Speed of Rocket at 60 Degrees Elevation
  • Context: Undergrad
  • Thread starter Thread starter ProblemSets
    Rocket Speed
The discussion focuses on calculating the speed of a rocket rising vertically at a 60-degree angle of elevation, observed from a point 100 meters away. The angle of elevation increases at a rate of 12 degrees per second, leading to the conclusion that the height of the rocket at that moment is approximately 173.21 meters. Using calculus, the relationship between the height and the angle of elevation is established, resulting in a calculated speed of the rocket at 83.73 m/s, contrary to an initial hypothesis of 4800 m/s.
  • Understanding of trigonometric functions, specifically sine and cosine.
  • Basic knowledge of calculus, particularly derivatives and rates of change.
  • Familiarity with converting degrees to radians.
  • Ability to set up and solve related rates problems in physics.
  • Study related rates in calculus to solve similar problems.
  • Learn about trigonometric identities and their applications in physics.
  • Explore the concept of angular velocity and its relationship to linear velocity.
  • Investigate the use of calculus in real-world physics problems, particularly in projectile motion.
Students in physics or mathematics, educators teaching calculus and trigonometry, and anyone interested in understanding the dynamics of projectile motion and related rates.
ProblemSets
A rocket is rising vertically from a point on the ground 100 meters from an observer at ground level. The observer notes that the angle of elevation is increasing at a rate of 12 degrees per second when the angle of elevation is 60 degrees.
Find the speed of the rocket at that instant.
Since we know the cos(60) =1/2 and the length is 100 meters, the hypothesis is 200 meters. The height then 200sin(60) = 173.21 meters. This problem then can be done with the calculus and can be done without using it. Remember to change degrees into radians for the calculus.
do u get 4800 m/sec?
I got 83.73 m/s
What do we want to figure out? The rate at which the rocket's height is changing, right? We want to find \frac{dy}{dt}.
We know:
\frac{d\theta}{dt}|_{\theta=\frac{\pi}{3}} = \frac{\pi}{15}
Solving using calculus you want to find an equation the relates the height to degrees with the given information, then find another equation that relates theta and the height with respect to time.
  • · Replies 47 ·
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 28 ·
