Calculating the Speed of a 796eV Electron
  • Thread starter Thread starter skibum143
    Electron Speed
The speed of a 796 eV electron can be calculated using the kinetic energy formula, Ek = 1/2 mv². The correct conversion of electron volts (eV) to joules (J) is crucial, where 1 eV equals approximately 1.602e-19 J. By substituting the values, the equation becomes 796 eV = 1/2 * 9.11E-31 kg * v², leading to the correct calculation of speed as v = sqrt(2 * 796 * 1.602e-19 / 9.11E-31), resulting in approximately 4.18E6 m/s. Proper unit conversion and careful mathematical manipulation are essential for accurate results.
  • Understanding of kinetic energy equations
  • Knowledge of unit conversion from electron volts to joules
  • Familiarity with fundamental constants such as Planck's constant and electron mass
  • Basic algebra skills for solving equations
  • Learn about the conversion of energy units, specifically eV to J
  • Study the application of kinetic energy formulas in particle physics
  • Explore the implications of relativistic effects on electron speeds
  • Investigate the significance of Planck's constant in quantum mechanics
Students in physics, particularly those studying particle dynamics, educators teaching energy concepts, and anyone interested in the calculations involving electron behavior in quantum mechanics.
skibum143
What is the speed of a 796eV electron?
E = hc/lambda
E = hv
I'm not sure how to get a value for meters... I know if I take h (plank's constant) and divide the electron, I will get 4.14E-15 ev*s / 796 eV = 5.20E-18 seconds, but that is just a time, i don't know how to get the distance for that time...
That energy is entirely kinetic.
Ek=1/2 mv2
If 796 = 1/2 * 9.11E-31 * v^2, I get v to be 4.18E16 m/s which is wrong...i'm not sure what I'm doing wrong...
Watch your units.
I tried converting eV to joules, which gave me 1.27E-16 joules, which gave me 8.36E6 m/s but that is wrong too. I think the units for mass (kg) are correct, I'm not sure what I have wrong...
Check your math.
For:
796 = 1/2 * mv^2 (where m = 9.11E-31) I keep getting 4.18E16 for v
I don't understand what part I'm doing wrong, I've done it about ten times...
Show how you solved for v.
eV = 1/2 mv^2
eV / (1/2m) = v^2
v = sqrt (eV / 1/2m)
Am I doing this wrong?
So far OK.
Seems to me like somehow you are misplacing 2 when calculating value.
I'm using
m = 9.11E-31
eV = 796
796 = 1/2*9.11E-31 v^2
796 = 4.55E-31 v^2
1.748E33 = v^2
v = 4.18E16
Don't know where I'm wrong...
Seems like my guess was wrong. You have ignored my earlier remark about using correct units. Sigh.
I didn't ignore it, I don't understand where my units are wrong. eV, m = kg
If you would tell me which part I'm doing wrong I could try and fix it.
Nevermind, I got it myself. I was using the wrong value to convert eV. Thanks anyway
You have to convert eV to J, from what you wrote you were assuming 796 [eV] = 1/2 9.11E-31 [kg] * x2 [m/s]2. eV is NOT kg*m2*s-2, it is about 1.602e-19 kg*m2*s-2 (or 1.602e-19 J).
  • · Replies 56 ·
