Speed of gravity vs. speed of light
The discussion centers around the observed time difference between the arrival of gravitational waves and gamma rays from the GW170817 event. Participants explore potential explanations for the 2-second delay, considering factors such as the nature of the signals, the collision process, and the effects of the interstellar medium.
  • Some participants suggest that the 2-second difference may not indicate a speed difference but could relate to the collision process and the geometry of the event.
  • Others propose that gravitational waves experience less scattering than light, which could account for the observed timing difference.
  • It is noted that gravitational waves increase in amplitude and frequency as the binary system approaches, while gamma rays may represent a discrete event during the merger.
  • Some argue that the gamma ray burst likely did not occur at the same moment as the peak of the gravitational wave signal, as it could be influenced by surrounding plasma dynamics.
  • A participant raises the question of whether measuring higher frequencies of gravitational waves could reduce the observed time difference, seeking estimations on this possibility.
  • One participant inquires about the potential effects of the interstellar medium on the gamma rays, suggesting that even a small effect could be significant over the vast timescale of 130 million years.
Participants express differing views on the implications of the 2-second delay, with no consensus reached regarding the underlying causes or whether it indicates a fundamental difference in the propagation of gravitational waves and light.
There are limitations in the discussion regarding the assumptions made about the nature of the signals and the potential effects of various environmental factors, which remain unresolved.
exponent137
GW170817 showed that gamma rays came 2 seconds after gravitational waves. (after 130M years) Are these two seconds uncertainty at determination of difference of these speeds? Or is it possible to explain, why 2 seconds of difference, or is it possible to explain, at least, a part of this difference?
I think it has more to do with the collision process and the geometry of the collision than a speed difference but I'm sure folks are actively investigating this difference to explain it.
http://ligo.org/science/Publication-GW170817GRB/flyer.pdf
Of course this could be nature's way of letting us see both events ie grav wave signal gives us a clue of where to point our scopes and then the gamma rays arrive for us to record them.
It's also possible, though remote, that they signal different events entirely although the article says that's a 1 in 20 million chance in which case the 2 second delay is just coincidental.
I'd say gravitational waves don't suffer from the same amount of scattering as light waves. Light can be scattered or bend from dust or other types of mass, while gravitational waves (to first order!) are not.
<< Note -- typo corrected >>
Those gravitational waves arrived here a long long time ago. They were gradually increasing in amplitude and frequency as the binaries were getting closer together and were detected when they exceeded the sensitivity threshold of the instrument. There was no discrete arrival moment.
The gamma burst on the other hand is probably a discrete event happening at a specific moment during the merger.
No, they're showing that whatever process produced the gamma ray burst did not happen at the exact same moment as the peak of the gravitational wave burst. Since the gamma ray burst was probably produced by something happening in a cloud of plasma surrounding the black hole merger, there's no requirement that it had to happen at exactly the same instant as the gravitational wave peak from the merger itself.
According to Jedishrfu link : http://ligo.org/science/Publication-GW170817GRB/flyer.pdf figure 2 - the fourth panel - the signal was stopped 1.7 seconds before gamma rays, also because LIGO-VIRGO cannot measure very high frequencies.
Let us imagine that it possible to measure any frequency of gravitational waves. Would this reduce this difference 1.7 s? Is any estimation, how?
I think your explanation must be correct.
It intuitively seems that if we assume that a gravity wave and electromagnetic move at the same velocity, we should be able to locate a ring location around the star merger center in which the gamma ray burst would have to be subsequently triggered for it to take the later eta unless it somehow came from partially behind the merger center. Does that make sense?
I suppose the resolution may not be fine enough to differentiate any of this in actual observation.
Wes
Has anyone looked at how much the interstellar medium would slow the gamma rays? It'd be a tiny effect, but so is 2 seconds in 130 million years. I have no intuition on the numbers offhand.
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 45 ·
  • · Replies 42 ·
  • · Replies 34 ·
  • · Replies 25 ·
