Speed of light enough to escape black holes ?
The discussion revolves around the concept of light and its behavior in relation to black holes, particularly whether light can escape a black hole and the implications of escape velocity and General Relativity. Participants explore theoretical aspects, conceptual clarifications, and the nature of spacetime within and around black holes.
  • Some participants suggest that if light travels at the speed of light, it might escape a black hole, questioning the implications of black hole density on light speed.
  • Others argue that the escape velocity of a black hole is equal to the speed of light (c), implying that light cannot escape once it crosses the event horizon.
  • There are claims that light does not slow down but loses energy as it climbs out of a gravitational well, leading to an increase in wavelength.
  • Some participants clarify that once inside the event horizon, all directions point towards the center, making escape impossible.
  • One participant mentions that light emitted at the event horizon will not lose or gain energy but will appear to "hang" at that location.
  • Another point raised is that while light moves at c locally, the radial coordinate decreases faster than the outgoing light, complicating the notion of escape.
  • There is a discussion about the Huygens construction and how it relates to light bending in gravitational fields, with questions about non-local descriptions of light behavior near black holes.
Participants express differing views on whether light can escape a black hole, with some asserting it cannot due to the nature of spacetime and others questioning the implications of light speed and energy loss. The discussion remains unresolved with multiple competing views present.
Participants highlight the complexity of defining radial positions and the behavior of light in curved spacetime, indicating that assumptions about local versus non-local frames may affect interpretations.
  • #31
PAllen said:
To me, a detector (which follows a world line) is the only thing that can observe.
I fully agree with that; I had no idea that with "worldline" you meant "detector"!
Coordinate labels and simultaneity are abstractions, not observables. So any detector that can observe light emitted inside the EH observes red or blueshift following normal GR rules. The general GR rule is to parallel transport the emitter 4-velociy to the receiver world line along the light path followed. Then express the transported emitter 4 velocity and local light path tangent vector in the local frame basis of the reception event, and use SR doppler formula. This formulation covers every combination of kinematic and curvature and cosmological contribution to redshift in one general method. [..]
2) You can't even write an alternative equivalent formula for inside the horizon because the region inside the horizon is not static, so there is no such thing, even approximately, of a gravitational potential. The concept of gravitational redhsift factored out separately from general redshift as I described above is possible only for static spacetime. [..] the light path goes from a static region of spacetime to a non-static region. [..]
Short answer: your question reflects fundamental misunderstanding of GR; corrected in the only way I know, your conclusion is wrong.
Thanks - Regretfully I am not familiar with "non-static spacetime" but perhaps that Naty's link that clarifies.
I will compare your answer with the other answers. :smile:
Perhaps this coordinate free description will help ... or not; we'll see. [..] not only is it possible to choose interior events simultaneous with external event, there are infinite possible choices. Similarly, given an internal event, there is a set of external events in its past light cone; any external event outside of this past light cone is a possible choice for a simultaneous external event]
It doesn't help yet; does it correspond to the "swapping of space and time"?
PAllen said:
Just FYI: I feel I and others have have answered all of these questions multiple times in multiple ways, in multiple threads. It seems to me you simply reject the answers but are not willing to say, straight out, that you reject GR.
I don't know why you would think that (except for 1916GR which is subtly rejected by mainstream). Your answer implies that those questions have no answer; however several web links seem to give an answer.
pervect said:
I don't have any idea what you're asking for here either.
Space time is curved, like the surface of the Earth. You can make maps of it, like you can make maps of the Earth's surface. But they won't / can't be to scale except for small regions (frames). The metric describes how the particular part of the map is distorted. To oversimplify greatly, the closer the metric is to unity, the less the distortion.
I asked for a "distant perspective" which is now found to be given in several links. :smile:
Considering that Hamilton spends a good part of his time describing a journey into a black hole, (complete with visuals), do you really think it's an accurate reading of him to say that he supports your "time stops at the event horizon, so we don't have to worry about what comes after" idea?
(That was semi-rhetorica., I can say that I certainly don't, and I would be surprised if you did if you thought about it a bit more. Though I've been surprised in this manner before, alas.)
Surprise for me - and perhaps also for you:
I now found that Hamilton also discusses this question, and answers it with a falling space/flowing river model - a kind of ether inflow (question 9):
- http://casa.colorado.edu/~ajsh/collapse.html#collapsed
I thought that the "falling space" model was disproved, but this is apparently not established:
- "ajp.aapt.org/resource/1/ajpias/v76/i6/p519_s1?"
Anyway, GR is based on a model of static space with "curvature" due to "fields". "flowing" space is fundamentally different from "curved" space; it is conceptually more different from GR than LET from SR. Einstein's light bending calculation method according to which light locally slows down doesn't even apply to flowing space! With that model time does not stop at the event horizon. Perhaps flowing space gives the same verifiable predictions as GR, but it is definitely not the same model as the one Einstein used for GR and to which I referred with my question; now reading the interesting link by Naty.
PS. Links to two opinions, not including falling space theory:
http://arxiv.org/abs/gr-qc/0609024 (found by me, discussed in Discovermagazine)
http://www.jimhaldenwang.com/black_hole.htm (found by Naty)
  • #32
Yes, the link Nat attempts to provide intuitive explanation of the non-static spacetime of the BH interior. Generally, the concept of static is simply: Can you find a way to introduce a family of timelike world lines covering spacetime (congruence, in the technical terminology), such that the metric does not change along each of these. More precisely, can you find a timelike killing field. If you can, then you can introduce coordinates of the familiar type (one timelike, 3 spacelike) such that the metric components are not a function of the time coordinate.
For a non-static spacetime, the above is impossible. This means it becomes impossible to do any of the following:
- model gravity by a potential (a function of position)
- factor redshift into gravitiational and kinemetic in any meaningful way. You can compute redhift between an emitter and detector whose world lines you specify, but can't factor it into separate components, as you can in a static spacetime.
The swapping of space and time is coordinate artifact of SC coordinates. It does not happen in Lemaitre or Kruskal coordinates. What is an invariant feature of causal structure of the interior versus exterior of a BH event horizon is that the future pointing light cone of all interior events includes no exterior events. Further, for the simple, non-spinning, spherical BH, the future pointing light cone of every interior event includes the singularity; and every timelike world line ends at the singularity.
On the contrary, I thought I provided multiple answer, and continue to be frustrated that you claim otherwise. I said, briefly:
- there is no such thing as global frames in GR, only gl0bal coordinates; and there isn't a way to strongly favor one over another as there is for global inertial frames in SR. However, I then describe 2 specific ways, and also the general rule, for establishing simultaneity between exterior and interior events.
I gave you two specific ones and also a general rule.
No surprise at all. I didn't think this was necessary to resolve your questions. If it is helpful, great.
This is wrong. It is based on curvature of spacetime. Static solutions arise for artificial special cases (one non-spinning object in the universe). As with any other theory, ideal, special case, solutions can be useful approximations to more realistic scenarios (e.g only one massive body in a region; rotation not extreme,). But, as with any theory, you need to know the limits of applicability of ideal solutions.
Flowing space is just an intuitive model of curved spacetime that cannot be treated as static.
Wrong, it is a direct consequence of the equations Einstein and Hilbert wrote down in 1916. Nothing has been added to or changed about those equations or the definition of observables. Mathematical technique has evolved. Understanding of what the equations imply has evolved - Einstein was involved in plenty of it, through the 1940. Some of Einstein's philosophic understandings of GR are not so widely shared now, but this has no bearing on physical predictions.
Einstein was simply doing a calculation for the simplest static case (sun considered effectively motionless and isolated; a very good approximation). Are you interpreting one special case computation as the whole theory??!
Again, flowing space is just one intuitive description of spacetime curvature without a timelike killing vector, so it cannot be treated as a static geometry. Note that even a static spacetime has curvature of time as well as space. It is just that that the curvature can be considered not to evolve in time.
[edit: The SC exterior static geometry is to GR (and the EFE) as the coulomb field of a single charge is to the richness of Maxwell's theory. ]
[Edit: I see that Hamilton has a very specific concept of flowing space, that he applies even to static regions. This is different from a more generic concept I was using only for non-static regions. However, it is crucial to note that Hamilton is just providing an interpretational model. It adds nothing, changes nothing, about GR. It is just an approach to picturing some of its consequences. One cannot speak about its being right or wrong; only useful or not-useful for your own understanding.
Note that this link Harrylin gave:
is not discussing classical GR at all. It is discussing one group's conclusions about how quantum corrections would modify GR (in the absence of any accepted theory of quantum gravity). ]
  • #33
In general light is not fast enough to escape the gravity of a black hole. But as stated many times, when you are dealing in black holes the laws on Physics seem to be broken. However I guess if you could bend space time enough around the center of the SMB light could possibly escape the intense gravity.
  • #34
What evidence do you have of this? Light can't even orbit too close to the event horizon--there is a separate horizon composed of nothing but photons orbiting further out from the event horizon. And any photons falling in closer will have their worldlines pointing to the center. The event horizon itself is the point past which even a photon pointed directly away from the singularity would have no hope of escaping. In other words, the point past which all worldlines curve back towards the center.
Besides, the current theories only break down at the singularity, which is well past the "point of no return". The physics up to that point is pretty solid (to use an admittedly horrendous pun).
"Bending space time enough" is just going to make the gravitational effect all the more intense, because an inertial path taken through space time is determined by a geodesic--the shortest path taken through curved manifold (in this case, spacetime.) and "bending space time" is just going to increase the curvature of the geodesics.
  • #35
PAllen said:
Yes, the link Nat attempts to provide intuitive explanation of the non-static spacetime of the BH interior. Generally, the concept of static is simply: Can you [..] introduce coordinates of the familiar type (one timelike, 3 spacelike) such that the metric components are not a function of the time coordinate.
For a non-static spacetime, the above is impossible. This means it becomes impossible to [..]
Thanks - that's clearer - and better than rotating a clock into a ruler. :-p Anyway it appears that that reference is not peer reviewed.
[..] On the contrary, I thought I provided multiple answer [..] I gave you two specific ones and also a general rule.
I saw that you gave the names of two methods that can be used to give different answers...
[rearranging:] [..] Flowing space is just an intuitive model of curved spacetime that cannot be treated as static. [Edit: I see that [..] applies even to static regions. [..]
Good! - that is exactly my point. I will start a topic on that model vs Einstein's GR.
Good try to discredit it (and already your second attempt, as it's what discovermagazine discussed) - but untrue according to Physical Review. The "analysis is in 3+1 dimensions and within conventional general relativity."
It provides perhaps the clearest and most up-to-date answer to the question of this thread, and from a quality source.
I'm still reading it.
[edit: it has 28 citations, so there may be a more relevant newer article on this]
  • #36
Here is its abstract:
"We study the formation of black holes by spherical domain wall collapse as seen by an asymptotic observer, using the functional Schrödinger formalism. To explore what signals such observers will see, we study radiation of a scalar quantum field in the collapsing domain wall background. The total energy flux radiated diverges when backreaction of the radiation on the collapsing wall is ignored, and the domain wall is seen by the asymptotic observer to evaporate by non-thermal ``pre-Hawking radiation'' during the collapse process. Evaporation by pre-Hawking radiation implies that an asymptotic observer can never lose objects down a black hole. Together with the non-thermal nature of the radiation, this may resolve the black hole information loss problem. "
Hawking radiatiion and pre-Hawking radiation are outside of classical GR. I have read enough to see the obvious fact that every aspect of its conclusions is based on quantum corrections to GR. Even the topic: "Information Loss" is a problem that exists only for quantum mechanics + GR. Evaporation is not part of classical GR, and is fundamental to their argument. This paper is not a paper on classical GR at all.
  • #37
Do you consider spacetime diagrams or the block universe different theories than SR? To me, they are just different approaches to picturing SR. Hamilton's river model's are not a new theory, just a conceptual aid. They change not a single equation or rule for computing an observable.
  • #38
Thus answering the question at hand, which was "is there a way to say what event for a distant observer is simultaneous with reception of a signal by an interior observer?" The answer being: two well known possible conventions; plus the applicability of the general SR/GR rule that indicates there are infinite admissable answers and no way to say one is 'right'. If you want more specifics, pose a specific scenario with numbers, and I will try to compute a specific answer for you, using one or both specific conventions.
  • #39
OK, I now read sufficiently of http://arxiv.org/abs/gr-qc/0609024 to give a quick summary as concerns the topic here.
"Our analysis is in 3+1 dimensions and within conventional general relativity. [..] we find that Schwarzschild coordinates are sufficient to answer the very specific set of questions we ask from the asymptotic observer’s viewpoint."
"the standard result [is] that the formation of an event horizon takes an infinite (Schwarzschild) time if we consider classical collapse."
And they conclude:
"First, we studied the collapse of a gravitating spherical domain in [..] classical [..] theory, ignoring any evaporative processes. [...] our results show that [..] the horizon does not form in a finite time".
This is, as I mentioned earlier, also discussed on another forum:
http://blogs.discovermagazine.com/badastronomy/2007/06/19/news-do-black-holes-really-exist/
A follow-up paper states and explains the same, perhaps even more clearly:
"Black Hole - Never Forms, or Never Evaporates" (title)
- http://arxiv.org/abs/1102.2609
From that I conclude that the modern answer to the question of this thread is that according to GR it can never happen - similar to "what happens when I go faster than light".
I'm satisfied with that answer (and note that the original poster did not come back to this thread).
  • #40
PAllen said:
[..] If you want more specifics, pose a specific scenario with numbers, and I will try to compute a specific answer for you, using one or both specific conventions.
Thanks for your kind offer; but it won't be needed!
PS. I started the new topic on "flowing space models" here:
https://www.physicsforums.com/showthread.php?t=647627
  • #41
First, one author does not represent the 'modern view'. Krauss is recognized as a cosmologist not a GR expert. Even so, I show how I believe you are over-interpreting the claims of this paper.
Yes, a specific set of questions. There is never any dispute about what light or radiation reaches a distant observer from the BH region.
The different question that came up in this thread was: can the distant observer send a message to an infaller? Where is the infaller when the message reaches them? Is there a way to talk about 'when' for the external observer the infaller gets the message? In classical GR, the first two of these are physical observables with absolutely indisputable answers; the last is purely a matter of convention - true for any question about distant simultaneity. The indisputable answer to the physical question:
- the infaller will receive signals from the distant observer at a well defined finite time on their watch.
- the infaller will continue receiving such signals past the EH all the way to the singularity.
This paper simply chose not address these question, so in no way does it refute them.
Schwarzschild time is not an observable of GR, it is a coordinate quantity. The only relevant observable for classical GR is the never disputed observation that no signal or influence will propagate from the EH or inside to a distant observer.
harrylin said:
And they conclude:
Now this I would say is wrong without qualification. The question is whose time? If you follow an infalling dust particle in a collapse, the horizon forms in finite time, the particle crosses it. Further, the area of the externally observed, ultra-redshift boundary grows as new matter falls into the region. Each new piece of matter you follow in its local frame crosses a larger surface area horizon.
So here, this phrasing (at least the snippet you've given, taken in isolation) is at least misleading. It certainly does not represent consensus view of classical GR.
As I read that paper, the titular conclusion follow from proposed behavior of Hawking radiation:
"it shows that so long as the mechanism of black hole evaporation satisfies a quite loose condition that the evaporation lifespan is finite for external observers, regardless of the detailed mechanism and process of evaporation, the conundrums above can be naturally avoided.'
Evaporation is outside the scope of classical GR.
  • #42
I used the pragmatic Wikipedia method: check out the citations over 4 years.
[..] The different question that came up in this thread was: can the distant observer send a message to an infaller? Where is the infaller when the message reaches them? Is there a way to talk about 'when' for the external observer the infaller gets the message?
Instead I only referred to the topic as in the title question of this thread.
Now this I would say is wrong without qualification. The question is whose time? [..]
That is specified: "the asymptotic observer" - which corresponds to the time I referred to in the 10 foregoing posts. They elaborate: "More concretely, if a black hole is formed in the Large Hadron Collider, it has to be observed by physicists sitting on the CERN campus."
This is how the more recent paper by Yi phrases the same (and with that I'll leave this thread):
"According to Oppenheimer & Snyder [7], there are two influencing conclusions of black hole(BH) formation: “[..] an external observer sees the star asymptotically shrinking to its gravitational radius”. It must be mentioned that the word “see” means measuring by coordinates, not “watching” the light emitted from the star".
  • #43
Counting citations without looking at the goals and content of the papers doesn't mean much. Here is later summary by a universally recognized GR expert on these issues at the boundary of classical and quantum gravity (it cites this paper and many others):
http://arxiv.org/pdf/0901.4365v3.pdf
I note the following, which I view as the continuing, unchanged, majority consensus for classical GR:
Classical general relativist: Eternal black holes certainly exist mathematically, as stationary
vacuum solutions to the Einstein equations. (See, for example, [10, 11, 12, 13], or any of the
many standard textbooks in general relativity [14].) Furthermore classical astrophysical black holes
(future event horizons) certainly exist mathematically as the end result of classical collapse based
on certain physically plausible equations of state. (See, for example, [15].)
Since a defining feature of such micro-black holes is quantum behavior, this is ipso facto completely outside of classical GR.
"Measuring coordinates" is nonsense. Coordinates are not observable, in SR or GR. Further, IMO, the introduction to the Yi paper announces him as crank (unlike Krauss et.al., who make no equivalent statements). Schwarzschild time, per se, is not an observable for anyone. All you can talk about is light and signals received by some observer, at various proper times along their world line. Coordinates are computed quantities, defined for various purposes.
A geometric translation of "SC time becomes infinite as an infall trajectory approaches the horizon" is:
If I compute simultaneity using one particular set of spacelike-hypersurfaces (distant simultaneity itself being inherently unsobservable), then I never find an event on an external observer's world line to be simultaneous with an infaller crossing the horizon.
However, if I make any of an inifnite number of different choices for simultaneity surfaces, I can declare which external event I compute to be simultaneous with an EH crossing event for an infaller.
  • #44
PAllen said:
[..] Here is later summary by a universally recognized GR expert on these issues at the boundary of classical and quantum gravity (it cites this paper and many others):
Popped in for one last look at this thread, and see there: Nice - I had missed that one! :smile:
I see that that expert imagines general relativists to be mathematicians: "exist mathematically" isn't physical existence. :wink:
Thanks again,
Harald
  • #45
Thanks again,
Harald
Well part of this is that nearly everyone, myself included, think the universe is quantum in nature; thus GR pushed to extreme regimes is unlikely to be correct. I simply clearly separate this not-yet understood realm, from classical GR. In EM, we have little difficulty saying: according to Maxwell's equations, xyz happens (e.g a stable atom cannot exist); accounting form quantum theory, it can. Similarly, I believe (almost certainly) that (due to quantum corrections):
- singularities don't actually exist in our universe
- compact objects (collapsed stars; active galactic centers) share many broad properties, observed from a distance, as classical event horizons; however, the details are likely different. How different, I don't know. For example, the question of whether BH horizons produce 'firewalls' is currently being debated between Polchinksi and Susskind (both prominent string theorists).
  • #46
Observation of Incipient Black Holes and the Information Loss Problem
Tanmay Vachaspati, Dejan Stojkovic, Lawrence M. Krauss
(Submitted on 7 Sep 2006 (v1), last revised 7 Jun 2007 (this version, v3))
"functional Schrödinger formalism", whatever else it may be is NOT classical.
While I'm not particulary fond of at least one of the authors (Krauss, as in my opinion he messed the"Physics of StarTrek" with some quirky popularizations) the paper probably deserves some serious study. But it is no sense about CLASSICAL black holes.
(And I'm sorry, but I can't really address the non-classical aspects of the paper due to a lack of familiarity. Perhaps someone else can. But I feel quite comfortable with talking about the CLASSICAL theory of black holes.)
One thing I think should be pretty clear. The paper will NOT answer the experiences of someone who falls into a black hole. Which is really the question under discussion - and not at all related to the topic of the paper. At least I thought that's what the question was. It seems like the topic is morphing around, never a good sign.
From what I gather, you seem to think that someone who falls into a black hole just vanishes or something? And you ignore all the various published papers about what happens inside the event horizon - for reasons that I don't follow. I"m really not sure what you think happens when there is "geodesic incompleteness". Imagine that you drew a space-time diagram, and you came to the edge of the paper, and you just stopped drawing the worldline. That is an informal description of "geodesic incompletness".
Geodesic incompletenss is NOT a required feature of the event horizon, though you can put it in if you really want to (you could have geodesics vanish somewhere other than the event horizon too - you simply decide where they vanish, and declare that it happens). It's rather like sketching a map of the universe on some piece of paper, and saying that anything that goes "off the map" just vanishes from existence.
You can do it, but it's silly.
I can point out (as I have many times in the past) the analogous situation of someone falling behind the Rindler horizon. The situation provides much insight. While I doubt there are any papers on the topic, there may be a textbook question or two. It's quite easy for the whole Earth to fall behind the Rindler horizon of an acclerating spaceship, and from the spaceship you'll see all the usual reshifting and apparent "freezing" of time, just as you will see with a black hole horizon, or any other event horizon. But, it should be reasonably obvious that nothing that happens on the remote spaceship is going to affect the Earth - if the Earth falls behind the Rindler horizon of the spaceship in 2012, the Earth is not going to vanish from existence, or cease to exist, in any meaningful sense. The spaceship, however, won't be able to see any events subsequent to 2012 as long as it continues to accelerate.
  • · Replies 31 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 62 ·
10K
