Calculating Energy Required for Temperature Change of Substance
  • Thread starter Thread starter Raihn
    Specific
The forum discussion focuses on calculating the energy required to raise the temperature of a 2.0g substance from 5.0°C to 15.0°C using the specific heat formula c = 0.20 + 0.14T + 0.023T². The correct approach involves integrating the specific heat capacity over the temperature range, leading to the equation Q = m∫(0.20 + 0.14T + 0.023T²) dT from T1 = 5.0°C to T2 = 15.0°C. The final calculated energy value, after proper integration, is Q = 9894.36 cal, confirming the importance of correctly applying calculus in thermodynamic calculations.
  • Understanding of specific heat capacity and its temperature dependence
  • Familiarity with integration techniques in calculus
  • Knowledge of thermodynamic equations, specifically Q = mcΔT
  • Ability to convert Celsius to Kelvin for thermodynamic calculations
  • Study integration techniques for polynomial functions in calculus
  • Learn about the implications of temperature-dependent specific heat in thermodynamics
  • Explore advanced thermodynamic equations and their applications
  • Practice similar problems involving variable specific heat capacities
Students in physics or chemistry courses, particularly those studying thermodynamics, as well as educators and tutors looking to clarify concepts related to heat transfer and specific heat calculations.
Raihn
The specific heat of a substance varies with temperature according to:
c = 0.20 + 0.14T + 0.023T^{2},​
with T in deg-C and c in cal/gK. Find the energy required to raise the temperature of 2.0g of this substance from 5.0C to 15C.
Q=mc\DeltaT
K= C + 273.15
Given:
m= 2.0g
Q=?
Q=mc\DeltaT
Q=m\int(0.2 + 1.4T + .023T^{2})dt
Convert C to Kelvin:
T1: K = 5.0 + 273.15 = 278.15K
T1: K = 15 + 273.15 = 288.15K
Solve for heat:
Q = [2.0g(0.2 + 1.4(288.15) + 0.23(288.15^{2})] -
[2.0g(0.2 + 1.4(278.15) + 0.23(278.15^{2})]
Q=2792.98
I don't think I did the math correctly can anyone please check it for me and tell me what I did wrong? Thank you in advanced.
-Raihn
Q=mc\DeltaT
K= C + 273.15
Given:
m= 2.0g
Q=?
Q=mc\DeltaT
Solve for heat:
Q=2792.98
-Raihn
Looking at this it doesn't look like you did the integral for the heat capacity? You should have 0.2T+1.4T^2/2 etc.
Why divide by 2? And I thought I did take the integral? I couldn't figure out how to add the 15 and 5 onto the integral sign, but I thought I did solve it in that manner? Maybe not? Now I've confused myself lol.
This is the value of the heat capacity?
Q=mc\DeltaT
K= C + 273.15
Given:
m= 2.0g
Q=?
Q=mc\DeltaT
This is your formula for Q
Solve for heat:
Here you have just subbed the value of c into Q=mc\delta T I see no evidence that c has been integrated?
You put the limits on like this (just click on the equation to see the source),
\int_{5}^{15}
and you divide by two because,
\int x dx=\frac{x^{2}}{2}
Oh ok, I see thanks a lot. Didn't notice I skipped that part. Thanks again.
Your welcome. Does the answer come out ok? If you need anymore help just ask.
I did it again and I got Q = 9894.36. I don't think that's right. This question is so simple I don't know why I'm not getting it.
Don't worry, it's only easy once you know it. Check your calculation again and post it here before you enter it, that way I can check it and hopefully you won't lose another attempt. I seem to be getting quite a big number.
Edit: Why don't you think it's right? Also I got confused with someone else, thought you were using a mastering physics package (me tired, sorry).
It's probably not clicking in my head since I'm studying for organic chemistry II and doing this at the same time, but this is what I did:
c = [0.20 + 1.4(288.15) + 0.023(288.152))] - [0.20 + 0.14(278.15) + 0.023(278.152)]
c = 494.78
Then:
Q=(2.0g)(494.718(288.15-278.15)
Q = 9894.36
Or is Q negative, where T1 = 278.15 and T2 = 288.15?
22K
