Speed of proton parallel to insulating sheet
The speed of a proton moving parallel to a large insulating sheet with a uniform surface charge density of 2.34 × 10^-9 C/m² can be calculated using electric field concepts and kinematics. At time t=0, the proton is 0.360 meters from the sheet and has an initial speed of 990 m/s. After 7.10 × 10^-8 seconds, the final speed of the proton is determined to be 1.34 × 10^3 m/s. The vertical force acting on the proton is independent of its height above the sheet and can be derived using the formula F_y = eσ/(2ε_0), where e is the charge of the proton and ε_0 is the permittivity of free space.
  • Understanding of electric fields and forces, specifically E = 1/(4π(ε_0))*(|Q|/r²)
  • Knowledge of kinematic equations, particularly V = v_0 + a(t)
  • Familiarity with Gauss's law and its application to electric fields
  • Basic calculus for integrating forces from continuous charge distributions
  • Study the application of Gauss's law to calculate electric fields from charge distributions
  • Learn about vector addition in physics, particularly for combining horizontal and vertical velocities
  • Explore the concept of electric force and its effects on charged particles in electric fields
  • Review kinematic equations for motion under constant acceleration
Students in physics, particularly those studying electromagnetism, as well as educators and anyone involved in solving problems related to electric fields and charged particle dynamics.
GogumaDork
At time t=0, a proton is a distance of 0.360 meters from a very large insulating sheet of charge and is moving parallel to the sheet with speed 990 meters/second . The sheet has uniform surface charge density 2.34 * 10^-9 (C/M^2).
What is the speed of the proton at 7.10×10^−8 seconds?
E = 1/(4pi(ε_0))*(|Q|/r^2)
q=σA
Charge of proton = 1.6*10^-19
F=ma=Eq
I'm not really sure how to approach the problem as the textbook chapter examples only relate to solving problems relating to gauss's law, electric field, charge density and electric flux.
I tried assuming the question wants me to solve for E (electric field) using 1.6*10^-19C as the charge Q, and distance .36 meters. Then went back into F=ma = Eq and found a value for acceleration and plugged into V = v_0 + a(t) however the answer was incorrect.
q=σA
F=ma=Eq
This is a multistep problem. The first part is the toughest. You need to use calculus to work out the total instantaneous electric force on the proton. You can do this by envisioning the force on the proton as being contributed by infinitesimally thin annuli (rings) of charge on the sheet. The annuli spread out from a radius of zero to ∞ away from the proton. You need only consider the vertical component of the element of force, since the horizontal components all cancel out when you sum around each ring.
From this, you should be able to prove that the total (vertical) force on the proton at anyone time is independent of its height above the sheet, and is given by F_y = \frac{e\sigma}{2\epsilon_0}. That makes the calculation of the vertical acceleration easy, and you can use the usual kinematic equations for constant acceleration to figure out the final vertical component of velocity. The speed is given by the magnitude of the resultant of both horizontal and vertical velocities - so you need to do a vector sum. Use Pythagoras' theorem for this, it's easy.
There is another force on the proton - gravity, but it's tiny in comparison to the electric force, and can safely be neglected.
I get 1.34 \times 10^{3} ms^{-1} as the final answer.
A much quicker way to arrive at the result F_y = \frac{e\sigma}{2\epsilon_0} is to use Gauss' law on a closed cylinder oriented with its long axis vertical (perpendicular to the sheet).
9K
  • · Replies 33 ·
