Solving the Winch Problem at 12m High
  • Thread starter Thread starter dontdisturbmycircles
    Winch
5 replies · 6K views
A winch at the top of 12 meter high building pulls a pipe of the same length to a vertical position. The winch pulls in rope at a rate of -0.2 meters per second. Find the rate of the vertical change and the rate of the horizontal change at the end of the pipe when y=6.
http://www.imagehosting.com/out.php/i249658_ahhh.JPG
I simply don't have enough information..
I set up an equation relating the three variables..
[tex]s^{2}=x^{2}+(12-y)^{2}[/tex]
and differentiate with respect to time and end up with
[tex]s\frac{ds}{dt}=x\frac{dx}{dt}-(12-y)\frac{dy}{dt}[/tex]
But I simply don't have all of the variables needed. I can solve for x (with pythagorean theorem), but not dx/dt...
Any help is appreciated.
Hint:
First find the ANGULAR rate of change by a smart law of cosines.
THEN, find the rates of change of (x,y) by using a right-angled triangle.
Thankyou arildno :smile:
I was able to get the correct numerical answer but something is bothering me...
Take the angle made at the top of the wall to be [tex]\theta[/tex]...
We know that [tex]\frac{d\theta}{dt}[/tex] must be positive since the angle is tending towards 90deg right?
I got [tex]\frac{d\theta}{dt}=\frac{/sqrt{3}}{80}[/tex]... but this leads to something that is incorrect. Because when I set up the following equation to relate x and s, I get this..
[tex]sin\theta=\frac{x}{s} = x(s)^{-1}[/tex]
[tex]cos\theta\frac{d\theta}{dt}=x(-1)s^{-2}\frac{ds}{dt}+s^{-1}\frac{dx}{dt}[/tex]
which eventually leads to
[tex]\frac{dx}{dt}=s(cos\theta\frac{d\theta}{dt}+x*s^{-2}\frac{ds}{dt})[/tex]
Now, solving for x using the right triangle at the base, [tex]x=\sqrt{12^{2}-6^{2}} = 6*\sqrt{3}[/tex]
and s=12 by similar reasoning
Then [tex]tan\theta=\frac{6\sqrt{3}}{6}[/tex]
[tex]\theta=\frac{\pi}{3}[/tex]
So solving [tex]\frac{dx}{dt}=s(cos\theta\frac{d\theta}{dt}+x*s^{-2}\frac{ds}{dt})[/tex]
I get [tex]\frac{dx}{dt}=\frac{\sqrt{3}}{15}[/tex]
Which is the correct magnitude, but the incorrect sign... :/
Well, I used the lowest angle, with the variable length s(t) as the opposite side. I didn't calculate it through, but my signs looked good.
Ok, let me try that and see if I can get it to work.
Wow it worked very smoothly using the lower angle... Correct sign and all. I'll have to think about this problem for a bit. Thanks again.
