Spanning sets and polynomials.
  • Thread starter Thread starter -Dragoon-
    Polynomials Sets
The discussion centers on whether the polynomials t^{3} + 2t + 1, t^{2} - t + 2, t^{3} + 2, and -t^{3} + t^{2} - 5t + 2 span the vector space P_{3}. The user attempts to solve this by setting up an augmented matrix and performing row reduction, ultimately finding that the coefficient matrix has a rank of 3. This indicates that the set of polynomials does not span the 4-dimensional space P_{3}, as a full spanning set would require a rank of 4. There is a discussion about the inconsistency of the system, with the conclusion that the set of polynomials cannot generate all vectors in P_{3}. Therefore, the polynomials do not span P_{3}.
-Dragoon-
Do the polynomials t^{3} + 2t + 1,t^{2} - t + 2, t^{3} +2, -t^{3} + t^{2} - 5t + 2 span P_{3}?
N/A
My attempt: let at^{3} + bt^{2} + ct + d be an arbitrary vector in P_{3}, then:
c_{1}(t^{3} + 2t + 1) + c_{2}(t^{2} - t + 2) + c_{3}(t^{3} +2) + c_{4}(-t^{3} + t^{2} - 5t + 2) = at^{3} + bt^{2} + ct + d
c_{1} + c_{3} - c_{4} = a
c_{2} + c_{4} = b
2c_{1} - c_{2} - 5c_{4} = c
c_{1} + 2c_{2} + 2c_{3} + 2c_{4} = d
Which becomes the augmented matrix:
\left[\begin{array}{cccc|c}1&0&1&-1&a\\0&1&0&1&b\\2&-1&0&-5&c\\1&2&2&2&d\end{array}\right]
Row reducing it, I come to the matrix:
\left[\begin{array}{cccc|c}1&0&1&-1&a\\0&1&0&1&b\\0&0&1&1&d-a-2b\\0&0&0&0&c-4a-3b+2d\end{array}\right]
Although the book did a different last row operation in the solution, I came to the same conclusion as they did except they had -2 in the 3x3 and 3x4 position rather than 1 as in my solution. Anyways, the book concludes the system is inconsistent regardless of specific values chosen for a, b, c, and d. But, wouldn't the system be consistent if a = b = c = d = 0? Then the fourth row would be [ 0 0 0 0 | 0], correct?
The point is that for any vector you should be able to come up with a linear combination of the coefficients to generate it.
Here, your coefficient matrix reduces to a rank 3 matrix, so your 4 vectors span a 3 dimensional space in P3. P3 is a 4 dimensional vector space and so there are definitely some vectors which you won't be able to generate.
Using an augmented matrix to figure out which vectors are spanned by your set is fine, but given the question "do the vectors span P3" you just need to see that the coefficient matrix is not rank 4 and therefore the set doesn't span P3.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
  • · Replies 18 ·
