Special relativity and acceleration
64 replies · 12K views · last reply
DrGreg said:
There's a misunderstanding here between Austin0 and sylas; you are talking about different things without realising it.
Ah. Thanks!
When Austin0 talks of "a set of clocks measuring the speed of light" he means you send light from clock A to clock B, measure the time of emission on clock A, measure the time of reception on clock B, and subtract the two times to give the time of transit. That method works when both A and B are stationary relative to the same inertial frame and the clocks have previously been synchronised in the standard way. It won't work when A and B are both stationary relative to the same accelerated frame, because, as has already been established, the clocks cannot stay in synchronisation.
Yes. You cannot have two synchronized clocks in the same accelerated frame but separated in space. Measuring the speed of light over a non-negligible distance within an accelerated frame (like my hypothetical accelerating spaceship of a non-negligible length) is (I think?) ambiguous, because it is not a Euclidean space, and will depend on how you assign co-ordinates.
On the other hand, sylas has in mind that each clock makes its own measurement of the local speed of light, independent of any other clocks. What does that mean? How do accelerating observers measure speed? The technical answer is that an accelerating observer asks an inertial oberver who happens to be momentarily traveling at the same speed (a "co-moving inertial observer") to make the measurement instead. In practice you can achieve the same end by using two clocks that are only a small distance apart (so the desynchronisation is negligible), or better still, consider the mathematical limit as the distance between the two clocks tends to zero. When an accelerating observer uses this method, they always measure the speed of light as c. That's what sylas meant.
Confirmed. That is precisely what I meant by having a clock that measures the speed of light, and indeed I thought of a set of clocks as all making their own independent measurements.
Hopefully you will each realize what the other was talkiing about and can now continue this thread in less confusion!
Thanks very much for your help there!
Cheers -- sylas
Added in edit: Stephen, let me attempt to answer your questions again more usefully!
Austin0 said:
If one way light speed tests were conducted between the front of the system and the back,,, and the back to the front , do you think that
A --- The tests would result in c as usual?
B --- The tests would result in asymetric and incorrect results due to the desynchronization due to the greater dilation that had occurred in the rear clock.
The clocks would have to be resynchronized with light?Measured how? Does this mean you would choose B in the post above?
The measurements I had in mind for measuring time dilation was a repeat of the measurement of gravitational time dilation in the Harvard tower experiment. One clock sends messages to the other with a known frequency, and the other measures a frequency. If they measure different frequencies, they are measuring a different time between messages, and hence measuring time dilation.
The clocks must be a fixed spatial separation, which can be established by reflecting the messages back to the source and having them received at the same frequency as transmitted.
But measurement of the speed of light as it goes from one clock to the other will be ambiguous, because it depends on how you decide to define space. An obvious "radar" space distance will mean all the clocks continue to measure the speed of light as c, but they will differ on how far light travels from one clock to the other. A distance defined by having a local measurement with a light clock at all points on the ship will mean that the clock in the rear will see light moving slower at the front, and a clock at the front will see light moving faster at the rear... I think.
Also I am unclear what means you are talking about when you say measured by the accelerated observers. DO you mean moving one of the clocks and making a direct comparison?
Finding an actual discrepancy in synchronization between the front and back??
Or with light tests revealing loss of synch??
I'm assuming measurements made locally by observers at the front and the back of the accelerating spaceship.
Cheers -- sylas
=DrGreg;2286000]There's a misunderstanding here between Austin0 and sylas; you are talking about different things without realising it.
Hi Dr Greg and thanks. You have got the above right, in spades.
I suspect that there would be no real fundamental differences on the priciples and practices of SR between us if it weren't for the semantic and situational confusion.
Exactly, with the additional requirement of a known distance dx
ANd this is not only a method of testing the synch of spatially separated clocks but also works to synch [set] clocks that are out of synch . Say, stopped for a period.
With a transmitted T (at source)from a synched system clock and a known dx/c= t
gives T + t = correct T (at receiver) which compared to the observed t of reception shows the interval of desynchronization for adjustment. Is there any problem with this?? I assumed it was standard SR convention.
It sounds like you are saying here that the answer to my question was that they would not be able to correctly measure light at c if they are spatially separated by a non-vanishingly small distance [at the opposite ends of the system]. Is this correct?
That is another interesting question. One that invoking ICMO's doesn't really solve does it?? Because to measure speed generally requires two observers . So you have two different instantaneously co-moving inertial frames instead of one accelerating frame that might possibly have a degree of desynch in its clocks. We know for sure that the two ICMIF's have different distances and times so I don't see a real difference.
In any case in this situation I was interested in the hypothetical method assumed for observers actually in the system to be able to observe [detect] dilation if it was present .
Thank you very much for your timely assistance and in put. Very ap[preciated. Stephen
Hi Sylas
If you are talking about what I think , it was a measure of electron emmissions and receptions of a particular frequency range. The reception statistics were reduced because of blue doppler shift of the photons or electron reception resonance frequency due to time dilation . Is this the experiment you mean? They accelerated the emmission source away from the receiver creating a comparable red shift in the photons and the absorption stats went right up.
If it is, I found it very interesting but the test parameters seemed too complex , with too many variables that are not yet completely sure themselves. I have read differing views on the action of gravity on light. That it does not effect the velocity but does doppler shift it.
That it does neither.
If clocks are dilated how would it be detected if it did increase in speed infintesimally.
Other GR explanations which seemed to say that it does go faster but not really?Too complex for me to follow.
Well that's certainly ambiguous. Kidding
Thanks for your input Stephen
Yes; it is the Pound and Rebka experiment, at Harvard, performed in 1959.
Shrug. I disagree; the experiment used clever techniques to detect tiny frequency changes, but there's nothing overly complex about it. More to the point, the experimental details don't matter. We're dealing with a hypothetical case of an accelerating spaceship; I am referring to the time dilation between front and back, and describing in principle how it can be measured. You can look at messages from one clock sent to the other with a known frequency. Time dilation will mean a change in the received frequency. I don't care how it is measured... the effect is real.
Clocks at the front and the back of an accelerating spaceship run at different rates, in precisely the same way that clocks at the top and bottom of the Harvard tower, or any other tower.
Another more direct experiment was done by a family with a physicist Dad. Dad took the kids up Mt Rainer for a weekend, along with three atomic clocks. Mum stayed home and worked, watching over atomic clocks left in the kitchen. The time difference showed up directly on the readings of the clocks. See [post=2177891]msg #10[/post] in thread "Gravitational Time Dilation - Confused" for pics and a description.
Basically, I am simply describing what happens to clocks in an accelerating spaceship. It is the same things as clocks separated from each other in a gravitational field. I don't really mind how you measure it. There are two methods given here for measuring the same time. Use messages sent at a known frequency. Or carry a clock slowly from one end to the other, leave it a while, and bring it back. Either way, you get a direct measure of the time dilation between clocks at the two locations.
I don't understand your question here. In principle, the speed of light is measured using a "ruler" and a "clock". The speed of light measured locally by any observer is always c. This applies regardless of velocities, accelerations or gravity.
I've explained how you detect time dilation at a remote clock, using two methods, both of which work as long as the remote clock remains at a fixed distance.
But measuring the speed of light over a long light path, moving beyond the local region of the observer, can run into issues if the spacetime geometry is curved somehow; as it is in an accelerating spaceship or in a gravitational field. In this case, the notion of speed over the whole path depends on co-ordinates chosen.
Cheers -- sylas
Hi I think I need to make it clear that I consider both the invariance of c and gravitational time dilation as empirically verified phenomena, there has never been any question there.
Time dilation due to acceleration is a theoretically validated phenomenon.
I am not rejecting it as a phenomenon or a theorem nor am I arguing against it.
I don't know enough about it yet to even have a strong opinion let alone question its actuality.
I don't accept it for exactly the same reasons.
I am just trying to learn about it. The principles and assumptions foundational to the theorem?. The parameters and postulated magnitude of the effect?. What different interpretations and ideas do different people have regarding it.?
I am working with the premise that it is actual and taking it for a spin to see the implications , detection methods , how it fits with other effects of acceleration , the measurement of light and on and on.
Of course I am being critical ,,to the limit of my powers of logical analysis.
I have no problem with the phenomenon itself, it is no stranger than a whole lot of other things, even strange,r that I now take for granted, I do have a problem with the idea of two clocks in different frames , desynchronized , that can still measure c accurately.
Unless the magnitude of the effect is so small as to be negligable. In any case this topic ,and acceleration in general, is going to require considerably more research and thought I ' m quite sure.
=sylas;2286898]Yes; it is the Pound and Rebka experiment, at Harvard, performed in 1959.
I wasnt referring to the complexity of their techniques which I am sure were fine. I was referring to the ambiquity regarding what exactly they were detecting. Was it doppler shift due to gravitational potential or was it time dilation? I understand you can say they are equivilent but at the same time they are two different phenomena. One is a modulation directly effecting a photon in transit. Eg; a photon from a source outside planet. Doppler shift.
The other is effecting the resonent frequency of electrons which then emit photons of a lower frequency. A la cesium. Time dilation.
I have had the same question regarding the redshift in spectra from the sum. It seems to be usually attributed to the potential effect on the photons in transit out of the well. So I have wondered why it wasnt assumed to be due to dilation effecting the source atoms. Or both. And how could we tell the difference?
I understand your reasoning when you view photon frequencies as "clock" periodicities.
But it also seems like there are real differences too, Light clocks have the same interval independent of the frequency of the light used. Frequency changes can occur without any temporal element involved , purely through relative motion. SO frequency change itself is not a sure indication of temporal dilation or expansion.
Be that as it may. The occurrence of frequency shift would definitely indicate either relative motion between the front and the back or time dilation in the absorbing detector.
Fair enough. This is plenty explicit and unambiguous.
Well thank you for your help and your patience with the communication confusion.
I have a lot of thinking ahead on these questions.
You can't, and that's because you're not talking about two different effects, but about two different descriptions of the same effect.
Fine, but consider this.
A photon traveling from a region of high gravitational potential to a lower, is lowered in frequency. SLower periodicity. Dillated.
A clock traveling the same path is increased in frequency. Faster periodicity.
And of course conversely. So the electron acts more like a clock and the photon acts like ,,well, a photon.
So it may ultimately be the same phenomenon and it all might be totally equivalent in the end.
Inertial motion,acceleration and gravity being simply different descriptions of a singular root but at this stage there appear to be relevant distinctions.
Thanks
...as measured with the clocks at the other location.
...as compared with photons coming from the other location.
Or, third viewpoint: neither the photon nor the clock is broken, it's just a different time there.
Well, logically, if time dilation exists for a clock moving relative to an inertial observer, then two clocks moving at two different speeds relative to an inertial observer must run at two different rates relative to the inertial observer. And the only way this is mathematically possible (if SR is correct) for two clocks "stationary" in an accelerated reference frame is if the clocks run at two different rates in the accelerated reference frame.
For a detailed derivation, I'd recommend Einstein's own derivation, but I can't find it on the net with a cursory quick search.
austin0 _______
=Ich;2292368]...as measured with the clocks at the other location.
austin0 _______
Also compared with clocks at either location. And the non-relative "actuality" of this can be empirically determined by simply leaving the moved clock in the new location for a period
and then by signal ,,comparing the elapsed time with the elapsed time on an unrelocated clock.
Or, third viewpoint: neither the photon nor the clock is broken, it's just a different time there .
You seem to be viewing this as a sort of SR ,, " which clock is really dilated" meaningless question.
I am looking at it from a completely different perspective. To me it seems that GR time dilation is purely a function of spatial location wrt the fixed gravitational space-time matrix.
As such it is absolute and not reciprocal wrt clocks at other locations.
If G is a clock on the ground at (g) and T is a clock at the top of the tower at (t) then the frequency ( f) of G = (f)[ G ,(g)] < (f)[ T, (t) ] not also (f) [T, (t)] < (f)[ G ,(g)]
If you want to consider photons as clocks then the analogous situation to what I described above would be : Two additional clocks E and P, colocated at (t) with (f)[ T, (t)]= (f)[ E, (t)] = (f) [P, (t)]
Moving them to (g) and finding that (f) [E (g)] = (f) [G (g)]
but ( f )[P(g)] > (f) [G ,(g)] or (f) [E (g)]
If we look at E and P as electron and photon with
(f)[ E, (t)] = (f) [P, (t)] as meaning equivalence of resonance (f) for absorption and emission
then ( f )[P(g)] > (f) [E,(g)] presents several possible explanations for the observed frequency differential
1-- the photon itself was directly changed by the translation through the potential gradient. This is the interpretation I read and mentioned above. (f) [P ,(g)] > (f) [P,(t)]
2---the differential is due to the actual difference in E ,, (f) [E,(g)] < (f) [ E,(t)]
and the difference in (f) P is only relative [not actual]
3-- both effects take place.
Empirically this would resolve by.
1--- if the difference in (f) P (f)[ P, (g)] - (f) [P, (t) = (f)[E,(t) - (f)[ E,(g)]
it would seem logical to adopt #2 above. And consider the photon unchanged as it is with doppler shift due to motion.
2 --- if (f)[ P, (g)] - (f) [P, (t) > (f)[E,(t) - (f)[ E,(g)] then it would appear that both were in effect.
The electron slowed down in E(f) and the photon actually increased P(f) while in transit.
SO does any of this clarify the question or make sense?
Thanks S
Not really.
But I like to emphasize that both "effects" are different viewpoints, so you certainly can't add their influence.
And that energy is intimately related to time, so a change in energy is a just different viewpoint of time dilation.
And that it does not matter whether the photon is unchanged or not. It appears differently to the upper observer, and GR doesn't care whether you explain that with a change of the observer or the photon.
=Al68;2292846]Well, logically, if time dilation exists for a clock moving relative to an inertial observer, then two clocks moving at two different speeds relative to an inertial observer must run at two different rates relative to the inertial observer.
Framed in this simple context the logic is both self evident and unquestioned.
But it seems to me that this situation is not at all that simple. That it implies and requires additional assumptions:
1-- Of course,, the axiom that everything is purely a coordinate transform and there are no physical implications to any relative effects..
2--That a single system can be considered as two independent frames. The fact that they are physically connected , not possibly having any effect or bearing on the consequences.
3-- That contraction is a purely spatial phenomenon. Negating any consideration that it may ultimately be a temporal displacement and may have unforseen effects on the clocks involved when acceleration is involved..
4--. That acceleration is fundamentally different from inertial motion. Is absolute not relative.
SO in this case we are calculating coordinate velocities and clock times in the rest frame and then jumping to the accelerating frame and assuming that they would apply there. At the same time assuming that the clocks in this frame are stationary wrt the frame and each other.
But viewed as two separate frames with different velocities they would not only, not be stationary , they would be at different distances from each other depending on which end you were measuring from.
Under the normal interpretation of SR , of course it is assumed that in whatever frame is under consideration the clocks are synchronized and the distances isometric. This would mean that whatever was calculated to be observed from another frame would be considered to be coordinate effects and would have no absolute interpretation. Like your transluminal velocities calculated for accelerating systems.
I can't help but think this is a little like calculating coordinate desynchronization as observed from one frame and then switching to the other frame and assuming the clocks are actually desynchronized.
I want to say again that I am not questioning the actuality or not of the phenomenon.
As to that, I have no view yet nor do I really care either way. It will just be another piece of the puzzle.
All of the above assumptions may be absolutely true.
I am just asking questions in the attempt to get together some kind of clear and logically coherant picture of the construct and how people interpret it. I think it is important , the whole question of acceleration , and so am spending a lot of time studying and thinking about it. But am finding it difficult to get definite answers. SO far on the invariance question I have received an unqualified yes, an unqualified no and an ,as yet ambiguous, yes and no.
DO you have a vote?? Thanks Stephen
=Ich;2296431]Not really.
I wasnt adding their influence. I was simply saying that IF empirical tests produced results that exceeded the expected magnitude arising from the gravitational differential between the emiting and absorbing "clocks" THEN there would be reason to assume that the photons were also directly effected.
IF not THEN occams razor would seem to choose the dilation in the measuring electrons as a complete and sufficient explanation.
I don't know of actual empirical tests other than the tower experiment. In that case the explanations I have read attributed the initial lack of absorption to a blue shift of the photons due to gravitational effects on the photon. My original question was ,,,why was this the viewpoint they chose.
In this view what is the change of energy effected through translating a clock,cesium atom, electron , from a region of low gravitational potential to one of higher?
And likewise for a photon??
Quantitatively I see what you are saying but isn't it significant as far as understanding the interrelationship between photons and gravity?
Thanks
Maybe because it's a quite common one: the photons gain potential energy while falling, just like any other thing would.
(in static spacetimes, like Schwarzschild)
Multiplication with g00, the time-time component of the metric.
For freely moving things like photons or falling clocks, g00 times particle energy (time component of its four momentum) is conserved.
I'm not sure this is helpful, however.
It is significant to understand that it does not matter. GR has no mechanisms that change clocks or photons. It is about relations of space and time, not malfunctioning clocks or broken photons.
I'm not making the first two assumptions. For the third one, the clock hypothesis (that a clock is unaffected by proper acceleration) is an assumption, so any conclusion about the reading of a clock in GR/SR is only valid for clocks which are unaffected by proper acceleration.
For number 4, the time dilation between clocks in an accelerated frame is derived from relative coordinate acceleration alone, independent of proper acceleration, and does assume the clock hypothesis.
Well, if a clock measures an elapsed time and stores the reading, the stored reading does not depend on any particular frame.
I can't figure out what you mean here.
Transforming coordinates from one frame to another is not "switching frames and assuming". Normally the transformed coordinates are correct by convention.
Similar to the way that 1 inch transforms to 2.54 centimeters. Sure assumptions are made, but the claim that 1 inch is "really" 2.54 cm is based on convention, not scientific theory. The way clocks are synchronized in SR, and coordinate times transformed between frames is based on convention, for simple convenience. There is no law of physics that says you must do it that way, but it's convenient to use a commonly used convention.
=Ich;2297818]Maybe because it's a quite common one: the photons gain potential energy while falling, just like any other thing would.
Could you explain what this means in the context of GR ?
In a classical interpretation, wouldn't it be said that; falling objects in a gravitational field loose potential energy while gaining kinetic energy or momentum [acceleration]
But as I understand GR the concept of acceleration does not apply in this situation and the path remains strictly inertial. If this is the case why would it be consistent to consider a photon gaining energy through translation through a potential gradient?
Does it also increase in velocity?
Are there test results as far as photon velocity with and against the gradient?
Based on the situation regarding frequency and your interpretation of it , I t would seem that with dilated clocks at higher potential areas [lower in the gradient] it would be expected that falling photons would be measured as moving at faster speeds by clocks with lower periodicity , than rising photons would be measured by clocks with higher rates.
Or at least this dilation factor would influence the actual measurements even if the empirical result was the opposite.
Is this the case?
I have read that photons actually travel slower in region of higher potential?
AS you surmised it is not immediately helpful. My knowledge of the mathematical structure of GR is only enough to instill a profound respect and give me a headache even contemplating actually learning it. A tensor in the neck.
AS regards falling clocks I can reach for an interpretation. As momentum ,velocity increase, conservation means that the time componenet must decrease ?
Isn't this generally true of physics? That was a problem of Newtonian gravity or electrodynamics, even now. We have quantifiable effects with no comprehensible mechanism to explain them. GR didnt explain or dispel the action at a distance conundrum, it just changed the terms. Whether you view electromagnetic interaction as directly between particles or as a field phenomenon or wave interference doesn't really make a difference in this regard.
But does that mean that human intelligence should stop seeking to understand deeper levels of cause?
And clocks and photons do undergo change in our perceptual empirical reality without be broken.
Thanks
____________________________________________________________________________
Hi Al68 I didn't mean to imply that you specificaly were making any kind of assumptions whatsoever. I was suggesting these particular ones as a partial list of implicit and necessary assumptions for the theorem to be logically valid. Or in an other perspective ; if any of these (axioms, assumptions, hypotheses) are not true, then the validity of the theorem is in question.
=Al68;2298039]I'm not making the first two assumptions. For the third one, the clock hypothesis (that a clock is unaffected by proper acceleration) is an assumption, so any conclusion about the reading of a clock in GR/SR is only valid for clocks which are unaffected by proper acceleration.
I am not familiar with the origen or timing of the "clock hypothesis" as such ,but I do know that as of very recently in this forum,, there were knowedgeable people who expressed views that acceleration did in fact induce dilation.
At this point it appears to be more than a mere assumption, as it has so far been validated by empirical testing.
But if you look at #3 I was not talking about dilation due to acceleration but about contraction and the possibility of it having a temporal origin and unkown effects on clocks. Ie: The possibility that the apparent movement through space [closer to the front] was in actuality a movement through time.
Well this is a somewhat different interpretation from what it seemed Sylas was saynig.
Which seemed to be that the difference was relative velocity between the front and the back. Which does imply #2
In light of your interpretation I have a question.
What is the difference btween proper acceleration in the system and coordinate acceleration as viewed from another frame?? If it is not empirically detectable as proper acceleration does giving it another name then make it observable?
If it is an actual phenomena why isn't it observed?? Simply because the magnitude is so slight as to be undetectable at our present state of technology??Or other?
This is of course absolutely true wrt real world clocks. But we are talking about hypothetical readings which may not be so independent
austin0
I think Sylas explained this nicely in the thread Invariance of c in ACCEL frames
I completely agree , with regard to inertial frames.
I don't think this analogy really applies. It is not a question of 1 in =2.54 cm but 4.67cm in S being equivalent to 7.9cm in S'
Isn't it actually the physics of the real world that determines the mathematical transform and the method of synchronization??
Thanks
The clock hypothesis says that a clock is unaffected by proper acceleration, eg: applied force, not coordinate acceleration, which is just the coordinate rate of velocity change in a specified reference frame. Those other knowledgeable people must have been referring to coordinate acceleration, which doesn't affect a clock's rate directly, but is a measure of the rate of change of coordinate velocity in a specific frame, which does affect a clock's rate (in that frame).
The front and rear of an accelerating spaceship would be at two different (but not independent) velocities with respect to an inertial frame. This is a consequence of SR, not an assumption.
They are equal if the other frame is the instantaneously co-moving inertial frame. But since that frame is different from moment to moment, they are rarely used as reference frames in a scenario, except sometimes one of them. Proper acceleration depends on force applied (thrust) and the mass accelerated, and is the same value in any frame. Coordinate acceleration, like coordinate velocity, depends on reference frame.
But the reason for that is convention as well. It's based on the SR simultaneity convention. If the proper length of my spaceship is 20 ft long, and an observer in relative motion at 0.6c measures the spaceship length by using light signals, he would use the SR simultaneity convention to determine the location of each end, and determine the ends to be 16 ft apart at a specified moment. Assuming a constant invariant light speed, the length of the ship in the other frame is 16 ft by convention. Length contraction is a result of convention, and invariant light speed.
Only in the same way as the standard method for converting inches to cm. The SR simultaneity convention, like other conventions, isn't a law of physics.
Neither is the clock hypothesis. It's a standard for what type of clock is valid in SR/GR. And of course there is no perfect clock, but some are close enough to that standard to give results consistent with SR/GR within a very small margin of error.
These conventions are used in a physical theory not as claims, but as useful tools. Alternative conventions could be used, and the final results would be the same, if the theory using the other conventions was otherwise equivalent to SR/GR.
Of course. I'm sloppy most of the time.
What is gravitational potential? If you look at it closely, it is not some local property of space. You can't measure the potential at any position.
Potential is an expression for a relation: the potential difference between two points is a number that tells you, for example, how much more energy a photon will have when measured at point 2 as when measured at point 1.
This is exactly how GR works also: there are no local circumstances that change clocks or photons. They always work fine.
Instead, GR describes the relation of spacetime at one event to spacetime at another event, with explicit predictions of how this relation shows up in measurements.
Generally, the relation is complex and path dependent.
In weak fields, at low speeds, however, the relation can be expressed as a single number. This number corresponds to potential in Newtonian gravity.
When light gains energy, it doesn't get faster, however.
=Ich;2303278]
Maybe I am once again misunderstanding but I thought that, as abstract constructions , the basis of both GR and electrodynamics was exactly that; assigning local values to points in the coordinate space? That those values [scalars, vectors, tensors etc]. were determined by the global conditions but were still local properties of space.
It is understood that you can't directly measure gravity at all
Why do you keep making comments like this implying that I am suggesting that one clock is right or another is broken?
Does this mean the measured velocity ,both empirically and theoretically, is invariiant , in this context, the same up and down the potential gradient?
Thanks
=Al68;2302912] ]
Subtle distinction there between different and independent
originally austin0
I understand the definitions of proper and coordinate acceleration. That was not my question. If acceleration of a frame results in dilation what difference does the semantical distinctions make with regard to its observation from another inertial frame.
Ie: Whether you call it proper acceleration or coordinate acceleration or consider it a velocity differential due to acceleration,,, why is it not detectable in the acceleration testing performed so far?
original quote austin0
__________________________________________________________________________-
But the reason for that is convention as well. It's based on the SR simultaneity convention. If the proper length of my spaceship is 20 ft long, and an observer in relative motion at 0.6c measures the spaceship length by using light signals, he would use the SR simultaneity convention to determine the location of each end, and determine the ends to be 16 ft apart at a specified moment. Assuming a constant invariant light speed, the length of the ship in the other frame is 16 ft by convention. Length contraction is a result of convention, and invariant light speed.Only in the same way as the standard method for converting inches to cm. The SR simultaneity convention, like other conventions, isn't a law of physics.
I think we completely disagree on this one. The Lorentz math is no more a convention than the inverse square proprtionality in gravity and electrostatics. There is no other possible expression. This is a description of fundamental aspects of reality and physicists of Andromeda would inevitably discover the same expressions although undoubtably with different conventional units.
Thanks
GR is formulated via local quantities, the curvature. Those quantities cannot be measured strictly locally, by their very nature you need to survey some finite region to measure them.
Also with EM, there are local quantities that define the field at each point. But these are locally measurable.
And the point I'm trying to drive home is that all those locally measurable quantities are totally independent of these local GR quantities. Local curvature doesn't influence the local E-Field in the least, both are independent by their very mathematical definition - where vectors and tensors "live in the tangent space".
As long as they are measured in a local free falling frame: yes.
I'm not sure I understand what you mean by "not detectable", but the difference between proper acceleration and coordinate acceleration is not semantical. The coordinate acceleration of any object can be made equal to any arbitrary value simply by the choice of a suitable reference frame.
Length contraction relies on not only the SR simultaneity convention, but the invariance of the speed of light, which is considered a law of physics. When I said that length contraction was based on convention, I should have said that the specific example (proper to coordinate length ratio) was based on convention, not the phenomena of length contraction itself. My bad.
=Al68;2307175]I'm not sure I understand what you mean by "not detectable", but the difference between proper acceleration and coordinate acceleration is not semantical. The coordinate acceleration of any object can be made equal to any arbitrary value simply by the choice of a suitable reference frame.
I will try to express myself more clearly. I was not suggesting that the difference between coordinate and proper acceleration was a matter of semantics.
You have a singular accelerating system and a unique set of observations as recorded in the system and an inertial frame. This is an unambiguous situation. Time dilation is either detected or it isn't as determined by comparison of proper elapsed time between the accelerated clocks and the inertial clocks after acceleration.
According to the actual real world tests performed so far to my knowledge,,,, there is no additional dilation due to acceleration. The dilation that has been recorded is totally accounted for by the dilation due to relative velocity. Ie: Due to the instantaneous velocities but with no additional factor due to the change in velocities.
This theorem posits that there is no dilation due to proper acceleration. There is no dilation due to coordinate acceleration. BUT there is additional dilation taking place due to the velocity differential resulting from acceleration.
That is what I meant about semantics. Simply calling it dilation due to a [Bvelocity[/B]differential from acceleration doesn't alter the fact that so far it is not detected.
I ,of course ,,cannot say that this is neccessarily true and is not simply a result of testing limitations etc etc. I also am taking the conclusions derived by the various mathematicians as valid without being able to perform the calculations myself. But can you simply dismiss the data in favor of a theoretical hypothesis?
Thanks
=Ich;2306276]GR is formulated via local quantities, the curvature. Those quantities cannot be measured strictly locally, by their very nature you need to survey some finite region to measure them.
OK this makes sense ,,,I wouldn't expect to be able to directly measure the field itself.
Vectors and tensors may live in "tangent space" but clocks dont. SO I don't follow how these local measurements can be totally independent of the field or curvature either. I thought particles were totally effected by the curvature and local quantities both in there paths and periodicity.
Previous austin0
Do you know of any actual tests done either from static locations at differing G altitudes or actual free fall tests?
See, that's why I keep reminding you not to think of broken clocks. A clock's "periodicity" is in no way effected bv local quantities. The best mathematical representation of "ticking rate" is indeed a vector (four-velocity), and as such lives in tangent space. Comfortably, I am told.
It's different with the path: local curvature defines how vectors, tensors and such change when being "transported" from one event to another. "Transport" can be a real transport, like moving a gyroscope around and observing how its axis - a vector - changes. Or a mathematical concept, like shifting A's four velocity through curved spacetime to the position of B's four velocity. That's the only way to compare vectors in GR, you have to bring both together, and it does matter how you do that. If the comparison shows that both don't point in the same direction: that's called time dilation.
I don't know any tests of light speed under awkward circumstances. But GPS, for example, depends on light behaving exactly like GR says, which, in turn, should coincide with what I say.
I see your point here. And you're right. What you say is not only supported by the data, but by theory as well. That is the crux of the clock hypothesis.
But semantically, I would disagree with the way you word this: "There is no dilation due to coordinate acceleration", simply because, by definition, this is the equivalent of saying: "There is no dilation due to coordinate velocity changes", which you point out, is not true.
Gravitational time dilation is both predicted by theory and supported by data, there is no contradiction. But whether the detected dilation is "gravitational" or "velocity based" depends on which coordinate system we choose. It's the same effect either way, both in theory and practice. Using the phrase "gravitational time dilation" is just a convenient way to explain the dilation of clocks which are "stationary" in an accelerated frame, but is the same dilation that would be referred to as "velocity based" when observed from an inertial frame.
austin0
=Ich;2309199]See, that's why I keep reminding you not to think of broken clocks. A clock's "periodicity" is in no way effected bv local quantities. The best mathematical representation of "ticking rate" is indeed a vector (four-velocity), and as such lives in tangent space. Comfortably, I am told.
See if I have this right. A clock at a specific location has a defined four-vector (periodicity). Translation to another location and comparison of four-vectors with a resident clock reveals that they don't point in the same direction =time dilation.
Is it not true that once colocated for comparison they will then have vectors that point in the same direction? That the time dilation is revealed by the difference in elapsed proper time , the clock reading. That the change in the moved clocks vector is not a SR result of its motion,, but is an incremental change due to the local curvature. Ie: measuring and responding to the local condition in the same way your gyroscope did.
I must be seriously misunderstanding here but I thought that tensors did not move but were constant values with fixed locations within the overall field?
austin0_________________________________________________________________________
I
Good idea. But from what I have been able to find it was not explicit if the transit time compensation was calculated at exactly c or not. But it did seem to be a single figure which should mean that the time from Earth to satellite is the same as satellite to earth.
Ill keep looking unless you have more defintie info.
Thanks
That's what I wrote, but
1. my description is not entirely correct (in fact it's wrong, but ok for the purpose),
2. I meant "difference in clock rate" instead of "time dilation".
All true. But like motion, that is a change relative to some other observer. While there is no locally defined "absolute direction" of said vector, just like there is no absolute velocity.
If you take the spin direction of a gyroscope as an example: that can be thought as fixed to the gyroscope's position and moving with it. Generally, we're talking about http://en.wikipedia.org/wiki/Parallel_transport" abstract mathematical procedure. Pure geometry, nothing to do with physics - except that SR and GR are also pure geometry, the latter at least with a coupling to mass.
I have been following with great interest the discussions in this thread, the comments on the interaction of gravity with light being of particular interest. I wonder if the following possibility has ever been considered:
Suppose that the presence of a gravitational field resulted in a modification of the product of the electric permittivity ε and the magnetic permeability μ of free space, which is the quantity which determines the velocity of light in free space according to the relation c^2 = 1/( ε. μ ) .
Suppose further that this resulted in a refractive index in a gravitational field which was a function of that field, possibly even a linear function. That would mean that the deflection of a light beam could be attributed to refraction by a changing refractive index, rather than directly to a gravitational force.
All the relevant equations could be changed by the inclusion of suitable factors which linked the value of refractive index to the gravitational field, thereby modifying the value of c to produce the same end result in every case. One major difference would be that it would no longer be necessary to deal with the distortion of space-time, because the resulting deflections could then be attributed to effects caused by changes in the refractive index of free space due to gravitational fields.
This interpretation would not for example change the result of the Pound-Rebka Harvard Tower experiment. The time-dilation produced by the gravitational red-shift would instead be interpreted as a change in the value of c, caused by the change of the refractive index, (due to the gravitational field) between the source and emitter, leading to the mismatch between the photon energies.
Would the concept of ‘gravitational time dilation’ even be necessary if what was really happening were changes in the value of c caused by a variable refractive index. The term ‘gravitational red-shift’ however, would still be entirely appropriate, since the result would still ultimately be due to the gravitational field, but by modification of the refractive index rather than by ‘time-dilation’.
