Solving the Spring-Weight Paradox: 0.039m
  • Thread starter Speedking96
    Paradox
2 replies · 1K views · last reply
Speedking96
Textbook problem 7.74: A basket of negligible weight hangs from a vertical spring scale of force constant 1500 N/m. (a) If you suddenly put a 3.0-kg adobe brick in the basket, find the maximum distance that the spring will stretch.
Fs = -kx
w = mg
I said that when the spring is stretched out at its max, the weight pulling down will equal the force of the spring pulling up.
Fs=w
-kx = mg
-(1500)(x) = (3)(-9.81)
x = 0.01962 m
The solution key tells me the max stretch is double this amount, 0.039 m. What is wrong with my approach?
Mark the word suddenly. If the basket were at maximum distance and forces would be in equilibrium, the velocity wouldn't change anymore, so the thing would hang still.
Do you think that is what would happen if you suddenly put a brick in the basket ?
Ah. I see. So then I need to solve the problem using the conservation of energy.
