Speed of signals in digital phone line?
The speed of signals in digital phone lines is approximately a fraction of the speed of light, specifically around two-thirds of the speed of light in copper due to resistance and propagation delays. The information transfer rate is 64 kbit/s, which is distinct from the speed of signal propagation. The electric field pulses travel through the medium, and while electrons drift slowly, the electromagnetic wave propagates quickly. Understanding these concepts is crucial for accurately assessing signal transmission in telecommunication systems.
  • Understanding of electromagnetic wave propagation
  • Knowledge of signal transmission principles
  • Familiarity with the effects of resistance in electrical conductors
  • Basic concepts of digital communication rates
  • Research the speed of electromagnetic waves in different mediums
  • Study the impact of resistance on signal propagation in copper wires
  • Learn about Time Domain Reflectometry for measuring signal loss
  • Explore the differences between copper and fiber optic signal transmission
Telecommunications engineers, electrical engineers, and anyone involved in the design or optimization of digital communication systems will benefit from this discussion.
kejjie
[SOLVED] Speed of signals in digital phone line?
I know that the rate of information transfer in a phone line is 64 kbit/s. I originally thought that this rate of info transfer was the same as the speed of transmission but I now know that this is not true: the speed = distance / time for signal propagation whereas the rate of info transfer = no. bits per page / time to send one page.
Is the speed at which a signal travels down a phone line a set value which I should know?
I'd really appreciate any help! Thanks
sorry! got the wrong sub-forum...
Context: an example of signal transmission - fax and the use of phone lines.
Question: State the approx. speed at which the signals travel.
I know that the rate of information transfer in a phone line is 64 kbit/s. I originally thought that this rate of info transfer was the same as the speed of the signal but I now know that this is not true: the speed = distance / time for signal propagation whereas the rate of info transfer = no. bits per page / time to send one page.
included above
It's an electrical signal so it travels at the speed of light.
Electricity at the speed of light? what about resistance, propagation delay, and/or bandwidth? Dont these things factor into the equation? If you really think about it... telephone travels thru copper til it either reaches fiber/microwave or a switch.. there has to be some loss there but you would have to measure with Time Domain Reflectometry or some such. I never assumed electricity to travel at the speed of light because of the medium thru which she travels has resistance. (ie. copper).. fiber may be a different story, however the end to end encoding/decoding of the signal is surely slower than light itself.
Regards,
-map
Regards,
-map
Spherical chickens in vacuums, spherical chickens in vacuums.
When you talk to someone, you say a certain number of words per minute (analogous to 64 kB/s), but that has nothing to do with the speed of sound - which is what is actually transferring those words.
We have sound in the air, and in phone lines we electromagnetic waves; how fast do they travel?
It's not electromagnetic waves, per se, traveling through copper phone lines. It is a pulsing electric field. Now there's a connection between these things, but electromagnetic waves are made up of photons, and phtons do not travel through phone lines (optic fiber, yes, copper, no).
Yet it is the same limitation. The electric field does not establish itself through the copper wires instantaneously, and so the modulation (oscillation of the strength) of the field takes time to get from one end to the other.
The speed at which this takes place is nearly the speed at which those electromagnetic waves travel.
dst how can an electron travel at speed of light? As far as I know, that's impossible even if we ignore stuff like resistance...
I would say that electric field pulses traveling along the wiring are electromagnetic waves, and they travel at the speed of light in the surrounding medium.
The electrons drift quite slowly, on the order of millimeters per second, but the electromagnetic wave propagates at a significant fraction of c in copper wire.
thanks v. much! so the answer is: roughly (a bit under) the speed of light
This probably doesn't read well, since I've merged two threads on the same questions together, so don't blame me!
I was wondering;"What the ... where did those posts come from?"
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 31 ·
