Solving the 'modified diffusion equation' using fourier transform
4 replies · 4K views · last reply
mudkip9001
A the density of a gas [tex]\rho[/tex] obeys the modified diffusion equation
[tex]\frac{\partial \rho(x,t)}{\partial t}-D\frac{\partial^2 \rho(x,t)}{\partial x^2}=K\delta(x)\delta(t)[/tex]
A) Express [tex]\rho[/tex] in terms of its 2D Fourier transform [tex]\widetilde{\rho}(p,\omega)[/tex] and express the right hand side as a Fourier type integral.
B) Find the function [tex]\widetilde{\rho}(p,\omega)[/tex]
[Note: It might occur to you that this function could contain a term of the form [tex]f(p)\delta(Dp^2-i\omega )[/tex], where [tex]f(p)[/tex] is an arbitrary function. If so, you should assume that [tex]f(p)=0[/tex]. If this doesn't occur to you, then don't worry about it!]
A) I'm pretty sure I can do this:
[tex]\rho(x,t)=\frac{1}{2\pi}\iint_{-\infty}^{\infty}dp\; d\omega\; \left [e^{i(px-\omega t)}\widetilde{\rho}(p,\omega) \right ][/tex]
and
[tex]\delta(x)\delta(t)=\frac{1}{4\pi^2}\iint_{-\infty}^{\infty}dp\; d\omega\; \left [e^{i(px-\omega t)} \right][/tex]
B) Sticking the results from A) into the diffusion equation, taking the derivatives and rearranging:
[tex]\iint_{-\infty}^{\infty}dp\; d\omega\; \left [e^{i(px-\omega t)}\widetilde{\rho}(p,\omega) \right]=\frac{K}{2\pi(Dp^2-i\omega)}\iint_{-\infty}^{\infty}dp\; d\omega\; \left [e^{i(px-\omega t)} \right][/tex]
...and here i get stuck. how do i solve this? I have noticed that the two sides are conspicuously similar, but I'm not sure what conclusions I can make from that.
Edit: the choice of exponentials for the transform (negative for the time) is the convention that was recomended in lectures.
I'm tempted to simply say [tex]\widetilde{\rho}(p,\omega)=1[/tex], and [tex]\frac{K}{2\pi (Dp^2-i\omega)}=1[/tex], but that wouldn't give much diffusion, so I assume that's not the answer...
I have also considered taking [tex]\frac{\partial^2 }{\partial p \partial \omega}[/tex] to both sides to get a partial differential equation, but i don't think that will work, since it's a definite integral, and you would still have an integral on the r.h.s from the chain rule.
i'm sorry, this is nought but a shameless bump, can't diguise it as anything else. Any hint would be appreciated.
You can't take the term [tex](Dp^2-i\omega)[/tex] out of the integral on the left since both variables are operated on by the integrals. Then maybe the hint can be used.
I stared at this for so long, can't believe I didn't realize that...
