Solving the Hydrogen Atom Wavefunction Puzzle
12 replies · 3K views · last reply
ehrenfest
[SOLVED] hydrogen atom
My book says that
[tex]R_{1,0}(r) = 2(1/a_0)^{3/2} e^{-r/a_0}[/tex]
is a normalized wavefunction. But if you integrate R_{1,0}(r)^2 over r from 0 to infinity, you do not get 1. What's wrong here?
You need a factor of r^2 that comes from the dx dy dz in spherical coords.
That's not it - he's got the factor of r^2. LATE EDIT: No, you're right. I misread his (r)^2 as the r^2 from the volume element.
Ehrenfest: You should not get 1 for that integral. Write down the (general) normalization condition.
Now, I am very confused. I did not have the factor of r^2. But I only need that when I am integrating over dtheta dphi.
Isn't the normalization condition
[tex]\int_{r=0}^{\infty}|R_{1,0}|^2dr = 1[/tex]
Obviously that's wrong but why?
Are you implying that it should really be
[tex]\int_{all space}|\Psi|^2drd\thetad\phi = 1[/tex]
But [tex]\Psi = R(r)Y_{l,m}(\theta,\phi)[/tex] and the spherical harmonics are already normalized. So the normalization condition is still [tex]\int_{r=0}^{\infty}|R_{1,0}(r)|^2dr = 1[/tex], right?
I edited my last post before I saw yours but here it is againAre you implying that it should really be
Only for a 1D problem.
That's not it either.
And that's important. Over what variables are the spherical harmonics normalized? Write down this expression.
Next:
[tex]\int d\Omega |\Psi(r,\theta ,\phi )|^2 = 1[/tex]
How do you write the volume element [itex]d\Omega[/itex] in spherical co-ordinates?
What do you get? You said in your first post that you did not get 1, what did u get?
What happens if you insert r^2 and then integrate?
I have now checked, and I think you are missing the r^2
[tex]R(r) = \frac{u(r)}{r}[/tex] where u(r) solves the radial shrödringer eq.
And now the nowmalization becomes:
[tex]\int_{r=0}^{\infty}|R(r)|^2r^2dr = \int_{r=0}^{\infty}|u(r)|^2dr =1[/tex]
EDIT: Gokul43201 saw that he made a misstake, now three of us are telling you that you missed the r^2 from the volume element of integration =)
I think I see the problem.
We know that
[tex]\int_{all space}\Psi(r,\phi,\theta)dr r^2 sin(\theta) d\theta d\phi = 1[/tex]
[tex]\Psi(r,\phi,\theta) = R(r)Y(\theta,\phi)[/tex]
So, [tex]\int_{\Omega}Y(\theta,\phi)d\Omega = \int_{0}^{\pi}\int_{0}^{2\pi} Y(\theta,\phi)d\phi d\theta = 1[/tex].
Wait, is the first equality in the last equation true, or do I need a factor of sine in there?
need or need.. you are forgetting to square the wavefunction..
the only problem was that you forgot was the r^2 from the volume element of integration.
[tex]\int Y^*Y sin(\theta )d\theta d\phi = 1[/tex] is the normalization condition for the angular part.
Here is what my last post should have been:
We know that
[tex]\int_{all space}\Psi(r,\phi,\theta)*\Psi(r,\phi,\theta)dr r^2 sin(\theta) d\theta d\phi = 1[/tex]
So, [tex]\int_{\Omega}Y(\theta,\phi)*Y(\theta,\phi)d\Omega = \int_{0}^{\pi}\int_{0}^{2\pi} Y(\theta,\phi)*Y(\theta,\phi) sin\theta d\phi d\theta = 1[/tex].
I have no idea why the first equality in the last equation needs that sin \theta? I have solids angles, I have no idea what they mean any more?
EDIT: Do not even read this post. It is all wrong. I am not confused any more.
Now I am really confused. Apparently the normalization condition is really
[tex]4\pi\int_{r=0}^{\infty}|R(r)|^2r^2dr = 1[/tex]
If you try this for the wavefunction I have in my first post, you need that factor of 4\pi.
Which means that [tex]\int \int Y^*Y sin(\theta )d\theta d\phi = 1[/tex] was not correct!
But that makes no sense and I am so confused.
