Speed of light enough to escape black holes ?
silvercrow
I wad thinking since black holes are so dense ... lights speed would get slow significantly , so isn't it that if you are at light speed ( 3 x 10^8 m/s ) then you might come out of a black hole ?
Its the same concept we learn in 10 grade !
Am i right ?
No, the escape velocity of a black hole is c - by definition.
But light doesn't escape because it slows down ? :p
I believe this is more of a General Relativity question?
Yes, it cannot escape the event horizon.
That is an easy way to remember it, though technically it's that there are simply no paths through spacetime that lead out from beyond the event horizon. However if you don't have a basic understanding of General Relativity just remember that light is "pulled" back in.
In other words, once you are inside, all directions are "towards" the center. There is no "outwards" direction for your flashlight.
The "escape velocity" analogy isn't a good one. When an object is ejected/launched radially at escape velocity its speed is reduced as measured by local observers along its path until at infinity it has slowed to zero speed. However, light always moves a c as measured by observers locally. And, light does not leave the Schwarzschild radius even though according to the escape velocity analogy it should get to infinity.
Am i right ?
Light, climbing out of a gravitational well, doesn't slow down, it loses energy. This increases the wavelength (reduces the frequency). At the horizon it's frequency is zero.
Not really. Light emitted outward exactly at the time someone crosses the event horizon will simply "hang" at the event horizon, not loosing or gaining energy.
Someone else falling into the black hole on the same trajectory can see the light left there, an image of the previous traveller.
No physical observer can hover at the event horizon. Any physical observer passing through the event horizon , using their own local clocks and rulers ,will measure the speed of any trapped light there to be equal to "c", just as they would measure the speed of any other light to be "c" (with the same conditions, the measurement must be a local one).
The above requires exact timing. If you consider a bunch of photons emitted over a period of time from an infalling object, (more realistic), as time advances a smaller and smaller number of the photons will be close enough to the exact time to be close to the event horizon. Those that are emitted "too late" will fall into the central singularity. Those emitted "too early" will escape to infinity.
Reference: see for example http://casa.colorado.edu/~ajsh/singularity.html#r=1, Hamilton's website on black hole's. Hamilton is a physics professor with several published papers on black holes.
hamilton said:
At this instant, as we pass through the horizon into the Schwarzschild bubble, we see all the other persons who passed through this location before us also pass through the horizon into the bubble.
That is a bit difficult for me to picture. What I do understand is how Einstein calculated light bending in a gravitational field with the Huygens construction; such gravitational lensing is a true physicists approach. However, considering that method, it is not clear to me why perfectly "outwards" should not be possible. What exactly prevents this possibility in terms of that approach?
Actually (let's pretend supermassive black hole with minimal tidal forces after crossing horizon; as usual, ideal SC geometry), after you cross the horizon, up until you crunch, you can point your flashlight any direction, and locally see its light move away from you at c in any direction (assuming, further, you are inertial). So, locally (as required by definition of semi-riemannian manifold), everything still looks Minkowski sufficiently locally.
However, if you define radial position in terms of circumference of a circle about the singularity / 2 pi, what happens is: your radial coordinate is decreasing much faster than the outgoing light (which is also moving - slowly - in the decreasing r direction). Note, that if someone falls in shortly after you, you can continue sending them light signals until you reach the horizon. To you, they are outgoing light signals, meeting this later infaller who is futher from the singularity than you. In terms of r coordinate, everything is ingoing, but at different rates.
A key point is that a line of constant r (as defined above) is a spacelike curve inside the horizon. Thus, a light like path must decrease in r with increase in its affine parameter.
[Upshot: I would qualify mfb's statement: all timelike or light like directions inside the horizon point in a decreasing r coordinate direction; outgoing r directions exist, but they are spacelike.]
OK... that I understand. Now, the Huygens method is non-local, as pictured from a distant frame far in space. So, I guess that my question boils down to asking how to transform that description into a description based on such a non-local frame.
Thanks, but that isn't a Huygens construction - not even a "non-local" description. If someone can translate the above into a non-local description, that would be very helpful for me and no doubt many others. I guess that I put my finger on the Schwartzschild singularity issue. :-p
Aren't clocks supposed to stop at the Schwartzschild radius and should thus also the frequency of light emitted from that point be zero? How can frequency be anything less than zero? :confused:
When searching a little about this question I found this:
http://casa.colorado.edu/~ajsh/schwp.html
(I only read the first half)
as well as this:
http://blogs.discovermagazine.com/badastronomy/2007/06/19/news-do-black-holes-really-exist/
That makes sense to me.
There is also an interesting discussion included which I did not yet fully read; post 10 provides a slight correction in phrasing by the author.
I don't know anything about this Huygen's method. It is not used in any texts I have or papers I've read on gravitational lensing (at least by that name). I've studied methods that simply follow null paths in SC coordinates.
The r coordinate I've described is simply the Schwarzschild coordinate r coordinate - I've given its physical definition. In contrasting the local inertial frame observation that you can point a flashlight in any direction, of flash a bulb and get a spherical wave front, with the global statement that all timelike or null paths (inside the EH) progress toward the singularity, you must define some such global coordinate. I don't know of any simpler coordinate for this purpose than SC r coordinate.
This false belief has been refuted numerous times on these forums. It's all about relativity. A distant or external hovering observer sees infalling clocks slow and their emitted light redshift, as they approach the horizon. The infalling observer sees no such thing. Their clock proceeds normally right up to the singularity, and they see external clocks also proceeding at a normal rate (slower or faster depending on the exact infall trajectory, but with a strictly finite Doppler factor).
One way of explaining this asymmetry is simply noting that ingoing light has no trouble decreasing r coordinate to the singularity; while outgoing light has increasing 'difficulty' escaping as the EH is approached, up until not escapting at all if emitted at the EH (or inside). Personally, I do see this [freezing of clocks as viewed external to EH] as purely an gravitational optical effect [on outgoing light], somewhat analogous to Lene Hau's freezing light in a BEC.
I wa thinking since black holes are so dense ...lights speed would get slow significantly...
What do you mean by this? It appears you may be thinking of a black hole, inside the event horizon, as dense matter??...so 'light would slow' as, for example, in glass or fiber optic cable??
That is NOT what is believed to be inside a BH event horizon...all the mass that caused the original BH to form is crushed from existence and resides at the singularity.
There is a good discussion about spacetime geometry inside a black hole here:
http://www.jimhaldenwang.com/black_hole.htmIn summary here is what you get inside a black hole horizon...all the way to the singularity at the center of the BH:
[r = 2M is the Schwarzschild radius, the location of the BH horizon]
[In GR] It is the coordinate with the minus sign that determines the meaning of “timelike. ... inside the event horizon, r is the timelike coordinate, not t. In GRT, the paths of material particles are restricted to timelike world lines. ... According to GR, inside a black hole, time is defined by the r coordinate, not the t coordinate. It follows that the inevitability of moving forward in time becomes, inside the black hole, the inevitability of moving toward r = 0. This swapping of space and time occurs at r = 2M. Thus, r = 2M marks a boundary, the point where space and time change roles. For the observer inside this boundary, the inevitability of moving forward in time means that he must always move inward toward the center of the black hole at r = 0.
PAllen said:
I don't know anything about this Huygen's method. It is not used in any texts I have or papers I've read on gravitational lensing (at least by that name). I've studied methods that simply follow null paths in SC coordinates. [..]
:rolleyes: It was the method that Einstein famously used to calculate the light bending by the Sun. On this forum I elaborated on that several times, with a link to the paper. Here once more: https://en.wikisource.org/wiki/The_...erihelion-motion_of_the_paths_of_the_Planets..
This false belief [of http://casa.colorado.edu/~ajsh/schwp.html] has been refuted numerous times on these forums.
That would mean that the only references that I found elsewhere are wrong according to refutations on this forum. In case you or someone else remembers any of such refutations that give a correct "distant" perspective instead, a link to it would be great! :smile:
It's all about relativity. A distant or external hovering observer sees infalling clocks slow and their emitted light redshift, as they approach the horizon. The infalling observer sees no such thing. [..]
Yes, that is obvious (well, to me it is) and not in question! :smile:
One way of explaining this asymmetry is simply noting that ingoing light has no trouble decreasing r coordinate to the singularity; while outgoing light has increasing 'difficulty' escaping as the EH is approached, up until not escapting at all if emitted at the EH (or inside). Personally, I do see this as purely an gravitational optical effect, somewhat analogous to Lene Hau's freezing light in a BEC.
According to the second link that I gave, it is an unrealistic assumption that there would be anything to emit light "at or inside" the EH; seeing the there provided arguments, that made perfect sense to me.
In reference to the quote in #15, while this description is often given, it is not quite accurate IMO. The switching places of r and t in SC coordinates is primarily a coordinate effect that disappears in a number of well behaved coordinate systems for this geometry. The change of role for t is exclusively the result of defining it so that fixing r,theta,phi and varying t labels points on spheres of fixed surface area (each distinguished by a different t). Since a path inside the EH that does not progress toward the singularity is spacelike, t labels points on the spacelike path, so it becomes spacelike.
Instead, consider Lemaitre coordinates. Here, you have a radial coordinate that remains spacelike all the way to the singularity, and a time coordinate that remains timelike all the way to the singularity. This is achieved by allowing the radial coordinate to be non-static (effectively describing a collapsing space). Specifically, fixing radial and angular coordinates and varying Lemaitre time coordinate produces a path connecting spheres of decreasing surface area.
The key physical statement about interior SC geometry is just that all timelike and null paths reach the singularity.
Well then I've just not heard it called Huygen's, and don't see much difference between it and other methods.
harrylin said:
That would mean that the only references that I found elsewhere are wrong according to refutations on this forum. In case you or someone else remembers any of such refutations using the "distant" perspective that I'm after, a link to it would be great! :smile:
The statement I was responding to was:
"Aren't clocks supposed to stop at the Schwartzschild radius and should thus also the frequency of light emitted from that point be zero? How can frequency be anything less than zero?"
The key point being that the understanding: "Only from the point of view of an external observer"
is missing. The reputable sources have this understanding.
You mean the arguments described in Discover magazine? The classical portion of these have been raised and refuted many times. External observers are seeng a frozen image - that is all. They can deduce that the object has reached the singularity. Specifically, they can compute when to send a signal such that the infaller will receive it an instant before reaching the singularity. The argument about Hawking radiation is more speculative because there is no complete theory of quantum gravity. Most other researcher's analyzing the same situation come to opposite conclusions (that horizon [or quantum analog thereof] forms in finite external time when quantum corrections are taken into account). However, this is an active, disputed area. For the purposes of this forum and thread, I am only discussing classical GR, classical EM.
PAllen said:
[..] The key point being that the understanding: "Only from the point of view of an external observer" is missing. The reputable sources have this understanding.
This is matter of context; the understanding that you say to be missing was specified in my post:
"the Huygens method is non-local, as pictured from a distant frame far in space. So, I guess that my question boils down to asking how to transform [your local] description into a description based on such a non-local frame. [..] If someone can translate the above into a non-local description, that would be very helpful for me and no doubt many others. I guess that I put my finger on the Schwartzschild singularity issue.
So, once more: In case you or someone else remembers any post that gives a reasonable answer from that same perspective, a link to it would be very helpful. :-p
That is quite what I understood from it (without contemplating what distant observers actually "see"; surely distant observers will not see anything after a while).
That's fine to me; this is also not the forum for quantum gravity!
Ok, then how much of what you're looking for is addressed or not addressed by the following observation I made:
"They can deduce that the object has reached the singularity. Specifically, they can compute when to send a signal such that the infaller will receive it an instant before reaching the singularity. "
Even though they won't get a reply, the distant observer knows when to send a signal that will be received by a given infaller:
- at moment of crossing horizon
- at an any point between horizon and singularity
None of these signals involve waiting for infinite time to pass [before sending them]. Further, the infaller can flash a radio burst on receiving each of these signals. It just so happens that the bursts (that propagate away from the infaller in all directions, in their frame) never escape the horizon. The whole assemblage (infaller, out going signal sphere) is moving towards the singularity [in terms of SC r coordinate, and in terms of termination world lines and null paths on the singularity].
So where does the energy of the light go? Is it still in the black hole?
It is part of the gravitational field. The black hole won't lose much energy by emitting a high-energetic photon close to the Schwarzschild radius.
I think that it doesn't really address the OP's question (corrected as in post #3) from a distant perspective.
In particular, that doesn't explain from that perspective what the frequency of light can be, if anything, that is emitted from "inside" (and why), nor why apparently many people think that in the lifetime of our universe anything can get beyond that horizon.
In particular, that doesn't explain from that perspective what the frequency of light can be, if anything, that is emitted from "inside" (and why), nor why people think that in the lifetime of our universe anything can get beyond that horizon.
I don't understand why it doesn't address both questions.
1) Locally, light emitted inside the horizon can be any frequency, and everything is perfectly normal, locally. What frequency it would be if it could escape is meaningless because it can't. What frequency it would be observed at by any world line (inside) that interacts with it is well defined and a function of the source and emitter world lines and intervening curvature, just like anywhere else in the universe (Doppler).
2) Why people think matter crosses the horizon has been addressed by my example of: I send a signal at 3PM today and know (per GR) that it will be received by a specific infaller as it crosses a 2-sphere exactly 1/4 the surface area of the apparent horizon. These issue have also been addressed in numerous long threads. You can reject this conclusion of classical GR only by rejecting classical GR (which you are free to do). Also note that, in GR (and SR, for that matter) simultaneity is a matter of convention. Using a different simultaneity convention than that used to construct SC coordinates (that matches this convention far from the BH) - for example, using Lemaitre t=<constant> simultaneity - one can talk about specific places inside the horizon that an infaller is 'now'. It is perfectly normal that the image you see of the infaller is older than 'now' (in this case, from some moment before it crossed the horizon).
I honestly think that if Lemaitre coordinates had been discovered before SC coordinates, 99% of BH misunderstanding would never have occurred. It is almost always due to attributing physical significance to coordinate artifacts.
1) Locally, light emitted inside the horizon can be any frequency, and everything is perfectly normal, locally. [..] What frequency it would be observed at by any world line (inside) that interacts with it is well defined and a function of the source and emitter world lines and intervening curvature, just like anywhere else in the universe (Doppler).
:confused: According to me, a worldline cannot observe. Anyway, I still wonder why the emission frequency would be positive and real (from a distant perspective of course) instead of imaginary as with the approximate solution:
- http://en.wikipedia.org/wiki/Schwarzschild_radius#Other_uses_for_the_Schwarzschild_radius
I have followed some of those threads without participating: the parts that I saw exactly avoided addressing such issues as this one. And it looks as if you formulated it better (more precisely) last time:
"They can deduce that the object has reached the singularity. Specifically, they can compute when to send a signal such that the infaller will receive it an instant before reaching the singularity. [..] "
If you transform that description of yours to our distant ECI frame, I suspect that you will find that to our reckoning, those signals of us will reach that person shortly before t=∞ so that "an instant before reaching the singularity" transforms to "perhaps after the end of this universe". But if that is wrong, please clarify why.
That may be well the case. I think that there will be even much less misunderstanding if you or someone else would be so kind to express those events in "earth coordinates", which would clarify if in theory this topic relates to something that can ever happen. But as this is the fourth consecutive post in which I ask this, I'll leave it at this if it still doesn't get addressed.
Thanks,
Harald
To me, a detector (which follows a world line) is the only thing that can observe. Coordinate labels and simultaneity are abstractions, not observables. So any detector that can observe light emitted inside the EH observes red or blueshift following normal GR rules. The general GR rule is to parallel transport the emitter 4-velociy to the receiver world line along the light path followed. Then express the transported emitter 4 velocity and local light path tangent vector in the local frame basis of the reception event, and use SR doppler formula. This formulation covers every combination of kinematic and curvature and cosmological contribution to redshift in one general method.
The concept of a gravitational redshift 'field' as in that wikipedia formula is a special case that applies only to static space time. It is doubly nonsensical to apply it across the event horizon:
1) There are no emitter and receiver possible from the inside to outside the EH. Therefore it is applied outside its domain of validity.
2) You can't even write an alternative equivalent formula for inside the horizon because the region inside the horizon is not static, so there is no such thing, even approximately, of a gravitational potential. The concept of gravitational redhsift factored out separately from general redshift as I described above is possible only for static spacetime.
One final key point: for emitter outside EH and receiver inside EH, you can compute the red/blue shift using the standard method I describe and get a perfectly normal result - because there is a light path from emitter to receiver in this case. The result cannot be summarized into a redhift as a function of position for the very reason above: the light path goes from a static region of spacetime to a non-static region.
I'm sorry if all of these realities of GR are ignored in wikipedia level treatments, but I can assure you they were well understood by 1960.
There is no such thing as a global frame in GR. There are local frames and global coordinate systems. So your statement asks for something GR states does not exist.
The best you can do in GR is define a family non-intersecting spacelike 3-surfaces of simultaneity that you parametrize with a timelike parameter. SC coordinates do this in a way that covers only the exterior region of a BH. Lemaitre and Kruskal coordinates do this in a way that covers the whole spacetime. Each provides a specific (and different) answer to what events inside the horizon are simultaneous with a given event outside.
Each of these coordinate systems (Lemaitre and Kruskal) provide a finite well defined answer to 'when', for an outside observer, a signal reaches a given inside detector.
Short answer: your question reflects fundamental misunderstanding of GR; corrected in the only way I know, your conclusion is wrong.
Thanks,
Harald
As above, GR says this question is wrongly formulated - there is no preferred definition of global Earth coordinates. There are at least two common global coordinates that answer this question - each differently. SC coordinates don't answer it for the trivial reason they don't cover enough of spacetime. (Note: SC coordinates provide two separate coordinate patches, one for interior region, one for exterior. If you want a simultaneity convention between spacetime regions, you need a single coordinate patch that includes both regions. Thus SC coordinates are simply inadmissable for answering your question).
[EDIT: Perhaps this coordinate free description will help ... or not; we'll see. You can't treat causally connected events as simultaneous. The relations of backward and forward going light cones defines the causal structure of spacetime. In the SC geometry, every event outside the EH is in the causal past of a set of events inside the EH. The causal future of any internal event includes only internal events. For a given event, anywhere, you can choose to consider any event between its past and future light cones as simultaneous with it. For an outside event, this means there are a set of interior events in its future light cone that cannot be considered simultaneous. Any interior event 'before' this future light cone can be considered simultaneous with the chosen external event. Thus not only is it possible to choose interior events simultaneous with external event, there are infinite possible choices. Similarly, given an internal event, there is a set of external events in its past light cone; any external event outside of this past light cone is a possible choice for a simultaneous external event]
Thanks,
Harald
Just FYI: I feel I and others have have answered all of these questions multiple times in multiple ways, in multiple threads. It seems to me you simply reject the answers but are not willing to say, straight out, that you reject GR.
I don't have any idea what you're asking for here either.
Space time is curved, like the surface of the Earth. You can make maps of it, like you can make maps of the Earth's surface. But they won't / can't be to scale except for small regions (frames). The metric describes how the particular part of the map is distorted. To oversimplify greatly, the closer the metric is to unity, the less the distortion.
Considering that Hamilton spends a good part of his time describing a journey into a black hole, (complete with visuals), do you really think it's an accurate reading of him to say that he supports your "time stops at the event horizon, so we don't have to worry about what comes after" idea?
(That was semi-rhetorica., I can say that I certainly don't, and I would be surprised if you did if you thought about it a bit more. Though I've been surprised in this manner before, alas.)
Naty1 said:
[..] There is a good discussion about spacetime geometry inside a black hole here:
In summary here is what you get inside a black hole horizon...all the way to the singularity at the center of the BH [..]
Interesting summary! I had not seen that post which you wrote simultaneously to me.
In particular, by chance (because you did not directly respond to me) it gives an answer from the "distant" perspective that I asked for:
"In the subsequent analysis, we will often consider the perspective of an observer who is at rest at "infinity," that is, very far away from the black hole."
Thanks! :smile:
Thanks! :smile:
This article looks pretty good, but there is at least one historical blunder. Lemaitre fully resolved the SC coordinate singularity in 1932 with his Lemaitre coordinates. Bergmann's 1942 textbook (I have a copy) already refers to resolution of this 'problem' using a slightly later approach by Robertson (of Robertson-Walker fame). So, at the University textbook level, the problem was considered solved by 1942.
What occurred in 1950 was the first hint that the SC geometry can by geodesically completed into a two world sheet geometry connected by a wormhole bridge; and that the eternal black hole is completed into a prior eternal white hole. None of these geoemetric features apply to a BH that arises from collapse matter - they only apply to the mathematical eternal BH. This effort, begun by J.L. Synge in 1950, reached fruition in the work of Martin Kruskal and George Szekeres, in 1960.
  • #31
I fully agree with that; I had no idea that with "worldline" you meant "detector"!
Coordinate labels and simultaneity are abstractions, not observables. So any detector that can observe light emitted inside the EH observes red or blueshift following normal GR rules. The general GR rule is to parallel transport the emitter 4-velociy to the receiver world line along the light path followed. Then express the transported emitter 4 velocity and local light path tangent vector in the local frame basis of the reception event, and use SR doppler formula. This formulation covers every combination of kinematic and curvature and cosmological contribution to redshift in one general method. [..]
2) You can't even write an alternative equivalent formula for inside the horizon because the region inside the horizon is not static, so there is no such thing, even approximately, of a gravitational potential. The concept of gravitational redhsift factored out separately from general redshift as I described above is possible only for static spacetime. [..] the light path goes from a static region of spacetime to a non-static region. [..]
Thanks - Regretfully I am not familiar with "non-static spacetime" but perhaps that Naty's link that clarifies.
I will compare your answer with the other answers. :smile:
Perhaps this coordinate free description will help ... or not; we'll see. [..] not only is it possible to choose interior events simultaneous with external event, there are infinite possible choices. Similarly, given an internal event, there is a set of external events in its past light cone; any external event outside of this past light cone is a possible choice for a simultaneous external event]
It doesn't help yet; does it correspond to the "swapping of space and time"?
I don't know why you would think that (except for 1916GR which is subtly rejected by mainstream). Your answer implies that those questions have no answer; however several web links seem to give an answer.
I asked for a "distant perspective" which is now found to be given in several links. :smile:
Surprise for me - and perhaps also for you:
I now found that Hamilton also discusses this question, and answers it with a falling space/flowing river model - a kind of ether inflow (question 9):
- http://casa.colorado.edu/~ajsh/collapse.html#collapsed
I thought that the "falling space" model was disproved, but this is apparently not established:
- "ajp.aapt.org/resource/1/ajpias/v76/i6/p519_s1?"
Anyway, GR is based on a model of static space with "curvature" due to "fields". "flowing" space is fundamentally different from "curved" space; it is conceptually more different from GR than LET from SR. Einstein's light bending calculation method according to which light locally slows down doesn't even apply to flowing space! With that model time does not stop at the event horizon. Perhaps flowing space gives the same verifiable predictions as GR, but it is definitely not the same model as the one Einstein used for GR and to which I referred with my question; now reading the interesting link by Naty.
PS. Links to two opinions, not including falling space theory:
http://arxiv.org/abs/gr-qc/0609024 (found by me, discussed in Discovermagazine)
http://www.jimhaldenwang.com/black_hole.htm (found by Naty)
  • #32
Yes, the link Nat attempts to provide intuitive explanation of the non-static spacetime of the BH interior. Generally, the concept of static is simply: Can you find a way to introduce a family of timelike world lines covering spacetime (congruence, in the technical terminology), such that the metric does not change along each of these. More precisely, can you find a timelike killing field. If you can, then you can introduce coordinates of the familiar type (one timelike, 3 spacelike) such that the metric components are not a function of the time coordinate.
For a non-static spacetime, the above is impossible. This means it becomes impossible to do any of the following:
- model gravity by a potential (a function of position)
- factor redshift into gravitiational and kinemetic in any meaningful way. You can compute redhift between an emitter and detector whose world lines you specify, but can't factor it into separate components, as you can in a static spacetime.
The swapping of space and time is coordinate artifact of SC coordinates. It does not happen in Lemaitre or Kruskal coordinates. What is an invariant feature of causal structure of the interior versus exterior of a BH event horizon is that the future pointing light cone of all interior events includes no exterior events. Further, for the simple, non-spinning, spherical BH, the future pointing light cone of every interior event includes the singularity; and every timelike world line ends at the singularity.
On the contrary, I thought I provided multiple answer, and continue to be frustrated that you claim otherwise. I said, briefly:
- there is no such thing as global frames in GR, only gl0bal coordinates; and there isn't a way to strongly favor one over another as there is for global inertial frames in SR. However, I then describe 2 specific ways, and also the general rule, for establishing simultaneity between exterior and interior events.
I gave you two specific ones and also a general rule.
No surprise at all. I didn't think this was necessary to resolve your questions. If it is helpful, great.
This is wrong. It is based on curvature of spacetime. Static solutions arise for artificial special cases (one non-spinning object in the universe). As with any other theory, ideal, special case, solutions can be useful approximations to more realistic scenarios (e.g only one massive body in a region; rotation not extreme,). But, as with any theory, you need to know the limits of applicability of ideal solutions.
Flowing space is just an intuitive model of curved spacetime that cannot be treated as static.
Wrong, it is a direct consequence of the equations Einstein and Hilbert wrote down in 1916. Nothing has been added to or changed about those equations or the definition of observables. Mathematical technique has evolved. Understanding of what the equations imply has evolved - Einstein was involved in plenty of it, through the 1940. Some of Einstein's philosophic understandings of GR are not so widely shared now, but this has no bearing on physical predictions.
Einstein was simply doing a calculation for the simplest static case (sun considered effectively motionless and isolated; a very good approximation). Are you interpreting one special case computation as the whole theory??!
Again, flowing space is just one intuitive description of spacetime curvature without a timelike killing vector, so it cannot be treated as a static geometry. Note that even a static spacetime has curvature of time as well as space. It is just that that the curvature can be considered not to evolve in time.
[edit: The SC exterior static geometry is to GR (and the EFE) as the coulomb field of a single charge is to the richness of Maxwell's theory. ]
[Edit: I see that Hamilton has a very specific concept of flowing space, that he applies even to static regions. This is different from a more generic concept I was using only for non-static regions. However, it is crucial to note that Hamilton is just providing an interpretational model. It adds nothing, changes nothing, about GR. It is just an approach to picturing some of its consequences. One cannot speak about its being right or wrong; only useful or not-useful for your own understanding.
Note that this link Harrylin gave:
is not discussing classical GR at all. It is discussing one group's conclusions about how quantum corrections would modify GR (in the absence of any accepted theory of quantum gravity). ]
  • #33
In general light is not fast enough to escape the gravity of a black hole. But as stated many times, when you are dealing in black holes the laws on Physics seem to be broken. However I guess if you could bend space time enough around the center of the SMB light could possibly escape the intense gravity.
  • #34
What evidence do you have of this? Light can't even orbit too close to the event horizon--there is a separate horizon composed of nothing but photons orbiting further out from the event horizon. And any photons falling in closer will have their worldlines pointing to the center. The event horizon itself is the point past which even a photon pointed directly away from the singularity would have no hope of escaping. In other words, the point past which all worldlines curve back towards the center.
Besides, the current theories only break down at the singularity, which is well past the "point of no return". The physics up to that point is pretty solid (to use an admittedly horrendous pun).
"Bending space time enough" is just going to make the gravitational effect all the more intense, because an inertial path taken through space time is determined by a geodesic--the shortest path taken through curved manifold (in this case, spacetime.) and "bending space time" is just going to increase the curvature of the geodesics.
  • #35
PAllen said:
Yes, the link Nat attempts to provide intuitive explanation of the non-static spacetime of the BH interior. Generally, the concept of static is simply: Can you [..] introduce coordinates of the familiar type (one timelike, 3 spacelike) such that the metric components are not a function of the time coordinate.
For a non-static spacetime, the above is impossible. This means it becomes impossible to [..]
Thanks - that's clearer - and better than rotating a clock into a ruler. :-p Anyway it appears that that reference is not peer reviewed.
[..] On the contrary, I thought I provided multiple answer [..] I gave you two specific ones and also a general rule.
I saw that you gave the names of two methods that can be used to give different answers...
[rearranging:] [..] Flowing space is just an intuitive model of curved spacetime that cannot be treated as static. [Edit: I see that [..] applies even to static regions. [..]
Good! - that is exactly my point. I will start a topic on that model vs Einstein's GR.
Good try to discredit it (and already your second attempt, as it's what discovermagazine discussed) - but untrue according to Physical Review. The "analysis is in 3+1 dimensions and within conventional general relativity."
It provides perhaps the clearest and most up-to-date answer to the question of this thread, and from a quality source.
I'm still reading it.
[edit: it has 28 citations, so there may be a more relevant newer article on this]
  • #36
Here is its abstract:
"We study the formation of black holes by spherical domain wall collapse as seen by an asymptotic observer, using the functional Schrodinger formalism. To explore what signals such observers will see, we study radiation of a scalar quantum field in the collapsing domain wall background. The total energy flux radiated diverges when backreaction of the radiation on the collapsing wall is ignored, and the domain wall is seen by the asymptotic observer to evaporate by non-thermal ``pre-Hawking radiation'' during the collapse process. Evaporation by pre-Hawking radiation implies that an asymptotic observer can never lose objects down a black hole. Together with the non-thermal nature of the radiation, this may resolve the black hole information loss problem. "
Hawking radiatiion and pre-Hawking radiation are outside of classical GR. I have read enough to see the obvious fact that every aspect of its conclusions is based on quantum corrections to GR. Even the topic: "Information Loss" is a problem that exists only for quantum mechanics + GR. Evaporation is not part of classical GR, and is fundamental to their argument. This paper is not a paper on classical GR at all.
  • #37
Do you consider spacetime diagrams or the block universe different theories than SR? To me, they are just different approaches to picturing SR. Hamilton's river model's are not a new theory, just a conceptual aid. They change not a single equation or rule for computing an observable.
  • #38
Thus answering the question at hand, which was "is there a way to say what event for a distant observer is simultaneous with reception of a signal by an interior observer?" The answer being: two well known possible conventions; plus the applicability of the general SR/GR rule that indicates there are infinite admissable answers and no way to say one is 'right'. If you want more specifics, pose a specific scenario with numbers, and I will try to compute a specific answer for you, using one or both specific conventions.
  • #39
OK, I now read sufficiently of http://arxiv.org/abs/gr-qc/0609024 to give a quick summary as concerns the topic here.
"Our analysis is in 3+1 dimensions and within conventional general relativity. [..] we find that Schwarzschild coordinates are sufficient to answer the very specific set of questions we ask from the asymptotic observer’s viewpoint."
"the standard result [is] that the formation of an event horizon takes an infinite (Schwarzschild) time if we consider classical collapse."
And they conclude:
"First, we studied the collapse of a gravitating spherical domain in [..] classical [..] theory, ignoring any evaporative processes. [...] our results show that [..] the horizon does not form in a finite time".
This is, as I mentioned earlier, also discussed on another forum:
A follow-up paper states and explains the same, perhaps even more clearly:
"Black Hole - Never Forms, or Never Evaporates" (title)
- http://arxiv.org/abs/1102.2609
From that I conclude that the modern answer to the question of this thread is that according to GR it can never happen - similar to "what happens when I go faster than light".
I'm satisfied with that answer (and note that the original poster did not come back to this thread).
  • #40
PAllen said:
[..] If you want more specifics, pose a specific scenario with numbers, and I will try to compute a specific answer for you, using one or both specific conventions.
Thanks for your kind offer; but it won't be needed!
PS. I started the new topic on "flowing space models" here:
https://www.physicsforums.com/showthread.php?t=647627
  • #41
First, one author does not represent the 'modern view'. Krauss is recognized as a cosmologist not a GR expert. Even so, I show how I believe you are over-interpreting the claims of this paper.
Yes, a specific set of questions. There is never any dispute about what light or radiation reaches a distant observer from the BH region.
The different question that came up in this thread was: can the distant observer send a message to an infaller? Where is the infaller when the message reaches them? Is there a way to talk about 'when' for the external observer the infaller gets the message? In classical GR, the first two of these are physical observables with absolutely indisputable answers; the last is purely a matter of convention - true for any question about distant simultaneity. The indisputable answer to the physical question:
- the infaller will receive signals from the distant observer at a well defined finite time on their watch.
- the infaller will continue receiving such signals past the EH all the way to the singularity.
This paper simply chose not address these question, so in no way does it refute them.
Schwarzschild time is not an observable of GR, it is a coordinate quantity. The only relevant observable for classical GR is the never disputed observation that no signal or influence will propagate from the EH or inside to a distant observer.
harrylin said:
And they conclude:
Now this I would say is wrong without qualification. The question is whose time? If you follow an infalling dust particle in a collapse, the horizon forms in finite time, the particle crosses it. Further, the area of the externally observed, ultra-redshift boundary grows as new matter falls into the region. Each new piece of matter you follow in its local frame crosses a larger surface area horizon.
So here, this phrasing (at least the snippet you've given, taken in isolation) is at least misleading. It certainly does not represent consensus view of classical GR.
As I read that paper, the titular conclusion follow from proposed behavior of Hawking radiation:
"it shows that so long as the mechanism of black hole evaporation satisfies a quite loose condition that the evaporation lifespan is finite for external observers, regardless of the detailed mechanism and process of evaporation, the conundrums above can be naturally avoided.'
Evaporation is outside the scope of classical GR.
  • #42
I used the pragmatic Wikipedia method: check out the citations over 4 years.
[..] The different question that came up in this thread was: can the distant observer send a message to an infaller? Where is the infaller when the message reaches them? Is there a way to talk about 'when' for the external observer the infaller gets the message?
Instead I only referred to the topic as in the title question of this thread.
Now this I would say is wrong without qualification. The question is whose time? [..]
That is specified: "the asymptotic observer" - which corresponds to the time I referred to in the 10 foregoing posts. They elaborate: "More concretely, if a black hole is formed in the Large Hadron Collider, it has to be observed by physicists sitting on the CERN campus."
This is how the more recent paper by Yi phrases the same (and with that I'll leave this thread):
"According to Oppenheimer & Snyder [7], there are two influencing conclusions of black hole(BH) formation: “[..] an external observer sees the star asymptotically shrinking to its gravitational radius”. It must be mentioned that the word “see” means measuring by coordinates, not “watching” the light emitted from the star".
  • #43
Counting citations without looking at the goals and content of the papers doesn't mean much. Here is later summary by a universally recognized GR expert on these issues at the boundary of classical and quantum gravity (it cites this paper and many others):
http://arxiv.org/pdf/0901.4365v3.pdf
I note the following, which I view as the continuing, unchanged, majority consensus for classical GR:
Classical general relativist: Eternal black holes certainly exist mathematically, as stationary
vacuum solutions to the Einstein equations. (See, for example, [10, 11, 12, 13], or any of the
many standard textbooks in general relativity [14].) Furthermore classical astrophysical black holes
(future event horizons) certainly exist mathematically as the end result of classical collapse based
on certain physically plausible equations of state. (See, for example, [15].)
Since a defining feature of such micro-black holes is quantum behavior, this is ipso facto completely outside of classical GR.
"Measuring coordinates" is nonsense. Coordinates are not observable, in SR or GR. Further, IMO, the introduction to the Yi paper announces him as crank (unlike Krauss et.al., who make no equivalent statements). Schwarzschild time, per se, is not an observable for anyone. All you can talk about is light and signals received by some observer, at various proper times along their world line. Coordinates are computed quantities, defined for various purposes.
A geometric translation of "SC time becomes infinite as an infall trajectory approaches the horizon" is:
If I compute simultaneity using one particular set of spacelike-hypersurfaces (distant simultaneity itself being inherently unsobservable), then I never find an event on an external observer's world line to be simultaneous with an infaller crossing the horizon.
However, if I make any of an inifnite number of different choices for simultaneity surfaces, I can declare which external event I compute to be simultaneous with an EH crossing event for an infaller.
  • #44
PAllen said:
[..] Here is later summary by a universally recognized GR expert on these issues at the boundary of classical and quantum gravity (it cites this paper and many others):
Popped in for one last look at this thread, and see there: Nice - I had missed that one! :smile:
I see that that expert imagines general relativists to be mathematicians: "exist mathematically" isn't physical existence. :wink:
Thanks again,
Harald
  • #45
Thanks again,
Harald
Well part of this is that nearly everyone, myself included, think the universe is quantum in nature; thus GR pushed to extreme regimes is unlikely to be correct. I simply clearly separate this not-yet understood realm, from classical GR. In EM, we have little difficulty saying: according to Maxwell's equations, xyz happens (e.g a stable atom cannot exist); accounting form quantum theory, it can. Similarly, I believe (almost certainly) that (due to quantum corrections):
- singularities don't actually exist in our universe
- compact objects (collapsed stars; active galactic centers) share many broad properties, observed from a distance, as classical event horizons; however, the details are likely different. How different, I don't know. For example, the question of whether BH horizons produce 'firewalls' is currently being debated between Polchinksi and Susskind (both prominent string theorists).
  • #46
Observation of Incipient Black Holes and the Information Loss Problem
Tanmay Vachaspati, Dejan Stojkovic, Lawrence M. Krauss
(Submitted on 7 Sep 2006 (v1), last revised 7 Jun 2007 (this version, v3))
"functional Schrodinger formalism", whatever else it may be is NOT classical.
While I'm not particulary fond of at least one of the authors (Krauss, as in my opinion he messed the"Physics of StarTrek" with some quirky popularizations) the paper probably deserves some serious study. But it is no sense about CLASSICAL black holes.
(And I'm sorry, but I can't really address the non-classical aspects of the paper due to a lack of familiarity. Perhaps someone else can. But I feel quite comfortable with talking about the CLASSICAL theory of black holes.)
One thing I think should be pretty clear. The paper will NOT answer the experiences of someone who falls into a black hole. Which is really the question under discussion - and not at all related to the topic of the paper. At least I thought that's what the question was. It seems like the topic is morphing around, never a good sign.
From what I gather, you seem to think that someone who falls into a black hole just vanishes or something? And you ignore all the various published papers about what happens inside the event horizon - for reasons that I don't follow. I"m really not sure what you think happens when there is "geodesic incompleteness". Imagine that you drew a space-time diagram, and you came to the edge of the paper, and you just stopped drawing the worldline. That is an informal description of "geodesic incompletness".
Geodesic incompletenss is NOT a required feature of the event horizon, though you can put it in if you really want to (you could have geodesics vanish somewhere other than the event horizon too - you simply decide where they vanish, and declare that it happens). It's rather like sketching a map of the universe on some piece of paper, and saying that anything that goes "off the map" just vanishes from existence.
You can do it, but it's silly.
I can point out (as I have many times in the past) the analogous situation of someone falling behind the Rindler horizon. The situation provides much insight. While I doubt there are any papers on the topic, there may be a textbook question or two. It's quite easy for the whole Earth to fall behind the Rindler horizon of an acclerating spaceship, and from the spaceship you'll see all the usual reshifting and apparent "freezing" of time, just as you will see with a black hole horizon, or any other event horizon. But, it should be reasonably obvious that nothing that happens on the remote spaceship is going to affect the Earth - if the Earth falls behind the Rindler horizon of the spaceship in 2012, the Earth is not going to vanish from existence, or cease to exist, in any meaningful sense. The spaceship, however, won't be able to see any events subsequent to 2012 as long as it continues to accelerate.
