Space Stuff and Launch Info
1,738 replies · 251K views · last reply
mfb said:
45 minutes until the launch of Crew-5. SpaceX livestream.
Anna Kikina will be the first Russian astronaut to fly on Dragon, and first Russian astronaut to fly on a US spacecraft that's not the Shuttle.
8th flight of Crew Dragon, second flight of this capsule, first flight of the booster which has gotten rare.
Edit: Successful launch, Dragon is in space. Based on an unlucky orbital alignment they'll need 29 hours to reach the ISS.
Atlas V has 20 launches left. It uses Russian engines so that number is known precisely, and all launches have been booked. Someone noted how the types of launches align with Tolkien's 20 rings:
Three launches will be US government satellites.
Seven launches will be Starliner capsules, where the rocket is shorter than usual.
Nine launches will be for Project Kuiper (Amazon).
That makes Viasat, the customer for the last launch, the Dark Lord?
That was amazing. Not just the successful launch but the first stage return landing, on a ship! On a circle!
Like a Heli pad, just incredible.
This is bizarre when we consider Ukraine and the dreaded Putin's behaviour.
I know Science tends to be above these things but this exercise is very high profile. Such is the way of international relations.
Running the ISS without Russia would be very difficult, leaving the ISS would be a bad idea, and Russia doesn't want to abandon it either. The seat swap program mixes both Dragon and Soyuz crews and ensures access to the ISS without paying either side.
Science has always tried to be a good example of how we should live and work together. SESAME is one of the most extreme examples, bringing together Israel, Iran and the Palestinian Authority, and Turkey and Cyprus. Countries that don't even recognize the existence of the other countries (Iran -> Israel and Turkey -> Cyprus) work together there.
  • Love
It amazes me that Putin's priorities fall that way. It certainly makes sense but since when has dear Vlad had that sort of sense?
I don't know, and I don't think this is the right place to discuss it.
Crew-5 docked with the ISS. Crew-4 will leave in a few days.
Firefly had declared 100% mission success earlier this month, but analysis of the payload orbits shows they were deployed at a significantly lower altitude than planned. Instead of ~300 km they only orbited at ~200-250 km, which comes with a far larger drag and far shorter lifetime. Nevertheless, the rocket has demonstrated that it can reach orbit, being short something like 50 m/s of the target orbit after accelerating by 9 km/s is probably a minor issue that they'll fix before the next flight (planned for late November).
mmm Putin's attitude to space seems pretty relevant to the title of this thread, actually. He's definite a random factor in the future of space exploration and use.
First orbit change measurements after the DART impact are out. The orbit of Dimorphos has been shortened by 32 minutes. This is significantly more than the ~10 minutes they expected. It suggests a velocity change of around 5 mm/s, a bit under 1 mm/s of that from the motion of DART and the much larger rest from debris.
Updating orbit data of asteroids because we forced a change is fun.
5 mm/s * 10 years = 1600 km which is a significant distance for a deflection maneuver.
Future observations should give a more detailed view of the orbit change, and Hera will also measure the mass of Dimorphos directly, currently it's just an educated guess based on its size.
Do you have an idea of the change of scale involved to deal with a significant 'rogue' asteroid? I've always imagined that a useful system would need a massive vehicle to deflect a big one. We'd need to plan a deflection of a few hundred thousand km for a real whopper before we could rest easy. (I heard a radio reporter asking an 'expert' whether we could consider ourselves safe now. lol)
The ideal setup would be something large, put together in Earth orbit and sitting there, ready for a mission.
I was searching for some information but my search terms were clearly inadequate because everything I found is either very congratulatory of this particular project or too arm waving. We clearly have some way to go - although logging the possible asteroids seem (?) to have been largely sorted out.
We don't need more than ~10,000 km deflection (Earth radius and a bit for Earth's gravity). There is an angle between our ideal direction of deflection and the direction orthogonal to the asteroid approach, but that's the general scale. Most asteroids won't aim at the very center of Earth anyway.
Kilometer-sized objects are almost all known, for smaller ones we still have many to discover.
Dennis and Akiko Tito booked seats on a Starship mission around the Moon, likely the second one after dearMoon. Dennis Tito was the first space tourist in 2001, this time they want to fly around the Moon (with 10 other passengers on that flight).
Interview----
A Japanese Epsilon rocket had a launch failure, the first for this type of rocket and the first Japanese launch failure in 19 years excluding the test flights of the tiny SS-520.
Spooky double booster landing?
After three years, Falcon Heavy is back for a morning launch on October 31 (9:44 local time, 13:44 UTC). Both side boosters will return to the launch site, which is always a great view. The center booster will be expended. This is SpaceX's first mission directly to geostationary orbit, delivering some military satellites.
Another Falcon Heavy launch could happen as early as November, delivering commercial satellites, and the next military launch is scheduled for January. The latter should have the side boosters do simultaneous landings on drone ships for the first time.
LauncherOne will fly from Cornwall in the UK to launch a couple of smaller satellites on October 29. Apart from Plesetsk in Russia somewhere around the Europe/Asia transition, this should be the first orbital launch from Europe ever. Arianespace always flies from South America and the British Black Arrow was launched from Australia.
Edit: Polaris program research plan
It will be a busy flight. Almost all focused on human bodies in space. My favorite acronym:
Literally Looking at More Astronauts in Space (LLAMAS)
Success of the Falcon Heavy launch.
Rollout of the Artemis 1 rocket. Fourth time:
* Wet Dress Rehearsal in March/April
* Wet Dress Rehearsal in June
* Launch attempts in August/September
* Now preparing for a launch attempt in November (14th, 16th, 19th)
China is playing booster reentry lottery again: They launched a space station module with Long March 5B. It's a "1.5 stage" rocket, meaning one central stage with side boosters. That massive central stage (~21 tonnes) reaches orbit and doesn't have a controlled deorbiting mechanism, so it deorbits at a random spot a few days after launch. Re-entry is expected in around 7 hours in a band crossing Central America, Mexico and the US, most of Africa, parts of Australia and New Zealand and various oceans.
It will be a spectacular show, but some pieces will hit the ground.
They just don't seem to care. What would the cost overheads be for a controlled re-entry? A bit smaller payload, when you get down to it.
Hit the South Pacific. That's a popular spot for controlled re-entry as well, so they were lucky.
~3% payload decrease, cost is difficult to estimate - they would need to add some extra thrusters or make the engine restartable and make the stage live longer to aim at an ocean: Larger batteries, thermal design gets more important, and so on. It's definitely possible but it's not something you can simply change for an upcoming launch.
Well, no. I was rather assuming that would be built in to initial planning. An 'entry level' feature, in fact.
NASA successfully tested atmospheric reentry with an inflatable heat shield: LOFTID.
This was the last Atlas V launch from California, the remaining 19 launches will be from Florida.
Edit: Video from space
Starliner's first crewed test flight has been delayed from February to April, the first operational flight has shifted to 2024. This means SpaceX will launch the last flight of the original contract (Dragon Crew-6, February 2023) before Starliner flies any humans, and finish that flight (around September) before Boeing flies its first operational mission. If there are no further delays then Starliner-1 will replace the astronauts of Crew-7 in early 2024, Crew-8 will replace these in late 2024, and then both systems keep alternating until Starliner-6 and Crew-13 in 2029. NASA booked one more Dragon flight, which could happen in early 2030 as last crew of the ISS. At least on paper everything fits perfectly.
ABL Space Systems prepares its RS-1 rocket for the first flight next week or so, no specific launch date yet. At 1350 kg to low Earth orbit it's a very large rocket for a startup.
Firefly Alpha reached a lower than expected orbit in October, but the rocket for the third flight is being prepared for a launch in late November.
The crew for #dearMoon, a private Starship flight around the Moon, has been announced:
* Yusaku Maezawa, billionaire and the person paying for the program
* Tim Dodd aka Everyday Astronaut, spaceflight photographer, reporter and YouTuber. I'm sure he will extensively cover all spaceflight aspects of this mission.
* Steve Aoki, DJ and producer
* Yemi A.D., art director
* Dev Joshi, actor
* T.O.P, musician
* Karim Iliya, photographer (website?)
* Rhiannon Adam, photographer (website?)
* Brendan Hall, filmmaker (http://www.brendanhall.com/about)
9 people from 7 countries (3 are from the US).
Backup:
* Miyu, dancer
* Kaitlyn Farrington, snowboarder
It's a Starship development program - that's where most of the money goes - but it's more than that. Unlike the Apollo era, where all astronauts were white men from the US military (plus one geologist), it will be a much more diverse crew this time. They are all somewhat closer to "normal" people: They don't have a PhD and 5000 hours of flight experience in 10 aircraft at age 25. And they have a large audience to share their experiences with.
  • Wow
* Dev Joshi, actor
* T.O.P, musician
Backup:
* Miyu, dancer
One Astronaut? EDIT: Cover? If something happens to him? Seizure? Anything?
I wonder how many have already been training on the "Vomit Comet" aircraft... :wink:
sophiecentaur said:
I do get very enthusiastic about unmanned missions
Well, stable founding of heavy lifting (and, maybe: orbital operation) capacity helps that too. I can't wait to see what happens when the strict mass limits of deep space missions gets loose enough to deliver few ton worth of equipment (and power source) to Saturn in one go.
https://www.reuters.com/lifestyle/s...aft-cancels-russian-iss-spacewalk-2022-12-15/
Dec 15 (Reuters) - A planned routine spacewalk by two Russian cosmonauts aboard the International Space Station was called off on Wednesday after flight controllers noticed a stream of particles spewing from a docked Soyuz spacecraft, a NASA webcast showed.
A NASA commentator said the torrent of particles, which appeared to come from the rear section of the Soyuz MS-22 capsule, seemed to be liquid from the spacecraft, possibly coolant.
NASA said none of the International Space Station (ISS) crew was thought to be in any danger.
UPDATE of Dec 14: SWOT launch delayed 1 day to Dec 16
from: https://swot.jpl.nasa.gov/news/77/nasa-sets-coverage-for-swot-water-survey-mission-launch/
The mission is targeted for liftoff at 6:46 a.m. EST (3:46 a.m. PST) Thursday, Dec. 16, on a SpaceX Falcon 9 rocket from Space Launch Complex 4-East at Vandenberg Space Force Base in California.Live launch coverage will begin at 6 a.m. EST (3 a.m. PST) on NASA Television, YouTube, Twitter, the NASA app, and the agency’s website, with prelaunch and science briefings beginning Tuesday, Dec. 13.
That's now 3 planned Falcon 9 launches within 10 hours and 8 minutes.The maiden flight of Zhuque-2 (privately developed methane/oxygen rocket, ~3000 kg to orbit) failed, the second stage shut down too early. It's still the first methane-using rocket with an orbital launch attempt. Terran 1, Starship, Vulcan and New Glenn are in development or being prepared for a launch.
Here’s what we know, and what we don’t, about the damaged Soyuz spacecraft
The leak "stopped" when it ran out of coolant. The risk of overheating flight computers seems to be the main concern. ESA's robotic arm didn't see much, they'll try to get a better view with the Canadian arm. We should have more information early next week.
The Starlink flight was moved by one day, no double launch from Florida.
