Spacecraft attitude control MATLAB code errors
  • Context: Engineering
  • Thread starter Thread starter Valentino Derazi
3 replies · 2K views
Valentino Derazi
In the attached PDF
See control theory and attitude dynamics from SIDI Spacecraf
Good morning,
I have this homework attached as PDF with also a more explanatory image wrt the one in the PDF.
I tried to solve it (my code is attached below) but I get nonsense results. Could someone explain errors and fix my code? Unfortunately I'm not so good at MATLAB
Welcome to PF.
It might be better to attach your Matlab code as a *.txt file, so everybody can open it even if they do not have an active Matlab install on their PC. Alternately you can paste the code into the forum window using code tags: [ code ] <<your code here>>[ /code] (but without the spaces in the tags).
Also, can you say more about the "nonsense results" that you are seeing?
This is the code in txt format. As nonsense results I mean that as output I get something that does not meet the requirements given by the homework.
[code pasted in below by the Mentors]
Matlab:
function spacecraft_attitude_control_HW2_2025()
    clc; clear; close all;
    format long;
    %% Initialize Parameters
    global params;
    params = initialize_parameters();
    %% Request 1: Disturbance Torques and Uncontrolled Motion
    fprintf('=== Request 1: Disturbance Torques ===\n');
    simulate_uncontrolled_motion();
    %% Request 2: Control System Design (now with PID)
    fprintf('\n=== Request 2: Control System Design ===\n');
    design_control_system();
    %% Request 3: Saturation Analysis with Thruster Failure
    fprintf('\n=== Request 3: Saturation Analysis ===\n');
    [t_sat, ww_sat] = analyze_saturation();
    %% Request 4: Desaturation Maneuver
    if ~isinf(t_sat)
        fprintf('\n=== Request 4: Desaturation Maneuver ===\n');
        perform_desaturation(t_sat, ww_sat);
    else
        fprintf('\nNo wheel saturation detected - skipping desaturation maneuver\n');
    end
    %% Save Results
    save_results();
end
%% Parameter Initialization
function p = initialize_parameters()
    p = struct();
    % Constants
    p.mu_moon = 4903e9;                  % Moon's GM [m³/s²]
    p.R_moon = 1737e3;                   % Moon radius [m]
    p.altitude = 8000e3;                 % Orbital altitude [m]
    p.a = p.R_moon + p.altitude;         % Semimajor axis [m]
    p.n = sqrt(p.mu_moon/p.a^3);         % Mean motion [rad/s]
    p.arcsec = pi/648000;                % 1 arcsec in radians
    % Spacecraft properties
    p.Ix = 21000; p.Iy = 20000; p.Iz = 22500; % [kg·m²]
    p.Iw = 0.11;                              % Wheel inertia [kg·m²]
    % Reaction wheel
    p.ww0 = 271*(2*pi/60);                   % Initial speed [rad/s]
    p.ww_max = 2000*(2*pi/60);               % Max speed [rad/s]
    p.Tw_max = 0.236;                        % Max torque [Nm]
    % Disturbance parameters
    p.A = 34;                                % Solar array area [m²]
    p.Cs = 0.8;                              % Reflectivity coefficient
    p.cp_offset = 0.6;                       % Center-of-pressure offset [m]
    p.Phi = 1371;                            % Solar flux [W/m²]
    p.c = 299792458;                         % Speed of light [m/s]
    p.thruster_failure_torque = 0.008;       % Additional disturbance [Nm]
    % Thrusters
    p.Ft = 3;                                % Thruster force [N]
    p.b = 1.25;                              % Moment arm [m]
    % Initial conditions
    p.theta0 = deg2rad(-29.2537);            % Initial pitch [rad]
    p.dtheta0 = deg2rad(-0.0039);            % Initial pitch rate [rad/s]
    p.X0 = [p.theta0; p.dtheta0; p.ww0; 0];  % State vector [θ, θ̇, ω_w, ∫θ]
    % Control parameters
    p.thruster_failure = false;
    p.desaturation_mode = false;
    p.control_active = false;
    % Electrical parameters
    p.Km = 0.118;                            % Motor constant [Nm/A]
    p.Kw = 0.003;                            % Back-EMF constant [V/rpm]
    p.R = 1.5;                               % Resistance [Ohm]
    p.Pmax = 18;                             % Max power [W]
    % ODE options
    p.options = odeset('RelTol', 1e-8, 'AbsTol', 1e-8);
end
%% Request 1: Uncontrolled Motion
function simulate_uncontrolled_motion()
    global params;
    % Ensure control is disabled for uncontrolled simulation
    params.control_active = false;
    % Simulate uncontrolled dynamics for 1 hour
    [time, X] = ode113(@spacecraft_dynamics, [0 3600], params.X0, params.options);
    % Calculate disturbance torques
    T_grav = zeros(size(time));
    T_srp = zeros(size(time));
    for i = 1:length(time)
        theta = X(i,1);
        % Gravity gradient torque (φ=0 in this case)
        T_grav(i) = (3/2)*(params.mu_moon/params.a^3)*(params.Iz-params.Ix)*sin(2*theta);
        % Solar radiation pressure torque (Sun along X-axis)
        F_srp = (params.Phi/params.c)*params.A*(1+params.Cs);
        T_srp(i) = F_srp * params.cp_offset;
    end
    % Plot disturbance torques
    figure('Name', 'Disturbance Torques', 'Position', [100 100 900 700]);
    subplot(2,1,1);
    plot(time, T_grav*1e6, 'b', 'LineWidth', 2);
    title('Gravity Gradient Torque', 'FontSize', 14);
    grid on; box on;
    xlabel('Time [s]', 'FontSize', 12);
    ylabel('Torque [µNm]', 'FontSize', 12);
    set(gca, 'FontSize', 11);
    subplot(2,1,2);
    plot(time, T_srp*1e6, 'r', 'LineWidth', 2);
    title('Solar Radiation Pressure Torque', 'FontSize', 14);
    grid on; box on;
    % Plot uncontrolled attitude
    figure('Name', 'Uncontrolled Attitude', 'Position', [200 200 900 500]);
    plot(time, rad2deg(X(:,1)), 'LineWidth', 2, 'Color', [0 0.5 0]);
    title('Uncontrolled Pitch Angle', 'FontSize', 14);
    grid on; box on;
    ylabel('Pitch Angle [deg]', 'FontSize', 12);
end
%% Request 2: Control System Design (PID implementation)
function design_control_system()
    global params;
    % Tune PID controller
    wn = 0.05;       % Natural frequency [rad/s]
    zeta = 1.0;      % Critical damping
    params.kp = params.Iy * wn^2;
    params.kd = 2 * zeta * sqrt(params.Iy * params.kp);
    params.ki = 0.1;  % Small integral term to eliminate steady-state error
    % Enable control for simulation
    params.control_active = true;
    params.thruster_failure = false;
    params.desaturation_mode = false;
    % Simulate controlled system for initial acquisition (5 minutes)
    [time, X] = ode113(@spacecraft_dynamics, [0 300], params.X0, params.options);
    % Calculate control performance metrics
    theta = X(:,1);
    err = -theta;
    ww = X(:,3);
    % Calculate electrical parameters
    Tc = params.kp*err + params.kd*(-X(:,2)) + params.ki*X(:,4); % PID control torque
    iw = Tc/params.Km;                        % Current
    Vm = params.Kw*(ww*60/(2*pi)) + params.R*iw; % Voltage
    Pw = Vm.*iw;                              % Power
    final_error = abs(err(end));
    max_ww = max(abs(ww));
    max_err = max(abs(err));
    max_power = max(abs(Pw));
    fprintf('PID Controller Gains:\n');
    fprintf('kp = %.4f Nm/rad\n', params.kp);
    fprintf('ki = %.4f Nm/(rad·s)\n', params.ki);
    fprintf('kd = %.4f Nms/rad\n', params.kd);
    fprintf('\nControl Performance:\n');
    fprintf('Max pointing error: %.2f arcsec\n', max_err/params.arcsec);
    fprintf('Final pointing error: %.2f arcsec (requirement: <20 arcsec)\n',...
            final_error/params.arcsec);
    fprintf('Max wheel speed: %.1f rpm (limit: %.1f rpm)\n',...
            max_ww*60/(2*pi), params.ww_max*60/(2*pi));
    fprintf('Max power consumption: %.2f W (limit: %.1f W)\n\n',...
            max_power, params.Pmax);
    % Plot control performance
    figure('Name', 'Control Performance', 'Position', [100 100 1000 900]);
    subplot(3,1,1);
    plot(time, err/params.arcsec, 'LineWidth', 2, 'Color', [0.2 0.4 0.8]);
    yline(20, 'r--', '20 arcsec limit', 'LineWidth', 1.5);
    yline(-20, 'r--', 'LineWidth', 1.5);
    title('Pointing Error During Acquisition', 'FontSize', 14);
    grid on; box on;
    ylabel('Error [arcsec]', 'FontSize', 12);
    legend('Pointing Error', 'Limits', 'Location', 'best');
    subplot(3,1,2);
    plot(time, ww*60/(2*pi), 'LineWidth', 2, 'Color', [0.8 0.2 0.2]);
    yline(params.ww_max*60/(2*pi), 'r--', 'Max Speed', 'LineWidth', 1.5);
    yline(-params.ww_max*60/(2*pi), 'r--', 'LineWidth', 1.5);
    title('Reaction Wheel Speed', 'FontSize', 14);
    grid on; box on;
    ylabel('Speed [rpm]', 'FontSize', 12);
    subplot(3,1,3);
    plot(time, Pw, 'LineWidth', 2, 'Color', [0.5 0 0.5]);
    yline(params.Pmax, 'r--', 'Max Power', 'LineWidth', 1.5);
    title('Wheel Power Consumption', 'FontSize', 14);
    grid on; box on;
    ylabel('Power [W]', 'FontSize', 12);
end
function [t_sat, ww_sat] = analyze_saturation()
    global params;
    % Simulate nominal operation for 1 hour
    [time1, X1] = ode113(@spacecraft_dynamics, [0 3600], params.X0, params.options);
    % Simulate with thruster failure for extended period
    params.thruster_failure = true;
    [time2, X2] = ode113(@spacecraft_dynamics, [3600 18000], X1(end,:), params.options);
    % Combine results
    time = [time1; time2];
    X = [X1; X2];
    ww = X(:,3);
    % Find saturation point (after failure)
    post_failure = time > 3600;
    sat_idx = find(abs(ww(post_failure)) >= 0.95*params.ww_max, 1);
    if isempty(sat_idx)
        t_sat = Inf;
        ww_sat = 0;
        fprintf('Wheel does not saturate within 5 hours after failure\n');
    else
        t_sat = time(sat_idx + sum(~post_failure)) - 3600;
        ww_sat = ww(sat_idx + sum(~post_failure));
        fprintf('Wheel saturates at t = %.1f s after failure (%.1f%% of max speed)\n',...
                t_sat, 100*abs(ww_sat)/params.ww_max);
    end
    % Plot wheel speed history
    figure('Name', 'Wheel Saturation Analysis', 'Position', [200 200 1000 600]);
    plot(time-3600, ww*60/(2*pi), 'LineWidth', 2, 'Color', [0.1 0.6 0.3]);
    xline(0, 'k--', 'Thruster Failure', 'LineWidth', 1.5);
    title('Wheel Speed History After Thruster Failure', 'FontSize', 14);
    grid on; box on;
    xlabel('Time After Failure [s]', 'FontSize', 12);
    ylabel('Wheel Speed [rpm]', 'FontSize', 12);
    legend('Wheel Speed', 'Failure Time', 'Speed Limits', 'Location', 'best');
end
function perform_desaturation(t_sat, ww_sat)
    global params;
    % Find initial state at saturation
    [time1, X1] = ode113(@spacecraft_dynamics, [0 3600+t_sat], params.X0, params.options);
    X0 = X1(end,:)';
    % Perform desaturation
    params.desaturation_mode = true;
    desat_duration = 60; % Initial guess [s]
    [time2, X2] = ode113(@spacecraft_dynamics, [0 desat_duration], X0, params.options);
    % Calculate electrical parameters during desaturation
    Tc = zeros(size(time2));
    for i = 1:length(time2)
        ww = X2(i,3);
        if ww > 0.8*params.ww_max
            Tc(i) = -params.Tw_max;
            Tt = -2 * params.Ft * params.b; % Use both thrusters
        elseif ww < -0.8*params.ww_max
            Tc(i) = params.Tw_max;
            Tt = 2 * params.Ft * params.b; % Use both thrusters
        else
            Tc(i) = 0;
            Tt = 0;
        end
    end
    iw = Tc/params.Km;
    Vm = params.Kw*(X2(:,3)*60/(2*pi)) + params.R*iw;
    Pw = Vm.*iw;
    % Combine results
    time = [time1; time1(end)+time2];
    X = [X1; X2];
    % Analyze results
    theta = X2(:,1);
    ww = X2(:,3);
    recovery_idx = find(abs(ww) <= 0.1*params.ww_max, 1);
    max_pointing_err = max(abs(rad2deg(theta)));
    if isempty(recovery_idx)
        fprintf('Desaturation failed to return wheel to safe range\n');
    else
        fprintf('Desaturation successful in %.1f seconds\n', time2(recovery_idx));
    end
    fprintf('Max pointing error: %.3f deg (requirement: <1 deg)\n', max_pointing_err);
    fprintf('Max power during desaturation: %.2f W (limit: %.1f W)\n', max(abs(Pw)), params.Pmax);
    % Plot desaturation performance
    figure('Name', 'Desaturation Performance', 'Position', [100 100 1200 900]);
    subplot(3,1,1);
    plot(time-3600-t_sat, rad2deg(X(:,1)), 'LineWidth', 2, 'Color', [0.7 0.3 0.1]);
    yline(1, 'r--', '1° Error Limit', 'LineWidth', 1.5);
    yline(-1, 'r--', 'LineWidth', 1.5);
    title('Pointing Error During Desaturation', 'FontSize', 14);
    grid on; box on;
    xlabel('Time After Saturation [s]', 'FontSize', 12);
    ylabel('Error [deg]', 'FontSize', 12);
    legend('Pointing Error', 'Error Limits', 'Location', 'best');
    subplot(3,1,2);
    plot(time-3600-t_sat, X(:,3)*60/(2*pi), 'LineWidth', 2, 'Color', [0.1 0.5 0.7]);
    yline([params.ww_max, -params.ww_max]*60/(2*pi), 'r--', 'Speed Limits', 'LineWidth', 1.5);
    yline([0.1*params.ww_max, -0.1*params.ww_max]*60/(2*pi), 'g--', 'Safe Range', 'LineWidth', 1.5);
    title('Wheel Speed During Desaturation', 'FontSize', 14);
    grid on; box on;
    subplot(3,1,3);
    plot(time2, Pw, 'LineWidth', 2, 'Color', [0.6 0.2 0.6]);
    title('Power Consumption During Desaturation', 'FontSize', 14);
    grid on; box on;
end
%% Core Dynamics Function (updated for PID)
function dX = spacecraft_dynamics(t, X)
    global params;
    theta = X(1); dtheta = X(2); ww = X(3); err_int = X(4);
    T_grav = (3/2)*(params.mu_moon/params.a^3)*(params.Iz-params.Ix)*sin(2*theta);
    T_srp = F_srp * params.cp_offset;
    T_dist = T_grav + T_srp;
    % Additional disturbance if thruster failed
    if params.thruster_failure && t > 3600
        T_dist = T_dist + params.thruster_failure_torque;
    end
    % Control logic
    if params.control_active
        if params.desaturation_mode
            % Desaturation control logic
                Tc = -params.Tw_max;
                Tc = params.Tw_max;
            else
                Tc = 0;
                Tt = 0;
            end
        else
            % PID control with anti-windup
            err = -theta;
            derr = -dtheta;
            Tc = params.kp*err + params.kd*derr + params.ki*err_int;
            % Anti-windup protection
            if abs(Tc) > params.Tw_max
                Tc = sign(Tc) * params.Tw_max;
            end
            Tt = 0;
        end
    else
        % No control
        Tc = 0;
        Tt = 0;
    end
    % State derivatives
    dX = zeros(4,1);
    dX(1) = dtheta;
    dX(2) = (T_dist + Tc + Tt) / params.Iy;
    dX(3) = -Tc / params.Iw;
    dX(4) = -theta; % Integral of error (for PID control)
end
%% Utility Function
function save_results()
    if ~exist('Plots', 'dir')
        mkdir('Plots');
    end
    figs = findobj('Type', 'figure');
    for i = 1:length(figs)
        fig = figs(i);
        name = get(fig, 'Name');
        if isempty(name)
            name = sprintf('Figure_%d', fig.Number);
        end
        saveas(fig, fullfile('Plots', [strrep(name, ' ', '_') '.png']));
        saveas(fig, fullfile('Plots', [strrep(name, ' ', '_') '.fig']));
    end
end
I think you will need to give much more information if we are to be able to help you. Can you comment on how you are implementing the attitude control system, and also comment on this from the assignment:
1. Evaluate all the disturbance torques acting on the spacecraft along the pitch axis during this
time. Plot the evolution of the pitch angle in the absence of control torques.
2. Design an attitude control system compliant with the flight rules. Provide in the report the
constants describing the control algorithm. Comment on your choice and plot all relevant
quantities (offset angle and rate, wheel angular speed, torque, current and power).
After 1 hour the spacecraft experiences a minor malfunction of the attitude control thrusters that
causes a constant disturbance torque of 0.008 Nm along the spacecraft Y-axis.
3. Calculate how long the pointing window can be extended using the same control law designed
before, considering this new disturbance acting on the spacecraft. Report at which time from
𝑡" a desaturation maneuver becomes necessary.
4. Design the maneuver to maximize the interval between two consecutive desaturation
maneuvers. Consider a maximum pointing error of 1° only during the desaturation maneuver.
Report the time needed for the desaturation, plot and comment the results.
