Solving Work Along a Force Field Path - A Math Question
  • Level: Graduate
  • Thread starter Thread starter marschmellow
    Field Force Work
4 replies · 2K views · last reply
marschmellow
This might be more of a mathematical question, but the other day in Physics my teacher said that work along a curved path is a line integral, which made perfect sense to me. But then I wondered how one determines the path of travel if the force varies at each point x, y, and z. So how would you find the path of travel of a particle given a vector field of forces, an initial position and an initial velocity?
This is exactly what the Lagrangian formulation of classical mechanics is for. Basically you write the Lagrangian, solve the Euler-Lagrange equation, plug in your initial conditions and you have your answer.
Okay good, that sounds hard. I'm glad the answer wasn't something really obvious, because I would be embarrassed for asking.
For a point-like (constant) mass all you need is to solve Newton's equation:
[itex] \mathbf{F}(\frac{d \mathbf{r}}{dt},\mathbf{r},t)=m\frac{d^2 \mathbf{r}}{dt^2}[/itex]
which is a system of 3 differential equations, the unknown is [itex]\mathbf{r}[/itex], the 'path of travel' (parametrized by time)
This maybe slightly off base with what you are talking about but incidentally, if your force field is conservative ( ie the force at any point depends on a function of position, like gravitational and electrostatic forces do ) then the line integral will be a constant for any path you choose and will depend only on your initial and final points.
