Solving the Blue Screen of Death (BoSD) Problem
  • Thread starter Thread starter FrostScYthe
    Death Screen
8 replies · 19K views
FrostScYthe
Hi. Yesterday, I was playing a game (Warcraft III) when suddenly system stops and I get a BoSD... It stated something like
"A problem has been detected and windows has been shut down to prevent damage blah blah blah blah, Technical information ***STOP: 0x0000008E (0xC000005, 0XBF04DF7B, 0xED924B18 0X000000000) ***: ialmdev5.dll 0 address BF04DF7B base at BF042000, DateStamp 43304C9
Beginning dump of physical memory
Physical memory dump complete. " (I wrote as much as I can recall and I had written down the technical info)
Anyway, I'd be fine with it, if it was just yesterday, but today while watching a movie, IT DID THAT AGAIN ;\... I'm frustrated, I may have not put relevant information, but that's because I'm clueless of what the problem is and ergo clueless of how to solve it.
Any help greatly appreciated,
FrostScYthe
ialmdev5.dll is a driver as far as I know. Update yoru drivers. What motherboard do you have?
My Specs
Here are my system specs:
System Information
Time of this report: 12/26/2005, 17:38:19
Machine name: DJP88L81
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: Dell Computer Corporation
System Model: Dimension 3000
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A02
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 254MB RAM
Page File: 365MB used, 259MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
0--------------------
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) 82865G Graphics Controller
Manufacturer: Intel Corporation
Chip type: Intel(R) 82865G Graphics Controller
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_019D1028&REV_02
Display Memory: 96.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ialmrnt5.dll
Driver Version: 6.14.0010.4396 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/20/2005 09:52:38, 36990 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ialmnt5.sys
Mini VDD Date: 9/20/2005 10:00:54, 1302332 bytes
Device Identifier: {D7B78E66-6632-11CF-B462-9721A3C2CB35}
Vendor ID: 0x8086
Device ID: 0x2572
SubSys ID: 0x019D1028
Revision ID: 0x0002
Revision ID: 0x0002
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
Sound Devices
Description: SoundMAX Digital Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_019D1028&REV_02
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: smwdm.sys
Driver Version: 5.12.0001.5246 (English)
WHQL Logo'd: Yes
Date and Size: 1/27/2005 20:31:06, 260352 bytes
Other Files:
Driver Provider: Analog Devices
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Not run
The driver that failed is your video card's driver. The latest driver from Intel is 14.17, available here:
http://downloadfinder.intel.com/scripts-df-external/Detail_Desc.aspx?agr=N&ProductID=1044&DwnldID=9498&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
Note that you should probably uninstall the current driver before installing the new one. The installation instructions should indicate this, but you should do it even if not made explicit in the instructions.
- Warren
you have a dell... go to the dell www site and put in you service tag number.. and download the newests intel chipset drivers.. Hope that fixes your problem
Thank you so much guys, fixing the video drive actually solved the problem, I think, it's not done it ever since... thanks for the help chroot
I do the download. then try to install, it says some component is corrupted or file missing
And it exits
Thanks,
-Tyndaris
A little piece of advice, if you don't want your system to die sometime in the future, 256MB of RAM is the MINIMUM requirement for XP. I'm amazed that you can watch videos. So yes, get more RAM.
i have 2 sticks of 256... so that's not the problem
