Solving Water Storage Tank Problem with Bernoulli's Equation
3 replies · 3K views
VanessaN
A water storage tank is open to air on the top and has a height of 1 m. If the tank is completely full and a hole is made at the center of the wall of the tank, how fast will water exit the tank?
Pressure is the same as atmospheric pressure because the tank is open to the air. Also, linear flow speed at the surface is essentially zero, so...
Bernoulli's equation can be simplified to:
rho * g * h1 = 1/2 * rho * v2^2 + rho * g * h2
[/B]
rho= density
g= 10 m/ s^2
height 1 (or height initial)= 1 m
Here is where I don't understand the solution...
height 2 is apparently = 0.5 m, but this is not in the question stem...
My attempt at solving for v2 ultimately comes out to be:
v2= sq rt 2g (h1-h2)= sq rt 2* 10 m/s * (1 m - 0) = sq rt 20 meters
But the correct way to solve was:
v2= sq rt 2g (h1-h2)= sq rt 2* 10 m/s * (1 m - 0.5 m) = sq rt 10 meters
So, I guess my question is why would the final height (height 2) be 0.5 m?
Or, is there any other way to get the correct answer of sq rt 10 meters?
solving for v2, which ultimately comes out to be:
I did not get the correct answer. The correct answer is apparently sq rt 10. Can somebody please help me figure out where I went wrong? Thanks in advance!:woot:
Your post is hard to follow, since you don't define the variables used in your equations nor do you list their values. How do you expect anyone to help? :oops: :rolleyes: o_O
In any event, have you heard of Torricelli's Law?
http://en.wikipedia.org/wiki/Torricelli's_law
They asked for the case where the hole is half way down the wall of the tank, not at the bottom of the tank.
Chet
Chet
ahhh, the case where i make a problem much more difficult by not understanding the question... the word "center" should have tipped me off to the fact that the final height would be 0.5!
Thank you for your help i appreciate it!
