Speed of satellite orbiting around the Earth
The problem involves a satellite of mass 1,000 kg maintaining an orbit around the Earth and seeks to determine its speed when transitioning from an orbit of radius R to a new orbit of radius 4R. The discussion centers on gravitational and centripetal force equations relevant to orbital mechanics.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between gravitational force and centripetal force, questioning the setup of the equations used to derive the satellite's speed at different radii. Some participants suggest using ratios to compare speeds at different radii.
The discussion is active, with participants providing insights into potential mistakes in the original poster's reasoning. There is an exploration of the implications of using different radii in the gravitational force equation, and some participants clarify the meaning of the variables involved.
Participants are navigating the complexities of gravitational force and centripetal force equations, particularly regarding the interpretation of radius in the context of the satellite's orbit. There is an emphasis on understanding the relationship between the distances involved and the forces acting on the satellite.
bijou1
A 1,000 kg satellite traveling at speed "v" maintains an orbit of radius, "R" around the earth. What should be its speed if it is to develop a new orbit of radius "4R" ?
Gravitational force equation (F) = (Gmems)/r^2
G (universal gravitational constant) = 6.67 x 10^-11 N*m^2/kg^2
me = mass of earth
ms = mass of satellite
r= distance between the centers of me and ms
Centripetal force equation (Fc) = (ms*v^2)/r
v^2/r = centripetal acceleration
r = radius of orbit for satellite
The satellite and the Earth both exert a mutual attraction for each other through the gravitational force equation and the Earth exerts a centripetal force to the satellite, so these two forces can be set equal to each other, since the gravitational force provides the centripetal force necessary for the satellite to orbit the earth.
The speed of satellite "v" when radius is "R"[/B]
⇒(Gmems)/R^2 = (ms*v^2)/R
⇒(G*me)/R = v^2
⇒v = √(Gme)/R
New speed of satellite "v*" when radius is "4R"
⇒(Gmems)/R^2 = (ms*(v*^2)/4R
⇒(4Gme)/R = v*^2
⇒v* = 2√(Gme)/R
since speed of satellite "v" when radius is "R" is equal to √(Gme)/R, substitute this into v* equation,
∴ v* = 2v
However my solution is wrong, and I don't understand why. I would like to know conceptually as well as mathematically the reason why. Any help would be great, thanks!
I have trouble with this problem. Please correct my approach and if my understanding of the concept is wrong. Thanks!
bijou1 said:
[snip]
⇒v = √(Gme)/R
[snip]
Set it up as a ratio. v1 => R, v2 => 4R. What is v2/v1 ?
Quantum Defect's comment should really help. If you want to see where you made a mistake:
What about the the R on the left side?
TSny said:
Quantum Defect's comment should really help. If you want to see where you made a mistake:What about the the R on the left side?
Hi, I may be wrong but I thought the "R" on the left side is the distance between the centers of the masses of the satellite and the earth, so the "4R" would only matter in the right side of the equation. Wait, is the distance between the centers of the masses of the satellite and the Earth = the total radii of the satellite and the earth, so for the left side of the equation, the radius is (4R)^2
∴(Gmems)/((4R)^2) = ms*(v*^2)/4R
⇒(Gme)/4R = v*^2
⇒v*^2= 1/2√(Gme)/R
⇒v* = 1/2v
Please correct me if I am not understanding this conceptually and mathematically. Thank you!
Yes. In the equation (Gmems)/r^2 = ms*(v*^2)/r, the r on the left and the r on the right stand for the same quantity: the radius of the orbit.
When r = R, you have Gmems)/(R^2) = ms*(v*^2)/R
But when r = 4R you get Gmems)/((4R)^2) = ms*(v*^2)/4R
So, is it correct to say the "R" in the left side of equation (Gmems)/R^2 is the radius and the distance between the centers of the satellite and the earth?
R is the distance between the two centers of mass. They talk about the radius of the orbit -- this is wrt to the Earth's com.
Oh, the "radius of the ORBIT." Thank you so much Quantum Defect and TSny. I get it now.
  • · Replies 16 ·
  • · Replies 39 ·
