Solving the Eigenvalue Problem: Proving \ e ^ A \psi=\ e ^\lambda\psi
neelakash
Consider the following problem:
if \ A\psi=\lambda\psi,prove that
\ e ^ A\psi=\ e ^\lambda\psi
This is my attempt.Please check if I am correct.
If
is correct, we should have:
\ ln\ e^ A\psi=\ ln\ e ^\lambda\psi
or, \ ln \{e^A} +\ ln \psi=\ ln \{e^\lambda} +\ ln \psi
Now cancel \ ln \psi from both sides and post-multiply the resulting equation by \psi
That is---
\ ln \{e^A} =\ ln \{e^\lambda}
or, \ [ln \{e ^ A}]\psi=\ [ln \{e ^\lambda}]\psi
Alternatively,
\ A\psi=\lambda\psi
So, we got the given equation from the equation to be proved.
The LaTeX image is not coming good.But I think everyone will understand my procedure.
neelakash said:
Now cancel \ ln \psi from both sides and post-multiply the resulting equation by \psi You cannot "cancel". \ln \psi is a matrix.
Do you know the definition of the matrix e^A?
I know the definition of e^A
Let A,B and C be three matrices.
If I have A+C=B+C
what is wrong if I cancel C from both sides?
ln (psi) is a matrix if you consider psi as matrix.I am usimg psi as a complex function like psi=M+iN
I did according to your hint.That works well, but still I am having problem to see why the logaritm of a matrix/operator will not work.
Also, your way of setting up the proof is flawed, as the following direct analogy shows
Theorem: If 1 = 1, prove that 0 = 1.
Proof:
If 0 = 1 is correct, then we obviously also have 1 = 0. Adding the two equations gives
Code:
0 = 1
1 = 0  +
1 = 1
which is the assumption given.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
