Space Stuff and Launch Info
1,734 replies · 247K views · last reply
SamBeer said:
Does anyone know anything about electrogravitics??
electrogravitics... That would be a very brief conversation on this Forum.
1oldman2 said:
it doesn't look good for AMC 9.
Well, the satellite is old already, had 14 of its 15 years design lifetime.
mfb said:
No launch today. 5th or 6th.
5th - today.
23:37 UTC (6.5 hours after this post) or up to one hour after that.
Good point, The article mentions a Kinetic event, any word on the cause ? Debris collision vs. Equipment failure ?
mfb said:
5th - today.
This will be a test of the "Third Times a Charm" theory. I'm betting the bugs are worked out and they will fly today.
https://www.missionjuno.swri.edu/junocam/processing/
https://spaceflightnow.com/2017/07/12/first-images-of-jupiters-great-red-spot-reach-earth/
http://agupubs.onlinelibrary.wiley....N)1944-8007.JUNO1/?campaign=dartwol|427538210
A better idea in the works ?
http://spacenews.com/spacex-drops-plans-for-powered-dragon-landings/
WASHINGTON - "SpaceX no longer plans to have the next version of its Dragon spacecraft be capable of powered landings, a move that has implications for the company’s long-term Mars plans."
"There was a time that I thought the Dragon approach to landing Mars, where you’ve got a base heat shield and side-mounted thrusters, would be the right way to land on Mars," he said. "Now I’m pretty confident that is not the right way and there’s a far better approach."
Quoting Musk
"Plan is to do powered landings on Mars for sure, but with a vastly bigger ship"
He also confirmed that SpaceX works on a smaller version of ITS.
The impact on the planned path to Mars is huge, but it also impacts other parts of SpaceX operation.
  • The largest thing humans landed on Mars so far (Curiosity) had a mass of 900 kg. Red Dragon would have landed multiple tons. A downscaled ITS would probably land with ~100 tons. Without previous experience of propulsive landings on Mars in general, and without any landing experience from SpaceX.
  • Before humans can be sent to Mars, spacecraft there have to demonstrate the landing capability, and they have to demonstrate that fuel production is feasible. Previously this was expected for the Red Dragon missions in 2020 and 2022. If a downscaled ITS is the first spacecraft to do go to Mars, then 2022 is a super optimistic timescale, and 2024 or later is more likely. You probably want another round to refine that - 2026. That means humans won't go there before 2029, even if everything goes well.
  • Currently they can reuse the pressure vessel of Dragon, but not the full capsule. The salt water landing corrodes other parts. A propulsive landing on land would have made full reuse much easier. Musk mentioned a possible landing on a soft surface, but that didn't look like a real plan. Landing in a lake might be possible.
On the positive side, the business model will probably look much better now. A rocket with a payload in the 100 ton range, where both stages are reusable very often, can take over the full commercial launch market, even the parts that do not exist yet (e. g. LEO satellite internet constellations or space tourism besides short ISS visits).
With a lot of in-orbit refueling, such a system could go to Moon as well. NASA or ESA might buy a few trips.
News on the Heavy.
https://spaceflightnow.com/2017/07/25/musk-sets-expectations-low-for-maiden-falcon-heavy-launch/
"When SpaceX’s Falcon Heavy rocket finally takes off for the first time, a debut now scheduled this fall, there’s a good chance the commercial heavy-lifter will falter short of reaching orbit, company founder and chief designer Elon Musk said last week."
"There’s a lot of risk associated with Falcon Heavy, a real good chance that that vehicle does not make it to orbit," Musk said, referring to the inaugural test launch. "I want to make sure to set expectations accordingly. I hope it makes it far enough beyond the pad so that it does not cause pad damage. I would consider even that a win, to be honest."
It is the pad they want to use for the manned missions to the ISS next year. If they would think damage to the pad was a likely outcome they wouldn't do that. More delays of Dragon 2 would make NASA a very unhappy customer, and so far it is the most important customer.
On the other hand, the US has some more military satellite contracts they want to award soon, for a total of $2 billion. For SpaceX to participate, they need at least one FH launch before the end of this year.
The STP-2 launch should make a pretty good proving ground for that. Any Idea what the payload mass is on that flight?
The demo mission with the dummy payload is all that counts. STP-2 will be too late.
I don't think the payload is the point, no one questions that FH will be able to lift every satellite currently designed. The interesting part is the flight dynamics. Does the rocket survive the vibrations induced by 27 rocket engines, is the aerodynamics simulation accurate, does the separation work?
ISAT has a mass of more than 5000 kg, COSMIC-2 adds 1700 kg, no idea about the other payloads but they should be lighter.
ISAT and COSMIC-2 go to LEO, but with different orbital planes. The total payload mass is probably not too high but the second stage will need fuel for all the plane changes.
Good question, I see they have redesigned the core stage air-frame in anticipation of the new stress involved.
If your a fan of JWST, here's a teaser.
https://asd.gsfc.nasa.gov/luvoir/media/Flyer_v5.pdf
After the JWST cost overruns, I'm not sure how happy the US would be with another telescope that looks like JWST.
The European ELT will be faster and it can make exoplanet pictures as well. The sensitivity is a bit lower, but picturing exoplanets is limited by the resolution, and ELT has a slightly better resolution.
Granted there is an image problem associated with JWST, I think the LUVOIR is just a concept on the wish list, but a pretty cool one. These projects seem to get weeded out by economics and given that climate lately its a miracle any of them see first light. I noticed the new design only uses one layer of sunshade, they must have improved the performance or found a new material.
After some maths, I wouldn't be unhappy.
Om goes googling:
James Webb Space Telescope:
Cost: $10,000,000,000 (er mehr gerd!)
hmmmm:
≈100,000,000 taxpayers
divided into 10 billion yields: $100/person
Not too bad, but $100 is one months of my disposable income.:oldgrumpy:
hmmmm...
2018: launch date
1996: inception date
≈22 years
$100/22 = $4.54/year ≈ 1¼¢/day​
I can afford a penny a day.
If you have $100/month disposable income, you probably pay less tax than the average taxpayer. Your contribution would be even smaller.
All these projects are cheap per person and day. There are many of them, of course.
Divide the highest ITER cost estimates by 2 billion (population of participating countries) and you get $10 per person, or ~0.1 cent per day over 25 years. For the option to have a very clean energy source in the future? Build two of them!
The US and many European countries spend about 3% of the federal/country budget on research. We could double science funding if everyone would be fine with paying 3% higher taxes. In the US that would be about $1.2 per person and day on average, in Germany it would be something similar but estimating the number is complicated.
I'd happily pay that. Okay, I am biased, because my income is from this budget item...
I paid 23% last year, with an income of ½ the national average.
I'm not sure what the average person paid last year.
Though, some of that was a "wealth" tax, so I'm not sure if that counts.
ps. Whatever you are paid, it is not enough.
pps. I think we're getting off topic...
Space and Stuff!
It is a UV telescope. A single layer of aluminum foil or plastic with aluminum coat will reflect/adsorb all of the UV/vis light. An IR telescope needs to be cold. JWST should be kept around 50K. LUVOIR can run at 280K. Spacial resolution is proportional to wavelength. A UV telescope should create much sharper images.
JWST is designed to get images in the infrared which are hard to get on Earth's surface.
OmCheeto said:
After some maths, I wouldn't be unhappy...
Cost: $10,000,000,000 (er mehr gerd!)...​
EELT is expecting to cost around $109. EELT should be able to get boring pictures of a wet rock. JWST will get interesting images of Jupiter sized structures which cannot be acquired from earth.
I think mfb is right that the US public wants a wet pixel. Might disturb some people if ESO gets it first while we spent 10x the cash.
Good point, thanks for the answer.
He has a habit of that.
I've only know him to be wrong, once, in my 10 years here, at PF.
ps. Somewhat off topic: I used to be a nuclear power plant technician, whilst in the Navy, and developed a habit of "never being wrong".
Being wrong back then, meant everyone would be dead.
Fast forward 20 years, to my civilian-hood, dollar store job, and after everyone was so pissed at me for never making a mistake after 10 years of perfection, one day, I made a mistake.
All I can remember was, that they danced.
I think I danced the day mfb made a mistake, because I FINALLY correctly did a maths problem.
I am very bad at maths.
It happens, but I try to avoid it.
JWST can do infrared spectroscopy of some exoplanets, especially in transits.
For direct imaging ELT is better - better resolution and contrast, and more light. It will be able to take direct pictures and spectra of many planetary systems up to ~100 light years away, and some even further out.
Here is a simulation for GMT. ELT will have nearly three times the mirror area and about twice the angular resolution..
JWST will be much earlier - 2018, while ELT has first light planned for 2024.
Speaking of JWST...:wink:
At some point this baby's going to fly, I just hope I live long enough to see it.
http://spacenews.com/spaceport-schedule-conflict-could-delay-jwst-launch/
WASHINGTON - "NASA’s James Webb Space Telescope is facing a schedule conflict for its Ariane 5 launch with a European planetary science mission that could, in one scenario, delay the telescope’s launch by several months."
That schedule conflict is due in part to delays in the development of BepiColombo. The mission’s launch has slipped several times in the last decade. In 2007, when ESA approved moving the mission into its development phase, it was expected to launch on a Soyuz rocket in 2013.
In 2011, ESA announced the mission would instead launch on a more powerful Ariane 5 in July 2014. The launch slipped in 2012 to August 2015, then later to July 2016, January 2017 and April 2018. Last November, ESA announced that the launch was now scheduled for October 2018 because of a problem with a power processing unit on the spacecraft .
Looks like there are a lot of launch windows for BepiColombo, and these dates are not even necessarily all launch options. Just shift it once more.
