really see a way how to go forward. Anyways, how do you solve this sytem?
That’s just a second order linear homogeneous differential equation. It can be solved by any appropriate method.
Wouldn't the linear homogeneous diff. equation be ##y_1'' + y_1 = 0##? The ##\frac 1 {\cos(x)}## term makes it nonhomogeneous.
Yes sorry, I meant to say inhomogeneous …
But I don't see how I can solve ##y_1^{\prime\prime}=y_2^{\prime}=-y_1+\frac1{\cos(x)}## using elimination method. Any help? I get the same answer as using https://mathdf.com/dif/, which, according to my professor, is incorrect.
You already eliminated ##y_2## ….
Yes, but I still can't see how to move forward, I am just stuck at this line.
@berlinvic, did you get a solution for the homogeneous problem ##y_1'' + y_1 = 0##? That's an easy one. For the nonhomogeneous problem ##y_1'' + y_1 = \sec(x)##, you might have to use variation of parameters.
Yes, I should have mentioned, I already know I should use variation of parameters. However I am not entirely sure which ones and how to apply them. I am fairly confused about it, do you have any tips?
Here is everything I've got so far:
I reduced the system to the second order ODE
y_1''+y_1=\frac{1}{\cos x}. \tag{1}
Next steps:
1. Find two linearly independent solutions to the homogeneous equation ##y_1''+y_1=0## --- for instance, ##u(x)=\cos x## and ##v(x)=\sin x##;
2. Compute the Wronskian of those solutions:
W[u,v]=uv'-u'v; \tag{2}
3. Find a particular solution to the equation $(1)$ using the [formula](https://en.wikipedia.org/wiki/Variation_of_parameters#General_second-order_equation)
y_{1p}(x)=A(x)u(x)+B(x)v(x), \tag{3}
where
A(x)=-\int\frac{v(x)}{W(x)\cos x}\,dx,\qquad
B(x)=\int\frac{u(x)}{W(x)\cos x}\,dx; \tag{4}
4. The general solution to ##(1)## is given by
y_1(x)=c_1u(x)+c_2v(x)+y_{1p}(x); \tag{5}
5. To find ##y_2(x)##, use the first equation of the system:
y_2(x)=y_1'(x)=c_1u'(x)+c_2v'(x)+y_{1p}'(x). \tag{6}$$
Next steps:
What did you get for the Wronksian? It's pretty simple in this problem.
where
I think you're confusing yourself with the above notation. The same wiki page you quoted gives these formulas for A(x) and B(x):
##A(x) = -\int \frac 1 W u_1(x)f(x)dx##
##B(x) = \int \frac 1 W u_2(x)f(x)dx##
Here W is the Wronskian and ##u_1(x)## and ##u_2(x)## are the solutions to the homogeneous DE you found earlier.
