Solving the Schrödinger equation for hydrogen atom
The discussion revolves around solving the Schrödinger equation for the hydrogen atom, specifically focusing on the separation of variables and the resulting differential equations. Participants are exploring the mathematical framework necessary to derive the wave functions associated with the hydrogen atom.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss separating variables in the Schrödinger equation and express uncertainty about boundary conditions. Some mention standard solutions to differential equations and suggest looking up solutions in quantum mechanics textbooks. Others explore specific equations, such as the azimuthal and colatitude equations, and question the derivation of coefficients in series solutions.
The discussion is ongoing, with participants sharing their progress on solving specific parts of the problem. Some have provided links to resources that may assist in understanding the solutions, while others are actively working through the equations and seeking clarification on specific points.
Participants note the complexity of the problem and the potential for errors in textbooks. There is mention of constraints related to the normalization of wave functions and the need for specific boundary conditions in the context of quantum mechanics.
raul_l
Hello. I'd like to solve this: -\frac{\hbar^2}{2m}\nabla^2 \Psi(r,\theta,\phi) -U(r) \Psi(r,\theta,\phi) = E\Psi(r,\theta,\phi)
I can separate the variables, but that's about it.
\frac{1}{R(r)} \frac{d}{dr}(r^2 \frac{d}{dr}R(r))+\frac{2mEr^2}{\hbar^2} + \frac{2m\gamma r}{\hbar^2} = C_r
\frac{1}{F(\phi)} \frac{d^2}{d\phi^2} F(\phi) = C_\phi
-C_r-\frac{sin\theta}{P(\theta)} \frac{d}{d\theta} (sin\theta \frac{d}{d\theta} P(\theta))=C_\phi
The answer should be something like this but I don't know how to get there.
\psi_{nlm}(r,\vartheta,\varphi)=\sqrt{{\left(\frac{2}{n a_0} \right)}^3\frac{(n-l-1)!}{2n(n+1)!}}e^{-\rho /2} \rho^{1} L_{n-l-1}^{2l+1}(\rho)\cdot Y_{lm}(\vartheta, \varphi)
If somebody could offer me any idea on how to proceed that would be great. I'm not even sure of how to choose the righ boundary conditions.
the derivation is done in almost all quantum mechanics textbooks so you should look on up.
It's a long derivation.
There are two apporaches to this problem: the DE's are standard ones and one can simply look up the solutions. However, if you have to prove the solutions from scratch, you must start with a series expansion. Again, all the details are in QM textbooks
Ok, this looks pretty complicated (not suprisingly).
I'll start with the azumuthal equation.
\frac{d^2}{d\phi^2} F(\phi) = C_\phi F(\phi)
The solution is in the form F(\phi)=Ae^{B\phi}
which gives me
\frac{d^2}{d\phi^2} Ae^{B\phi} = C_\phi Ae^{B\phi} \Rightarrow -AB^2 e^{B\phi} = C_\phi Ae^{B\phi} and therefore C_\phi=-B^2
Due to constraints on the wavefunction F(\phi)=F(\phi+2\pi)
which means that Ae^{B\phi}=Ae^{B(\phi+2\pi)}=Ae^{B\phi} e^{2B\pi} \Rightarrow e^{2B\pi}=1 \Rightarrow B=im where m is an integer.
Because of normalization \int_{-\infty}^{\infty} F(\phi) d\phi=1 and therefore A=1.
I have arrived at F(\phi)=e^{im\phi}
and C_\phi=-m^2
which means that -C_r-\frac{sin\theta}{P(\theta)} \frac{d}{d\theta} (sin\theta \frac{d}{d\theta} P(\theta))=-m^2
Thanks for your help so far. I'll keep on working on this.
I'm half way solving the colatitude equation (I know how to solve differential equations using series expansion).
However, this is a lot of work I think it would probably be a better idea to just look it up in a QM textbook.
I have one question though.
Why is C_r=l(l+1) ? I can't find the answer anywhere.
I have a problem with solving the general Legendre equation.
As we know the series solution is in the form
\sum a_s x^s
I have found the formula for the coefficients
a_{s+2}=-a_s \frac{(l-s)(l+s+1)}{(s+1)(s+2)}
Now, if l=s then a_{l+2} and all subsequent coefficients become zero.
In the book it says that the highest coefficient a_l is given by the formula a_l=\frac{(2l)!}{2^l (l!)^2} but I don't see how. :confused:
If I set a_0=1 I get
a_s=\frac{(l-s+2)(l-s+4)...l(l+1)(l+3)...(l+s-1)}{s!}
If l=s then
a_l=\frac{2*4*...*l(l+1)(l+3)...(2l-1)}{l!}
I don't know how to proceed. The best I can do is write it like this:
a_l=\frac{(2l)!}{1*3*...(l-1)(l+2)(l+4)...2l*l!}
which is pretty close to \frac{(2l)!}{2^l (l!)^2} but not exactly.
which book?
Mathematical Methods For Physicists by Tai L. Chow
Of course, there is always the possibiliy of a mistake in the book.
At the bottom of page 298.
Yes, as far as I know.
Actually, they use the series expansion method to solve the Laguerre equation. But the Legendre equation is solved differently. I think it's quite clever.
Hello again.
I'm having trouble evaluating \frac{(-1)^l}{2^{2l} (l!)^2} \frac{(2l)!(l+m)!}{(l-m)!} \int_{-1}^{1} (x^2-1)^l dx
which should be \frac{2}{2l+1} \frac{(l+m)!}{(l-m)!}
My first thought was to use the Newton's binomial formula to evaluate the integral.
\int_{-1}^{1} (x^2-1)^l dx = \int_{-1}^{1} \sum_{k=0}^l \frac{l!}{k!(l-k)!} (x^2)^{l-k} (-1)^k = (\sum_{k=0}^l \frac{l!}{k!(l-k)!(2l-2k+1)} x^{2l-2k+1} (-1)^k) _{x=-1}^{x=1}
Since (2l-2k+1) is always odd (x^{2l-2k+1})_{x=-1}^{x=1} always yields 2.
Therefore
\frac{(-1)^l}{2^{2l} (l!)^2} \frac{(2l)!(l+m)!}{(l-m)!} \int_{-1}^{1} (x^2-1)^l dx = \frac{(-1)^l}{2^{2l} (l!)^2} \frac{(2l)!(l+m)!}{(l-m)!} \sum_{k=0}^l \frac{l!}{k!(l-k)!(2l-2k+1)} (-1)^k = \frac{(-1)^l}{2^{2l} l!} \frac{(2l)!(l+m)!}{(l-m)!} \sum_{k=0}^l \frac{1}{k!(l-k)!(2l-2k+1)} (-1)^k
I don't know how to proceed (or if I've been correct so far).
Btw, here x substitutes cos \theta but I don't think that changes anything.
