Solving the Eigenvalue Problem: Proving \ e ^ A \psi=\ e ^\lambda\psi
neelakash
Consider the following problem:
if [tex]\ A[/tex][tex]\psi=[/tex][tex]\lambda[/tex][tex]\psi[/tex],prove that
[tex]\ e ^ A[/tex][tex]\psi=[/tex][tex]\ e ^\lambda[/tex][tex]\psi[/tex]
This is my attempt.Please check if I am correct.
If
is correct, we should have:
[tex]\ ln[/tex][tex]\ e^ A[/tex][tex]\psi=[/tex][tex]\ ln[/tex][tex]\ e ^\lambda[/tex][tex]\psi[/tex]
or, [tex]\ ln \{e^A} +[/tex][tex]\ ln \psi=[/tex][tex]\ ln \{e^\lambda} +[/tex][tex]\ ln \psi[/tex]
Now cancel [tex]\ ln \psi[/tex] from both sides and post-multiply the resulting equation by [tex]\psi[/tex]
That is---
[tex]\ ln \{e^A} =[/tex][tex]\ ln \{e^\lambda}[/tex]
or, [tex]\ [ln \{e ^ A}][/tex][tex]\psi=[/tex][tex]\ [ln \{e ^\lambda}][/tex][tex]\psi[/tex]
Alternatively,
So, we got the given equation from the equation to be proved.
The LaTeX image is not coming good.But I think everyone will understand my procedure.
neelakash said:
Now cancel [tex]\ ln \psi[/tex] from both sides and post-multiply the resulting equation by [tex]\psi[/tex] You cannot "cancel". [tex]\ln \psi[/tex] is a matrix.
Do you know the definition of the matrix [itex]e^A[/itex]?
I know the definition of e^A
Let A,B and C be three matrices.
If I have A+C=B+C
what is wrong if I cancel C from both sides?
ln (psi) is a matrix if you consider psi as matrix.I am usimg psi as a complex function like psi=M+iN
I did according to your hint.That works well, but still I am having problem to see why the logaritm of a matrix/operator will not work.
Also, your way of setting up the proof is flawed, as the following direct analogy shows
Theorem: If 1 = 1, prove that 0 = 1.
Proof:
If 0 = 1 is correct, then we obviously also have 1 = 0. Adding the two equations gives
Code:
0 = 1
1 = 0  +
1 = 1
which is the assumption given.
