What Is the Final Temperature When Ice Melts in Water?
The final temperature when 0.50 kg of ice at 0°C is added to 1 kg of water at 20°C is calculated using the principles of thermal equilibrium. The specific heat of ice is 2000 J/kg°C, while the specific heat of water is 4186 J/kg°C, and the latent heat of fusion is 33.5 x 104 J/kg. The equation used is Q_gain(ice) = Q_lost(water), leading to a final temperature of approximately 0°C, as the energy required to melt the ice exceeds the energy available from the water before it cools to 0°C.
  • Understanding of thermal equilibrium principles
  • Knowledge of specific heat capacity and latent heat
  • Familiarity with energy conservation equations
  • Basic algebra for solving equations
  • Study the concept of thermal equilibrium in detail
  • Learn about specific heat capacity calculations
  • Explore latent heat and its applications in phase changes
  • Practice solving problems involving energy conservation in thermal systems
Students in physics or engineering, educators teaching thermodynamics, and anyone interested in understanding heat transfer and phase changes in materials.
cugirl
An insulated cup contains 1kg of water initially at 20 C. 0.50 kg of ice, initially at
0 C is added to the cup of water. The water and ice are allowed to come to thermal equilibrium. The specific heat of ice is 2000 J/kg oC, the specific heat of water 4186 J/kg oC, the latent heat of fusion of water is 33.5x104J/kg. What is the final temperature of the water?
(A) 0 C
(B) 1.2 C
(C) 4.6 C
(D) 9.2 C
(E) 15.2 C
mc(Ti-Tf) = mLf + mc(Tf-0)
(1.0)(4186)(20 - Tf) = (.5)( 33.5x104 ) + (.5)(4186)(Tf)
83,720 – 4186Tf = 167,500 + 2093 Tf
-83780= 6279 Tf
-13.3 = Tf
Correct method
But what is the total energy needed to melt the ice?
How much energy can you get from the initial water before it cools to 0c?
