Some work on MTW Figure 25.7
  • Thread starter Thread starter TerryW
TerryW
What is Q in Figure 25.7
Q^2 = (R-2)(R+6) etc
Figure 25.7 in MTW is unusual in that it introduces formulae with no real explanation as to how they have been derived. I refer to the use of ##Q^2 = (R-2)(R+6)## and ##Sin^2 \theta = k^2 = (Q-R+6)/2Q## and then ##sin^2 \phi_{min} = (2+Q-R)/(6+Q-R)## leading to ##\Theta = 4*(R/Q)^{½}(F(\pi/2,\theta) - F(\phi_{min},\theta)) - \pi##
So I decided to to try find out how these formulae might be generated.
My first step was to solve: ##\big(\frac{du}{d\phi}\big)^2 +(1-2u)u^2 = u_b^2##
ie ##d\phi = \frac{du}{\sqrt2(u^3-1/2u^2+1/2U_b^2)^{½}}= \frac{du}{\sqrt2 (\sqrt(u-r_1)(r_2-u)(r_3-u))}##
A cubic of the form ##u^3 +\alpha u^2+\beta u + \gamma## can be factorised into ##(u-r_1)(r_2-u)(r_3-u)## using a standard process.
I built a spreadsheet to find ##r_1## ,##r_2## and ##r_3## for the values of ##\alpha = 0.5, \beta =0## and a range of values for ##\gamma = \frac{1}{2}u_b^2 =< \frac{1}{2}u^2_{b(min)}## where ##u_{b(min)} = \frac{1}{b(min)} = \frac{1}{3\sqrt3}##
The next stage is to get ##\frac{du}{\sqrt2((u-r_1)(r_2-u)(r_3-u))^{½}}## into a form which can be integrated.
Using the substitution ##u = r_2-(r_2-r_1)cos^2\theta## and ##du = -2(r_2-r_1)Sin\theta cos\theta##
I arrive at ##\frac{1}{\sqrt 2} \int _0^b\frac{du}{\sqrt ((u-r_1)(r_2-u)(r_3-u))} = \frac{1}{\sqrt 2} \int \frac{2d\theta}{\sqrt(r_3-r_1)\sqrt(1-k^2sin^2\theta)}## where ##k^2 = \frac{(r_2-r_1)}{(r_3-r_1)}##
I'm now ready to evaluate (1) the various formulae involving Q and R in Fig 25.7 with their equivalents from my analysis, taking the values for ##b= \frac{1}{u_b} = 5.2065.## and contrasting them with the equivalents derived from the roots of the cubic.
A (MTW) ##b^2 = 5.2065^2 = \frac{R^3}{(R-2)} ## This is a cubic equation which has one root with the value of 3.11474.
A (Cubic) One of the roots of ##u^3 - \frac{1}{2} u^2 + \frac{1}{2}u_b^2 = 0## when u_b is set to 0.19207 (=##\frac{1}{5.2065}##) is 0.32105 =##\frac{1}{3.11474}##
So, solving the cubic ##u^3 - \frac{1}{2} u^2 + \frac{1}{2}u_b^2 = 0## provides a value for 1/R where R is the distance of closest approach.
B (MTW) ##Q^2 = (R-2)(R+6) = (3.1147-2)(3.1147+6)= 10.16016, Q= 3.1874##
Q is then used to generate ##k^2##
##k^2 = (Q-R+6)/2Q = 0.9526##
B (Cubic) ##k^2 = \frac{(r_2-r_1)}{(r_3-r_1)} = \frac{(0.32105-(-0.16637))}{(0.34532-(-0.16637))} = 0.9526##
So the roots of ##u^3 - \frac{1}{2} u^2 + \frac{1}{2}u_b^2 = 0## are all that is needed to produce ##k^2##.
C (MTW) The so-called amplitude of the elliptic function ##sin^2\phi _{min} = (2+Q-R)(6+Q-R)##.
##(2+Q-R)(6+Q-R) = 2.0727/6.0727 = 0.34131. ##
##Sin^{-1}(\sqrt(0.34131) = 35.748º##
C (Cubic) ##\phi = cos^{-1}\big(\sqrt\frac{r_2}{r_2-r_1}\big) = 35.748º##
D (MTW) ##4(R/Q)^\frac{1}{2} = 4 * \sqrt {(3.1147/3.1874)} = 3.9541##
D (Cubic) ##\frac{4}{\sqrt 2 \sqrt (r_3-r_1)} = 3.9540##
I've confirmed that an impact parameter of ##b/M = \sqrt 27 - 0.065## gives a value of ##\Theta = 2\pi##
The calculation for ##b/M = \sqrt 27 - 0.000012## gives ##4\pi##
So why did MTW use the formulae involving Q and R instead of working through from the cubic equation?
I've tried to find some relationship between MTW's R&Q and the three cubic roots ##r_1##, ##r_2## and## r_3## but nothing is immediately obvious.
TerryW
The relations between the three root ##(r_1, r_2, r_3)## and the quantities ##R## and ##Q## are given in the paper by C. Darwin referenced in Fig. 25.7 of MTW. You can read this paper online here if you register for a free account. Section 8 of the paper deals with the orbits of light rays. There, he shows how to obtain $$r_1 =- \frac{Q-R+2}{4R}, \,\,\, r_2 = \frac 1 R, \,\,\,r_3 = \frac{Q+R-2}{4R}.$$ ##Q## is just an abbreviation for ##\sqrt{(R-2)(R+6)}##. Darwin uses ##P## instead of ##R## for the distance of closest approach. And he uses ##l## for the impact parameter instead of ##b##.
For a specified ##R##, the roots are determined by these relations. Darwin also shows how to determine the deflection of the light rays.
This is a nice substitution. It reduces the integral to an elliptic integral. (I'm not sure of your upper limit of ##b## for the ##u## integral.)
These days, it is easy to use software to numerically evaluate the integral. Back when computers were not accessible, you could use numerical tables for elliptic integrals. Darwin's paper was published in 1957. Even at the time of the publication of MTW (1970) most students didn't have easy access to computers. This might partly explain MTW's use of Darwin's expression for the deflection angle in terms of the elliptic integral ##F##: $$\Theta = 4(R/Q)^{1/2}\left[F(\pi/2, \theta) - F(\phi_{\rm min}, \theta)\right] - \pi$$
Hi TSny,
I've had a look at the paper you recommended and yes it shows the relationship between the roots of the cubic and Q and R, but it still leaves me with the question of why bother to do it when you can just use the roots directly as I have demonstrated.
I can't take all the credit for this. I put a query into Google AI and it came up with the transformation of the cubic but wrongly identified the substitution as ##u = r_2-(r_2-r_1)sin^2\theta## which clearly did not work. There were other minor inaccuracies in the answer but it put me on the right track
(I'm not sure of your upper limit of for the integral.)
You're right. I suppose it should be ##u = r_2## although this does make the integrand infinite at the limit.
I well remember the days before computers. I graduated in 1969. Even at Oxford, we still had to make extensive use of slide rules and those can register like calculating machines which had only developed to the point where it had an electric motor instead of a handle!
In my attempts to confirm that the formula for ##\Theta## gives the results of ##\pi##, ##2\pi##,##3\pi##, and ##4\pi##, I found that I was able to just ask Google AI "What is the value of the elliptic function ##F(\theta,k)##?" to get the values I needed.
I'm now trying to find a way to confirm the values of 1.75 and 0.0029 in ##\frac{2bdb}{d\Theta}## in Ex 25.26. I'll have another look at that paper you referenced to see if there is anything to help with this. Failing that, I may have to send up the Bat Signal
Regards
Terry
TerryW said:
Hi TSny,
I don't see much difference between the MTW (Darwin) calculations and your calculations using ##r_1, r_2, ## and ##r_3##. Darwin shows how the three roots can be expressed in terms of just ##R##, the distance of closest approach. (See post #2). The expressions used in MTW are easily shown to be equivalent to your expressions. For example, you have ##k^2 = \frac{r_2 - r_1}{r_3-r_1}##. Using Darwin's expressions for the roots, this reduces to ##k^2 = \frac{Q-R+6}{2Q}##, which is the expression used in MTW.
1970 for me. Ah, yes, the wonderful slide rule! Still have mine in my desk drawer. Never use it, but I'm too attached to it to get rid of it.
:smile: It's a new world.
For ##db/d\Theta##, you might try using the approximation given in Fig. 25.7: $$\frac b M \approx 3^{3/2} + 3.48e^{-\Theta}$$ The approximation is for large ##\Theta##.
Yep! Still have my slide rule.
I agree that Darwin's expressions and mine are the same, I'm only questioning why it was necessary to introduce Q in the first place when everything can be derived directly from the roots of the cubic. But I also thought my post may be useful if anyone else ever gets to that Figure and wonders where Q and R come from!
To try to confirm the values of 1.75 and 0.0029 in Ex25.26, I've used the results that I generated for##F(\phi,k)## and the associated values of ##4/\sqrt{2(r_3-r_1)}## to create two values of ##\Delta \Theta##, one for ##b= \sqrt{27} + 0.151## with ##\Delta b = 0.01## and one for ##b= \sqrt{27} + 0.0065## with ##\Delta b = 0.00005##
The results are 3.89 vs 1.75 and 0.0036 vs 0.0029. So I have the right order of magnitude but could be closer.
The problem is that the values of ##F(\pi/2,k)## are very similar, differing only by small values Order(0.001). I'll have a look to see if I can find values for ##F(\pi/2,k)## accurate to maybe 5 or six decimal points!
I've also tried to build spreadsheets to calculate the original integral. The problem with this is that the results are highly sensitive to my choice for du. Maybe a bit more work to be done on this.
My problem with using ##\frac b M \approx 3^{3/2} + 3.48e^{-\Theta}## is that I'd need to work out where this has come from! I do have an idea to try out to see if I can generate this formula - I'll update my post when I've followed this up.
Regards
Terry
For online calculation of the incomplete elliptic integral ##F[\phi, m]##, where ##m = k^2##, see this site at WolframAlpha. The link shows the calculation of ##F[0.3, 0.8]##.
  • · Replies 19 ·
  • · Replies 22 ·
