Undergrad How is the sound horizon at recombination and BAO measured in the CMB?
The sound horizon at recombination (~r(z*)) is measured using the Cosmic Microwave Background (CMB) at a redshift of z*=1100, while the sound horizon measured with Baryon Acoustic Oscillations (BAO) can be assessed from the drag epoch to low redshifts. Both sound horizons are approximately 140 Mpc, with minor variations. The angular size of 1 degree for r(z*) is derived from theoretical considerations, linking the physical size of the sound horizon to its observed size through the proper distance to the CMB. Temperature fluctuations in the CMB are analyzed to compare with theoretical predictions, indicating the universe's geometry.
  • Understanding of Cosmic Microwave Background (CMB) theory
  • Knowledge of Baryon Acoustic Oscillations (BAO)
  • Familiarity with redshift concepts in cosmology
  • Basic grasp of angular size and distance calculations
  • Research the methods for measuring CMB temperature fluctuations
  • Study the implications of BAO on cosmic structure formation
  • Explore the theoretical foundations of angular size approximation
  • Investigate the statistical analysis techniques used in cosmological measurements
Astronomers, cosmologists, and physics students interested in the measurement and implications of sound horizons in the universe, particularly those focusing on CMB and BAO analysis.
jordy1113
So I'm trying to understand the sound horizon measured at recombination and the sound horizon measured with BAO. Here is what I've gathered (PLEASE tell me if I'm wrong and if you could please explain, I've been trying to read but can't find a clear explanation):
~r(z*) is measured using CMB (could someone explain to me exactly how this is measured) at z*=1100 (recombination epoch)
~ r using BAO can be measured from the drag epoch to very very small redshifts
~ both sound horizons are basically the same (around 140Mpc, yes I know they're not exactly the same but they vary only a little)
Again if someone could explain how these are measure (like why choose angular size of 1 degree for r(z*)) I really need to clear up my confusion :( Thank you to everyone in advance
Space news on Phys.org
The experts seem to have vacated the premises, so you're stuck with me. My understanding is incomplete, though.
With that disclaimer - You get 1 degree as your base scale from theoretical considerations. You calculate the physical size of the sound horizon at recombination (r, about 0.14 Mpc, or 0.45 Mly, which is 150 Mpc in comoving terms). This gives you an idea of how big the largest 'bubble' leaving imprint on the CMB should be. You then calculate the proper distance from the observer to the CMB at recombination (R, about 45 Mly), so that you can relate the physical size to its observed size. Using small angle approximation, you get the angular size by dividing r/R, which netts about 1 degree. As the universe expands, this angular size remains constant.
You can then measure the size of the temperature fluctuations in the CMB to see how they compare to theory. E.g. a deviation here would suggest the geometry of the universe being different than the assumed flat one.
I have no hands-on experience with actually measuring these, nor have I seen it done.
I suspect it's done with some sort of statistical analysis across the whole sky, rather than taking a ruler to any single fluctuation, considering how messy it all is.
I always thought it was odd that we know dark energy expands our universe, and that we know it has been increasing over time, yet no one ever expressed a "true" size of the universe (not "observable" universe, the ENTIRE universe) by just reversing the process of expansion based on our understanding of its rate through history, to the point where everything would've been in an extremely small region. The more I've looked into it recently, I've come to find that it is due to that "inflation"...
  • · Replies 23 ·
  • · Replies 29 ·
  • · Replies 37 ·
