What is the final speed of a block and the angular speed of a pulley?
  • Thread starter Thread starter pcandrepair
    Block Speed
The discussion revolves around calculating the final speed of a block and the angular speed of a pulley in a physics problem involving energy methods. The block has a mass of 0.830 kg, and the pulley is a hollow cylinder with specific dimensions and mass. Initial calculations for the block's final velocity yielded incorrect results, prompting users to reassess their equations, particularly regarding the inclusion of friction and the rotational kinetic energy of the pulley. After multiple iterations and corrections, the final speed of the block was determined to be approximately 1.60535 m/s, leading to an angular speed of about 44.52 rad/s for the pulley. The conversation highlights the importance of careful attention to detail in physics calculations, especially when dealing with energy conservation principles.
pcandrepair
[SOLVED] Speed of a Block
The sliding block has a mass of 0.830 kg, the counterweight has a mass of 0.430 kg, and the pulley is a hollow cylinder with a mass of 0.350 kg, an inner radius of 0.020 m, and an outer radius of 0.030 m. The coefficient of kinetic friction between the block and the horizontal surface is 0.250. The pulley turns without friction on its axle. The light cord does not stretch and does not slip on the pulley. The block has a velocity of 0.820 m/s toward the pulley when it passes through a photogate.
(a) Use energy methods to predict its speed after it has moved to a second photogate, 0.700 m away.
_________ m/s
(b) Find the angular speed of the pulley at the same moment.
_________ rad/s
Moment of Inertia for a hollow sphere: Icm = 1/2 M (R1^2 + R2^2)
Friction = \mu*M1*g*diameter
For part A i used the following equation to solve for the final velocity:
1/2(M1*Vi^2) + 1/2(M2*Vi^2) - friction = 1/2(M1*Vf^2) + 1/2(M2*Vf^2) + M2*g*h
1/2(.83Kg * (.82m/s^2)) + 1/2(.43Kg * (.82m/s^2)) - (.25)*(.83Kg)*(9.8)*(.7m) = 1/2(.83Kg * Vf^2) + 1/2(.43Kg * Vf^2) + (.83Kg * 9.8 * .7m)
-1 = 1/2 Vf^2 (.83Kg + .43Kg) + 2.9498
Vf^2 = -4.5371
Vf = 2.13 m/s
This answer is incorrect. I cannot figure out where I went wrong. If someone could help me out, it would be much appreciated. Thanks!
I also tried part b with this number. I'm pretty sure this is the correct formula but I need the right number from part a to get the correct answer.
V = R\omega
\omega = V/R
\omega = (2.13m/s) / (sqrt((.02^2) + (.03^2)))
\omega = 59.0756 radians/sec
In calculating the change in PE, note that the hanging mass lowers. The change in height should be negative.
When I use a negative height, I get 1.75888 m/s and it tells me my answer is wrong but within 10% of the correct value.
You also forgot the rotational KE of the pulley.
I added 1/2 Iw^2 to each side using the initail veloctiy for w on the left side and w on the right side is the same as the Vf on the right side? When I do this I'm getting 2.397m/s which wouldn't be in the 10%.
\omega = v/r, where r is the outer radius.
Now I'm getting 1.75919 m/s. This seems way to close to my answer from post #3.
If you spell out the entire equation you are using (like you did in post #3) and show the intermediate values you get, I'll look it over.
1/2(M1*Vi^2) + 1/2(M2*Vi^2) - friction + 1/2 (I)(V/R)^2 = 1/2(M1*Vf^2) + 1/2(M2*Vf^2) + M2*g*h + 1/2 (I)(V/R)^2
I found (I) to equal .000228
1/2(.83Kg * (.82m/s^2)) + 1/2(.43Kg * (.82m/s^2)) - (.25)*(.83Kg)*(9.8)*(.7m) + 1/2(.000228)(.82/.03)^2 = 1/2(.83Kg * Vf^2) + 1/2(.43Kg * Vf^2) + (.83Kg * 9.8 * .7m) + 1/2(.000228)(V/.03)^2
-.999761 = .415 Vf^2 + .215 Vf^2 - 2.9498 + .000114 Vf^2
1.95004 = .630114 Vf^2
Vf^2 = 3.09474
Vf = 1.75919 m/s
Double check that first number; I get a significantly different number.
I recalculated the -.999761 and got -.914667. Then I got 1.79716 m/s and it's still wrong.
See below:
Double check the highlighted number (work done by friction). [Edit: That's the change in gravitational PE, not work done by friction.]
that number is the M*g*h for the hanging mass which should be right. did I forget to include friction on the right side of the equation?
I mislabeled it as work done by friction, but I meant the M*g*h for the hanging mass. Double check that number.
Ah, you have a typo: You wrote .83 instead of .43.
(.43Kg)*(9.8m/s^2)*(-.7m) = -2.9498
I'm getting the same number from before.
one more
I think you forgot the (1/.03)^2 factor when you calculated that last term.
Now I'm getting 1.60535 m/s.
Ok. That 1.60535 is correct. For part b now, would i just use V = Rw to find the angular speed. So,
w = 1.60535 / sqrt(.02^2 + .03^2)
w = 44.5238 and this would be in rad/sec?
I used the wrong radius in the previous post. I used .03 and got the right answer. Thanks for all your help Doc Al!
